Technical 1946 Ford Steering Issue
Discussion in 'The Hokey Ass Message Board' started by Jefftheman03, Jul 4, 2015.
  1. Jefftheman03
    Jefftheman03
    *Ok first off this is my second posting on this problem, the first one has been deleted. I don't know why, I've seen other posts like min.
    I have a 46 ford coupe frame with an aftermarket Mustang II crossmember, stock upper control arms and spindles, tubular lower control arms, and uncut coil springs. I purchased a stock rack and pinion from an 88 Thunderbird for the steering. Yesterday I got the rack put in and connected the tie rods. With the steering centered as best I could (No steering column) i adjusted the toe. I eventually ran out of threads on the inner rod and both wheels where still toed out. What is my problem and how do i fix it? Thanks!
  2. Hnstray
    Hnstray
    from Quincy, IL
    I saw your first thread and noted a post which referenced the fact there are different length tie rod ends, depending on application. That would be a good place to start you research.
    The major chain parts companies have part descriptions and dimension shown for many of their items.
    Ray
  3. 1-SHOT
    1-SHOT
    from Denton
    They use to make rack extensions so you would not have bump steer, I don't know if they are still available.
  4. 2racer
    2racer
  5. Jefftheman03
    Jefftheman03
    I've had a major headache today and haven't gotten around to the car today but as soon as I can I'll measure them and I'll let yall know! Thanks for the help!
  6. Jefftheman03
    Jefftheman03
  7. Hnstray
    Hnstray
    from Quincy, IL
    I had forgotten about this. The MMII crossmember may be wider than the stock dimension (56" track) to accommodate the wider track of your Ford. I ordered a 58" unit some years ago and it came with a rack extension....basically a spacer that screws onto the end of the rack and then accepts the tie rod.
    Different tie rod ends may solve your problem, but the rack extension is something to keep in mind.
    Ray
  8. Jefftheman03
    Jefftheman03
    Thanks for the info but I don't need extensions. It's the stock rod ends that are too long! I have them all the way in and the tires still point outward! Thanks! And for when I build another one I'll have that for future reference!
  9. Model T1
    Model T1
    I know this is not tradtional but seems popular. On my 1948 Chevy panel truck with SBC I used the same set up you have. T-Bird rack and MMII kit. Haven't driven the panel truck but it steers and drives in the yard.
    Remember God created Ford. But when he created Chevy he got it right! He called it Camaro!:rolleyes:
  10. Hnstray
    Hnstray
    from Quincy, IL
    :oops: You are correct, of course.....brain fade on my part. You said toe-out and at some point I knew that.....and then....pfffft...it was gone! My solution addresses excessive toe-in. Sorry.
    Ray
    Jefftheman03 likes this.
