Another spindle mount wheel question
Discussion in 'The Hokey Ass Message Board' started by hotrodtim, Jan 15, 2013.
  1. hotrodtim
    hotrodtim
    HI, I have searched but can not seam to find what im looking for. Does anyone know the bearing race sizes on spindle mount wheels. Not looking for part numbers. I would like to know the inner and outer race bore size and seal bore size on FORD, ANGLIA AND any other known spindle! that Spindle mount Halibrand and American racing magnesium wheels were made for. Just looking for a way to tell what wheels fit what spindle. also the hub thickness. thanks
  2. thorpe31
    thorpe31
    from nor-cal
  3. hotrodtim
    hotrodtim
    thanks. but not what i am looking for, I need the hub bearing race size for the wheels not the spindle!
  4. hotrodtim
    hotrodtim
    I know there is hambers on here that has some spindle mount mag wheels to get some measurements. thanks
  5. brandon
    brandon
    Should be the same as stock hub for the spindle your using...
  6. hotrodtim
    hotrodtim
    thanks BUT I am trying to find out all the different hub and bearing race and seal sizes that were available on the spindle mount halibrand and American wheels! FORD, ANGLIA, WILLYS AND MOPAR.
  7. dadz34
    dadz34
    from Sanger, TX
    Call Real Rodder's Wheels. They can get you in contact with Eric Vaughn...he would most likely know. I would measure mine for you except they are mounted on my fendered sedan and they are a major pain in the **** to mount. (Better part of a day).
  8. vegasparky
    vegasparky
    I see this is an old blog. Did you find out, what you needed to know. I can help you with Ford info. g***erted@yahoo.com
