Projects My first project taking up the garage 52 ford mainline
Discussion in 'Traditional Customs' started by cdoh, Apr 11, 2015.
  1. spiffy1937
    spiffy1937
    from Florida
    Happy to see a young guy that is in to working on old cars! Looks like a nice car to start with and you are doing a great job. Wish I was 23 again! (67)
  2. cdoh
    cdoh
    from chicago
    I decided to do some work since I couldn't be at the yorkville show today.
    I cut out the center of the original taillight lens just big enough for the 60 Lincoln lens to slide through from the back. Then I used the chrome trim to sandwich the two lenses together for a factory look. ImageUploadedByH.A.M.B.1435531133.863348.jpg ImageUploadedByH.A.M.B.1435531150.538921.jpg ImageUploadedByH.A.M.B.1435531165.460810.jpg ImageUploadedByH.A.M.B.1435531200.795489.jpg
  3. JohnnyGretsch
    JohnnyGretsch
    cdoh likes this.
  4. cdoh
    cdoh
    from chicago
    I think it pretty cool because its subtle.
  5. JohnnyGretsch
    JohnnyGretsch
    I think if you could get a decent pair of the '54 'rocket slot' surrounds they'd top it off.
  6. cdoh
    cdoh
    from chicago
    It would be cool if you could send me a picture of what you're talking about. I tried a google search but I didnt find anything. I dont know what rocket slots are.
  7. JohnnyGretsch
    JohnnyGretsch
    Something like this.
  8. cdoh
    cdoh
    from chicago
    the chrome trim, right? what model did that come from?
  9. JohnnyGretsch
    JohnnyGretsch
    I think it was a 1954 only piece, from memory they used them on the whole lineup.
  10. deto
    deto
    X2 on the VR-1 20/50. It has kept a few of my clapped out motors alive...
    cdoh likes this.
  11. cdoh
    cdoh
    from chicago
  12. cdoh
    cdoh
    from chicago
    This motor runs like a sowing machine but randomly it will spudded and wanna die unless I keep it alive with the throttle and after a while of driving it goes back to normal. This will happens mostly when the motors is hot. Any suggestions
  13. Skankin' Rat Fink
    Skankin' Rat Fink
    from NYC
    Junk in the needle valve?
  14. cdoh
    cdoh
    from chicago
    You think something is moving around and blocking the fuel in the carb?
  15. Timbofor
    Timbofor
    Sounds like **** in the float bowl. I've had similar issues after waking a sleeping giant. I like to add a fuel filter back by the tank to catch the junk. Preferably the plastic disposable kind that functions like a sediment bowl.
  16. cdoh
    cdoh
    from chicago
    I should probably clean out the sediment bowl. I know I have some **** at the bottom
  17. Timbofor
    Timbofor
    Took mine off when I did the carb swap. I need to fab some mounts up so I can use it again. I'm running a Rochester. So it's got that tiny filter in the fuel inlet. I have clogged it multiple times, even though my tank looks spotless inside.
  18. birdman1
    birdman1
    my second car was a 1953 mainline. No radio, no clock, and only a drivers side sun visor!!
  19. Timbofor
    Timbofor
    People don't believe me when I tell them things like p***anger side mirror, sun visor, rear view, radio and back bumper were considered add on options.
    Won't be long before no one remembers roll up windows.
    cdoh likes this.
  20. cdoh
    cdoh
    from chicago
    seat belts and I think turn signals too right?
  21. Timbofor
    Timbofor
    You are correct. If I remember correctly the p***anger side turn signal was optional. I still don't get why they moved the healthy summer from the floor. It's one of my favorite features of old cars. Moving the stater ****on from the floor was however a good move.
    What dimwit came up with the idea of the starter switch on the carburator linkage.
    cdoh likes this.
  22. cdoh
    cdoh
    from chicago
    I know my dad has a 1958 Buick with throttle start. "We need something new for our Buick line" "Lets start the car with the throttle mashed to the floor!" "....GENIUS!!"
  23. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    The English weren't too far behind. I used to work on the old Jaguar XKE cars. Those were designed as right hand drive and had a manual choke. Well when they converted them over to left hand drive, they never moved the choke lever which was located next to the p***enger door. So to adjust the choke you had to lay across the car to get to the lever.
    cdoh likes this.
  24. cdoh
    cdoh
    from chicago
    haha a buddy of mine works on the new jags and that sounds like some **** they would do.
  25. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    English engineering is an animal of it's own. I worked on close to 50 of those things (I was the new guy and no one else wanted anything to do with them) none of them ran the same, and none of them ran right.
    The explains the old saying, "You have a Jag huh, so what do you drive?"
    bengeltiger and cdoh like this.
  26. cdoh
    cdoh
    from chicago
    I've heard that the old Jag inboard brake could bring a man to his knees.
  27. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    I think book time on that was like 10 hours. You actually had to remove the rear interior to access some of the bolts.
  28. cdoh
    cdoh
    from chicago
    Im glade to work on american cars....
  29. deto
    deto
    X2. Getting a quarter turn at a time with an open end wrench on every bolt on those damned inboard brakes....
  30. cdoh
    cdoh
    from chicago
    I was having a weird idle issue where when the motor was hot it would stutter and Shut down. Turns one idle screw port was clogged. What the hell!!!
