Technical Meedle in Carter WDO carburator
Discussion in 'The Hokey Ass Message Board' started by Never Done, Jun 29, 2015.
  1. Never Done
    Never Done
    from Norway
    This needle, What is it for. And where does I belongs in a Carter WDO. It is for a 1948 olds.
    It is not to the float....
      207.6 KB
  2. papadaddio
    papadaddio
    from Minnesota
    Maybe check needle for accelerator pump
  3. Never Done
    Never Done
    from Norway
    I think so to, is the place for it below the screw
      341.6 KB
  4. Jalopy Joker
    Jalopy Joker
  5. blackrat40
    blackrat40
    Maybe you should carefully take your carb apart and see if you can find a needle valve like
    that inside.
    It is possible that the carb rebuilding kit supplied an alternate inlet needle valve so the
    kit could be used on another similar carb with a different float valve.
  6. Paul
    Paul
    Editor
    Under the meedle screw?
