Projects 1955 Chevy 210 Build
Discussion in 'The Hokey Ass Message Board' started by rsg2506, Jul 10, 2014.
  1. Drum brakes are faster. You can adjust drum brakes to where the turn freely without any brake drag. Get a set of 61 thru68 full size chevy hubs & bearings and convert your 55 to tapered roller bearings. change to a dual mster cyl. disk brakes always drag a bit. electric fan -drum brakes adjusted loose- skinny front tires inflated to 60 pounds = 1/2 second faster ET. My 55 2 dr wagon has drum brakes and im keeping them.
  2. rsg2506
    rsg2506
    I ended up putting disks on the front. It stops pretty good (not that I drove it that much before I pulled the motor). I scored a 12 bolt posi (3:73) out of 69 camaro for a really good price. I'll be swapping that in next.
    Btw chuck...Coupes are for chickens...lol
  3. pdq67
    pdq67
    Please consider the old CRAGAR deep dish chrome reverse rims or Fenton type slotted mags.
    Modern tires sized like the old E-60/14's and L-60/14's
    My L's measure a modern 298-53/14" size and I still have them out in my garage on my 9" x 14" Fenton slotted mags. as well as my 7" x 14's the E's are on.
    I did have the Chrome reverse on my '67SS/RS Camaro car before the slots.
    pdq67
  4. rsg2506
    rsg2506
    A couple updates...
    I fitted a 1969 Camaro 3:73 12 bolt posi. I set the pinion angle and welded on new perches....
    AHotRod likes this.
  5. rsg2506
    rsg2506
    The motor is cleaned up, painted, and ready to go back in once I paint the firewall and front frame components.
    AHotRod likes this.
  6. Like low budget said the drums ought to stop it just fine. If I had to go with discs unless I was just wanting something high zoot I would go with GM metrics, they work are cheap and easy to find in a about any autozone in the nation.
  7. ChucksCrib
    ChucksCrib
    from Uranus
    Looks like you have a well behaved, obedient shop dog there too
  8. rusty1
    rusty1
    bikes 006.jpg ....nice project you have there, ...wish I had this ol 55 back...
    AHotRod, brut4s and rsg2506 like this.
  9. belair
    belair
    Looking good.
    rsg2506 likes this.
  10. alfin32
    alfin32
    from Essex, Ma.
  11. rsg2506
    rsg2506
    A little more progress ...
    Blasted the frame and firewall
    Painted the frame with por15 and getting ready to clean up the firewall and lay down some white paint.
  12. rsg2506
    rsg2506
    I'm moving the battery to the trunk and filled some of the holes in the firewall. I shot the firewall single stage gloss black.
    I did the dash too....
  13. rsg2506
    rsg2506
    Dropped the big block in.....
  14. ChucksCrib
    ChucksCrib
    from Uranus
    "Dropped the big block in"
    Probably a :10 job without the front clip off...........for most
