Projects 33 chevy 3w....time for a cool change
Discussion in 'Traditional Hot Rods' started by tb33anda3rd, Feb 11, 2014.
  1. tb33anda3rd
    tb33anda3rd
    worked on the air filters. i had them chromed but did not want to put them back together with the horse hair filter. i picked up a couple k&n air filters to cut down to fit. i removed the rubber gasket from the new filter, and opened up the inner flange. i then took the chrome air cleaner apart and removed the inner mesh. DSCF4180.JPG DSCF4174.JPG
    volvobrynk likes this.
  2. tb33anda3rd
    tb33anda3rd
    i then cut the filter down to size, 3 1/4" and then to seal it, i made a rubber gasket for the top and bottom. i think this should work out fine. DSCF4175.JPG DSCF4177.JPG
  3. tb33anda3rd
    tb33anda3rd
    ***embled, and now i just need to do the other one. DSCF4176.JPG DSCF4179.JPG
  4. blowby
    blowby
    from Nicasio Ca
    Just tuning in for tonight's installment of 'Somebody's getting something done around here'. Sweet air cleaners. What I like about your photos is you leave all the tools and **** laying around.
    volvobrynk and oldcars.acadia like this.
  5. tb33anda3rd
    tb33anda3rd
    hah, once i get focused i just work. cleaning up is my warm up for the next step. sometimes the next day i wonder, what the f'''''k happened in here?
  6. mike the plumber
    mike the plumber
    wow that's a keeper
  7. tomkelly88
    tomkelly88
    It sorta looks like your work bench is only held up by a rough old stack of timber blocks, don't go working away on it too hard!
    That setup looks cool as, can't wait to see it on the car.
    I'm really enjoying this rebuild, keep up the good work!
  8. tb33anda3rd
    tb33anda3rd
    yes it does look like it is on the pile of wood. but there are six legs on that table with 6 big casters. i have actually set cars on that table and rolled them out from under the lift.
    thanks, i am glad your enjoying!
  9. FolksWaggin
    FolksWaggin
    OK, gonna try to post a video of Ted's Chevy starting up...
  10. YJ4000
    YJ4000
    SWEET!! Sounds good.
    Ryan.
  11. ct1932ford
    ct1932ford
    Were you laying on the floor working the throttle? :confused: Sounds like it should:cool:
  12. tb33anda3rd
    tb33anda3rd
    this engine sounds so different from the near stock 283 i had in it. dad always liked/had the car quiet, think "sleeper". i used the gl*** packs, sitting in the middle of the 2" exhaust, with full tail pipes to give it a "tame" sound, but when i jumped on it it had a little "roar". this engine may need different mufflers.
  13. tb33anda3rd
    tb33anda3rd
    fuel pump arrived. i went with a carter marine pump, it was the only pump that said it would work with ethanol fuels. i decided to mount it on some rubber mounts i had, to quiet it down, now i just need get a new filter. i was happy to see it was made in the u.s.a.
  14. tb33anda3rd
    tb33anda3rd
  15. tb33anda3rd
    tb33anda3rd
    also finished cutting down the second air filter and washing them both out. when they dry i will oil them and install them. DSCF4185.JPG
  16. The37Kid
    The37Kid
    Red air filter screens look fine, should help quiet the red wheel requests. Bob
  17. ct1932ford
    ct1932ford
    :D
  18. Runnin shine
    Runnin shine
    [emoji87]
    tb33anda3rd and kidcampbell71 like this.
  19. Sprockmonster
    Sprockmonster
  20. pumpman
    pumpman
    ummmmmm, me likey. Talk about a sleeper, you can't even see the driver.
    tb33anda3rd likes this.
  21. HOTRODPRIMER
    HOTRODPRIMER
    Ted,the car sounds great,your making a lot of progress. HRP
  22. tb33anda3rd
    tb33anda3rd
    that means good, right?
    :cool:
    thanks Danny, hope to have a productive weekend.
  23. tb33anda3rd
    tb33anda3rd
    put the fuel filter on tonight and it is running and idling better.:)
    if i find someone to help me put the seat in tomorrow i will back it out of the barn.:):) DSCF4186.JPG DSCF4187.JPG
  24. TFoch
    TFoch
    Wished I lived closer, I'd love to help and get to see it back out of the garage!
  25. tb33anda3rd
    tb33anda3rd
    my neighbor will help but they are in full "hay" mode, so i have to catch him before the dew burns off or after they load the barn........it's after 10 now and i can hear the tractor moving around.
    i can always use a crate.
  26. tb33anda3rd
    tb33anda3rd
    my neighbor helped me put the seat in early saturday morning. DSCF4193.JPG DSCF4196.JPG
    volvobrynk and falcongeorge like this.
  27. ct1932ford
    ct1932ford
    Was that supposed to be red and white?:rolleyes: Did you get the 2 - 4's on?
  28. tb33anda3rd
    tb33anda3rd
  29. tb33anda3rd
    tb33anda3rd
    pulled off the bracket and mounted the generator on the header directly, with the help of another bracket i had, so i could take the valve cover off easier to adjust the valves. while the bracket was off i contoured the corners to match the bracket my dad had made. DSCF4197.JPG DSCF4194.JPG DSCF4195.JPG
  30. The37Kid
    The37Kid
    my neighbor helped me put the seat in early Saturday morning.
    That was nice since his cows match the interior. Bob
    volvobrynk and tb33anda3rd like this.
