Saving a 32 Ford Body
Discussion in 'The Hokey Ass Message Board' started by rcnut223, Dec 11, 2011.
  1. rcnut223
    rcnut223
    from wisconsin
    ImageUploadedByH.A.M.B.1434510194.874438.jpg ImageUploadedByH.A.M.B.1434510210.890233.jpg ImageUploadedByH.A.M.B.1434510229.038252.jpg ImageUploadedByH.A.M.B.1434510240.676404.jpg ImageUploadedByH.A.M.B.1434510260.671858.jpg
    Painted the crossmember tonight
    First few shots were at 6:30
    Now 10 and I am finished, in more than one way ...
    Onward and upward!
  2. Kan Kustom
    Kan Kustom
    Looking awesome !
  3. DeLuxe 32
    DeLuxe 32
    You should post some of these pics in the " painted in my driveway " thread!
  4. rcnut223
    rcnut223
    from wisconsin
    kidcampbell71 and mgtstumpy like this.
  5. rcnut223
    rcnut223
    from wisconsin
    New rear end 3rd member arrived today !!
    kidcampbell71 likes this.
  6. rcnut223
    rcnut223
    from wisconsin
    On its wheels, well fronts at least !
  7. flatford39
    flatford39
    One milestone at a time Mike. This is my favorite thread on here. Hope you do a feature on plumbing break lines or did I miss that one already.
  8. rcnut223
    rcnut223
    from wisconsin
    Thanks flatheadford39
    Fun part was getting the darn thing off the engine stand rotisserie
    Good thing my boys are strong! I'm not anymore
  9. rcnut223
    rcnut223
    from wisconsin
    Hmmm
    Well I have the brake lines installed , honestly can't remember if i posted on that or not or took pictures
    But....
    Tell me what you would like me to cover and I can post some info
  10. patman
    patman
    There's no such thing as too many pictures...keep 'em coming please!
  11. rcnut223
    rcnut223
    from wisconsin
    Not working on the car tonight
    Having a different kinda fun!
  12. rcnut223
    rcnut223
    from wisconsin
    Made significant progress this weekend
    ImageUploadedByH.A.M.B.1434932022.196826.jpg ImageUploadedByH.A.M.B.1434932039.533788.jpg
    Finished up the the exhaust and coated it
  13. big duece
    big duece
    from kansas
    Nice, I like the blue color you picked!
  14. rcnut223
    rcnut223
    from wisconsin
    Finished up the brakes,
    Having issues with the pads dragging, real bummer as I thought I sorted this out pretty well
    Installed the engine and exhaust ImageUploadedByH.A.M.B.1434932242.444875.jpg ImageUploadedByH.A.M.B.1434932256.725770.jpg ImageUploadedByH.A.M.B.1434932270.346666.jpg
  15. rcnut223
    rcnut223
    from wisconsin
    Thanks Big Duece
  16. rcnut223
    rcnut223
    from wisconsin
    Anyone want a junk tool box?
    Notice the boxes by the trash in the ch***is picture?
    Seriously, Finally broke down after 30 years and bought a nice one
  17. Atwater Mike
    Atwater Mike
    My main toolbox is a pair of matched bottom boxes and top boxes, side-by-side, on a rolling ch***is.
    Like the Queen Mary, so I have two more standard 36" wide with top boxes in the main garage and the shop out back.
    I really should 'downsize', but sacrifice tools??? Never!
    Deuce is coming along sooo clean! Love Washington Blue!
  18. alpo
    alpo
    It's coming along real good. I also like your color choice.
  19. tmfcracing
    tmfcracing
    from Sweden
    Its a roller , thats a great milestone Mike !!
  20. treb11
    treb11
  21. rcnut223
    rcnut223
    from wisconsin
    Thanks Martin
  22. rcnut223
    rcnut223
    from wisconsin
  23. rcnut223
    rcnut223
    from wisconsin
    Found the problem with the shoes last night, the anchor pin needed to be installed upside down, cause I miss measured when I welded the plate with the hole for them on the 40 backing plates.
    Might have helped if it had not been a year and a half since I ***embled them last! Oh well! wasted a couple 2-3 hours figuring that one out.
    kidcampbell71 and lowcoe like this.
  24. rcnut223
    rcnut223
    from wisconsin
    ImageUploadedByH.A.M.B.1435117204.865074.jpg ImageUploadedByH.A.M.B.1435117215.914767.jpg ImageUploadedByH.A.M.B.1435117228.881620.jpg ImageUploadedByH.A.M.B.1435117244.285346.jpg
    Finished up the rear brake lines and park brake cable tonight
  25. greaser
    greaser
    Could be the camera angle, but looks like possible brake line pinch point between top of rear axle housing and bottom of frame??
    This ch***is is really taking shape quickly. Looking awesome!!
  26. rcnut223
    rcnut223
    from wisconsin
    y
    You are correct, it possibly is, the coilovers should bottom before this hits at the brake line. I have not figured out how a bump stop to avoid the possibility of a pinch, working o that solution.
    Ideas?
  27. DDDenny
    These worked good for my boxed, c-notched ch***is, just drill and tap frame and don't use the nuts, turn in real tight by hand bump stops.jpg .
    Energy Suspension makes them.
  28. alchemy
    alchemy
    The best solution is to not run your brake lines on top of the axle. Also, make sure to place them in a location that won't get pinched should it ever need cinching down on a trailer.
  29. rcnut223
    rcnut223
    from wisconsin
    Thanks DDDeney!
    Alchemy, I looking into a solution for the clamp the holds the line on the right side, that is were the issue comes in. It's on the top and in the middle of the axle.
  30. rcnut223
    rcnut223
    from wisconsin
    ImageUploadedByH.A.M.B.1435457520.100759.jpg ImageUploadedByH.A.M.B.1435457533.749863.jpg
    Thanks for the watch out on the brake lines
    Here is the fix
