Hot Rods Flathead block worth?
Discussion in 'The Hokey Ass Message Board' started by PieisgooD, Jun 12, 2015.
  1. PieisgooD
    PieisgooD
    from Omaha
    I have the opportunity to bring home a couple flathead ford v8s out of early 50s fords. They both are still in the cars that have been sitting in a field for quite a while. The owner doesnt know about their condition so I am ***uming they are stuck. Both are complete. What would the bare blocks be worth? And would there be much demand for the other parts off of them? Would there be any other parts to try and snag off of the cars that would be in high demand? I was thinking of grabbing some interior pieces, steering column etc.
  2. patmanta
    patmanta
    from Woburn, MA
    Pictures?
    I had good luck with a flathead that came out of a parked vehicle. They were usually driven there and left, so there's a good chance at having a nice block.
    Values vary wildly depending on where you live and what season it is. They could be worth $100 or $1000 (or more). Regardless, don't let them go to the s****per.
  3. timwhit
    timwhit
    Every part is worth saving. You'll just have to work on them a little to see if they're any good. How much money will determine the next step however. Tim
  4. Bearing Burner
    Bearing Burner
    from W. MA
    The blocks are probably worth$50 as they set. 4 out of 5 will be cracked in valve seats or along pan rails. Maganafluxed or pressure tested then the price is in the $400 range
  5. banjorear
    banjorear
    Two years ago I sold a known good block that was baked, blasted, tanked, and magg'd for $600. It was standard bore.
  6. PieisgooD
    PieisgooD
    from Omaha
    So from the sounds of it, just pulling them out of the cars they won't have much value. I may have to p*** on this then.
  7. flatheadmurre
    flatheadmurre
    If you got the time take them home and take of the heads and pan.
    If you cant see any cracks after a wirebrush cleanup the value just went up :)
  8. k9racer
    k9racer
    With in the last year I sold a 99A long block 650. A 51 Merc complete 800. 2 8ba blocks bare very good condition for 250 each. Any time I can buy a flat head for 100 dollars I jump on the instantly.If they are junk the s**** will bring 30 of your dollars back.
  9. Texas Webb
    Texas Webb
    If I were closer I'd be there with dollars,trailer,tools and chain-fall.
  10. RB35
    RB35
    About the only parts that won't sell readily is the stock manifold and heads. Caveat-Depending on the head letters below the spark plugs, some are worth more than others due to compression ratios.
