Projects 41 plymouth coupe 392 hemi build thread
Discussion in 'The Hokey Ass Message Board' started by farmer12, Apr 7, 2010.
  1. farmer12
    farmer12
  2. farmer12
    farmer12
    The inside of the deck lid has been sanded and is also ready for the initial paint soon.
    Plung, mgtstumpy and hemi v8 like this.
  3. ...it's gettin' closer and closer, Eric! Cool!
  4. 1959apache
    1959apache
    We demand more progress!
    Looks good Eric. I am still looking forward to hearing it run!
    farmer12 likes this.
  5. farmer12
    farmer12
    Ok Scott, you want some progress? Here it comes.
    P***enger door is completed now.
    Plung, mgtstumpy, speed v8 and 2 others like this.
  6. farmer12
    farmer12
    Firewall is completed now.
  7. farmer12
    farmer12
    Floor is completed now.
  8. farmer12
    farmer12
  9. farmer12
    farmer12
    And finally, the inside of the removable transmission tunnel.
    Plung, mgtstumpy, Hogman and 2 others like this.
  10. milwscruffy
    milwscruffy
    Well at least there's some shiny black on the insulation ! :D
    OahuEli and farmer12 like this.
  11. farmer12
    farmer12
    I get the hint.....shiny black will be applied in the coming weeks.
  12. 1959apache
    1959apache
    Damn Eric that's a lot of work putting that **** on. I heard that dynamat peels off roofs if you get a real hot spell. Do you get much hot weather there?
  13. farmer12
    farmer12
    I didn't count the hours but I guess anywhere between 20 to 30 hours. The weather never gets real hot around here, rarely above 30 degrees (86 F) and then only for a few days. So I think it will remain stuck to the roof!
  14. Finnrodder
    Finnrodder
    from Finland
    Looks great,but now you cant hear the hemi roaring because of the insulation:D
  15. farmer12
    farmer12
    The electric cutouts will do the trick I think.
    Hivolt5.0 and loudbang like this.
  16. OahuEli
    OahuEli
    from Hawaii
  17. exterminator
    exterminator
    Yeahhhhhhh,your getting closer!
  18. farmer12
    farmer12
    Getting closer indeed, but my patience is being tested at the moment......
  19. Brand Apart
    Brand Apart
    from Roswell GA
    Do tell, Eric do tell.
  20. dirt t
    dirt t
    Eric , I lost track of this build. It's looking better every time I see it. when the shiny paint go on?
  21. C0ra1l1
    C0ra1l1
    Eric, you are accomplishing one of the most significant projects this forum has ever witnessed, both fun and educational. Though being so near, any additional waiting is surely frustrating.
    In Finland summer has been mostly wet and windy so far, hopefully we'll be enjoying warmer days in the coming weeks.
  22. dirt t
    dirt t
    Common to Kingman AZ sun every day and if you golf It's across the street. To get here Mother Road (Route 66) To AZ mileage marker 71 turn in.
  23. exterminator
    exterminator
    I no a little about having your patience tested-so whats up?
  24. farmer12
    farmer12
    Well....the hood and grill should have been finished last month........the last 2 pieces of the puzzle before further work can continue. Going to have a good talk to the guys this week.
  25. Peanut 1959
    Peanut 1959
    Don't they know how much this means to us? ;)
    Hansa1100 and OahuEli like this.
  26. bobss396
    bobss396
    Sometimes progress grinds to a halt... but hang in there, look at how much has been accomplished already. My '59 is finally going together after a long winter of hard work.
  27. farmer12
    farmer12
    Before the guys start final work on the hood, I've decided to strengthen the area near the cowl and the front, where the pin/latch is situated. The new metal will be welded to the support brace once the correct radius is found. This way the hood won't shake and wobble around when driving 200 mph. :)
    Plung, mgtstumpy, speed v8 and 5 others like this.
  28. good idea, Eric, i always wondered how this area of hood will behave while driving and close/open the hood, now i know, same on my ride. actually it lays down on the solid new rubber stripe mounted to the cowl, but each time you're opening the hood it starts wobbeling a bit. good thought and well done. btw, the cooler is overall flat black now and waits for decals and filling up.... :):D p.s.: please drop me a pm with your address....
  29. farmer12
    farmer12
    I know, I know, it's taking a long longer than planned, but the hood is finally in place......still need to adjust it slightly for the gaps though. They're not perfect yet.
    Plung, mgtstumpy, speed v8 and 3 others like this.
  30. farmer12
    farmer12
