Projects The "All Business Coop" 1930 Model A
Discussion in 'Traditional Hot Rods' started by Hot Rod 50, May 6, 2015.
  1. Muttley
    Muttley
    Yeah.........were going to need some pictures of that. :cool:
  2. gnichols
    gnichols
    from Tampa, FL
    If I'm not too late... is the seat you have the seat you will be using? Steering column and pedals in the correct postion? Then... put on a helmet as you're probably going to want to Billet-proof it some day or race it at any of the other popular traditional events. Then add 2" to the top of your helmet for a little bounce insurance (after the headliner is factored-in!). Then calculate your chop. Visibility isn't everything. And the "Look" isn't all that comfortable for you or your guests if your rod is terribly uncomfortable. FYI, I failed this little test when doing my truck and now I can't wear a helmet without 40 degrees of camber in the old neck joint - nor drive it even an 1/8 mile that way. My vote would be to chop it LAST! Gary
    volvobrynk likes this.
  3. volvobrynk
    volvobrynk
    from Denmark
    Next after the idea about about only doing the small chop, and going after it, the advice above is the best one I've heart in a long time!
    Keep at it, lads!
  4. trucker1
    trucker1
    Lug studs are swedged to the drums so you can't just press out the studs to replace them. That swedge has to be cut out around each stud to release it from the drum causing you to have to replace the drum. If you try to press them out without this it will fold the drum up and maybe damage the hub. I replaced mine with modern studs with the hole reamed to a good press fit. **** Spadaro helped me with that, many thanks to him and many others here on this site for all the help. Glynn.
  5. Hot Rod 50
    Hot Rod 50
    Thanks for that info. They were about to hit the press.
  6. TexasSpeed
    TexasSpeed
    from Texas
    A couple guys PMed me asking about the No. 5 Coupe. It is in Germany now, from what my buddy is telling me. It's a 7" chop. It was built by a Zach Whitlock out of Tennessee. There are a few pictures of it on here but I don't know his handle..
  7. jerseyboy
    jerseyboy
    ^^^I don't usually like heavy chops, but man that chop really accentuates the nose! That is the bomb!^^^
    HR50,
    I'm really enjoying your build by the way.
    Fire Fox and volvobrynk like this.
  8. 31Apickup
    31Apickup
    Someone may not of had a ***le, acquired a different one and made up a tag, it's hard to say. If the state added the tag it would be a state issued number and not a Model A based number. It's difficult to say what occurred over the last 80 some years. The only way to verify the true serial number is pull the body. If you have a ***le in your name matching the tag then I'd just leave it at that.
  9. KustomCandy
    KustomCandy
    from Australia
    Your Garage is the perfect environment for such a build. Reminds me of my owm space. Tho I have uneven Pavers for a floor and two less walls. So Shelter from the elements pretty much ****s.
    This'll be an interesting one to follow.
    Dan
  10. Hot Rod 50
    Hot Rod 50
    Thanks custom Kandy. It's one of our shops that used for oil field equip and repair. Luckily I've got room for the coop and my ghia but it's not a nice shop by any means. Good enough for a backyard hot rod though.
    So as I mentioned the lug studs are way to short. One option would be to run 16 inch wires. But to be able to run these Steelies what should I do. I've figured out how to remove the studs. Then can I just replace with a normal style stud or should I look for some later model drums that will fit the stock brake setup?
  11. tricky steve
    tricky steve
    from fenton,mo.
    Ahhh.. you don't want that old thing... I'll come and get it from ya, save ya the money of the junk man coming to get it......:p:p:cool::cool:
  12. Hot Rod 50
    Hot Rod 50
  13. Hot Rod 50
    Hot Rod 50
  14. Hot Rod 50
    Hot Rod 50
    Stopped at 4ish inches
    chop job, BradinNC and Kool49 like this.
  15. Hot Rod 50
    Hot Rod 50
  16. Hot Rod 50
    Hot Rod 50
  17. noddaz
    noddaz
    Looks good there...
    ROCKER77 and Hot Rod 50 like this.
  18. ROCKER77
    ROCKER77
    looks like a good height to me
  19. Hot Rod 50
    Hot Rod 50
    Thanks guys. I'm pretty happy with it. I was dead set on 5" this morning but this looks right to us with how high the car sits.
  20. scrap metal 48
    scrap metal 48
    I'd go lower now so later your not saying "wish I went lower"...
    v8paul, bengeltiger and Muttley like this.
  21. mike the plumber
    mike the plumber
    4-ish inches looks tough!
    Hot Rod 50 and volvobrynk like this.
  22. Bam.inc
    Bam.inc
    from KS
    4" golden proportion. It's great
  23. Hot Rod 50
    Hot Rod 50
    I keep thinking this but the problem is the header wood will be 1/4 inch over the crown of my noggin and I like my seating as it is. So probably staying here. It looks more hammered in person too.
    I do love the chop on your latest coupe though.
  24. ski
    ski
    from San Diego
    Looks just right even if the car did end up siting a tad lower.
  25. Hot Rod 50
    Hot Rod 50
    I'm pretty happy with the stance. I like em sitting high for some reason. The rake is spot on for me.
  26. Hot Rod 50
    Hot Rod 50
    Here's a good before and after look
    DeLuxe 32, 55zephyr and Lilred36 like this.
  27. Hot Rod 50
    Hot Rod 50
    Also I gotta thank fellow hamber jcfranklin for getting me off my *** and to cutting. He measured it all out for us. It would likely not have happened otherwise.
    I can't stop staring at it!
  28. 55zephyr
    55zephyr
    Looks great, I'd be pleased with that look.
    Cheers, Ron.
    Hot Rod 50 likes this.
  29. wheeldog57
    wheeldog57
    In the past year and a half, three of my friends whacked their 30-31 coupes. One @ 3", one @ 6", and one @ 7". Each car looks very cool BUT after seeing yours, that is where I'm going to chop mine. BAD*** BRO
    volvobrynk and Hot Rod 50 like this.
  30. jerseyboy
    jerseyboy
    Looks good just like another A I like on the "Favorite A Thread":cool::cool::cool: Me likie.
    loginrc and volvobrynk like this.
