FOR SALE IS AN A/C BRACKET FOR THE 331, 354, &392 CHRYSLER HEMI'S. THIS IS A FULLY ADJUSTABLE MOUNT, DESIGNED TO BOLT TO THE 2 BOLT HOLES ON THE FRONT OF THE WATER CROSS-OVER ON THE FRONT OF THE HEMI, ON THE PASSENGER SIDE. IT MAY WORK ON OTHER HEMI'S, OR OTHER ENGINES FOR THAT MATTER, THAT HAVE THE SAME BOLT SPACING WHERE IT MOUNTS. THEY ARE DESIGNED FOR THE SANDEN MODEL 6668 COMPRESSOR, BUT SHOULD WORK WITH ANY COMPRESSOR WITH A 5 3/4" CENTERLINE MOUNT DIMENSION (FROM SOLID MOUNT TO SWIVEL MOUNT CENTERLINE). THE HOLE SPACING FOR WHERE IS MOUNTS ON THE WATER CROSS-OVER IS 1 3/4". THE SPACER THAT IS WELDED IN THE CENTER HAS A LARGE HOLE CUT IN IT TO RUN WIRES/HOSES THROUGH. THIS BRACKET IS MADE FROM 1/4" HOT ROLL MILD STEEL. THESE ARE PLASMA CUT AND BUILT IN A JIG TO ENSURE A QUALITY FIT AND FUNCTION. THE REAR OF THE BRACKET IS CUT OUT CONTOUR AROUND THE HEAD. NO SPACERS ARE PROVIDED BECAUSE EACH APPLICATION MAY REQUIRE A DIFFERENT SPACING FOR PULLEY ALLIGNMENT. FEEL FREE TO EMAIL WITH ANY QUESTIONS. AS WITH ALL OF MY PRODUCTS, THESE ARE MADE IN AMERICA, BY ME!! PRICE IS FOR A BARE STEEL BRACKET. CONTACT ME WITH ANY QUESTIONS. THESE FIT IN A $11 FLAT RATE SHIPPING BOX. THANKS AGAIN, JEFF 360-751-5959 I ALSO OFFER A PACKAGE DEAL PRICE TO GO WITH MY CUSTOM MID/LOW MOUNT ALTERNATOR BRACKET (SEE SEPERATE POST FOR THAT INFO), $80 FOR THE PAIR (NORMALLY $90)
