Customs My shoebox chop
Discussion in 'The Hokey Ass Message Board' started by Stefan T, Oct 21, 2009.
  1. spasecadet
    spasecadet
    from PDX
    That's awesome! Great to see it coming together!
  2. Stefan T
    Stefan T
    from Sweden
    Thanks for the coment
    a little update
    I have begin to ***emble the inner fenders
    Her's the fenders in place for test
    A pic from the front from the outside of the garage.
    The fenders in place but only for test so aftr pics was taken the fenders was off aigin
    /Stefan
    dlandberg likes this.
  3. oldman2
    oldman2
    Test fit was looking good...Jim
  4. Stefan T
    Stefan T
    from Sweden
    Update!
    Maybe not so mutch but little more progress
    I have made a plate in the lower wheel house on p***inger side like that one
    that cover the clutck pedal
    I seems that the should not have one plate there in the spare parts catalog
    The front parts is now little more toghter
    /Stefan
  5. oldman2
    oldman2
    Front end looks really clean, nice job...Jim
  6. Stefan T
    Stefan T
    from Sweden
    Thanks for the comment
    I have not posted anny pics from my shoebox build for a waile
    But have i some update of this thread
    I have a grill to shoebox from a 1949 to my 1950
    I have bought it for some yers ago on ebay
    But the center part was from a 50 an i have a 49 holder but i have to the 50 style insted
    The spare catalog sayed 2 3/8" offset so i did one with that and used the front hole in splashplan
    insted of the inner hole that fit to the 49 holder
    The center part fitted on the holder
    Center part instaled on the car
    It was necary to make holes for the positions light from the 49 in the fenders
    I use a 1 1/2" green lee knock out punch
    Holes in the fenders now time for the screw holes to
    The positons lights holer in place
    This was the grill part for to day
    /Stefan
  7. Stefan T
    Stefan T
    from Sweden
    But i have little more to post after near 2 month
    I have let a frend print out some duckt flanges to the air cleaner
    They are 3d printed in black ABS and grinded and painted black so the dont look 3 printed out
    I have installed them in the ventlaion chanels in the innner fenders
    I cut up holes in the ventlation chanels so can get cold air tho the carb in top of the blower
    All for to day
    /Stefan
  8. oldman2
    oldman2
    Stefan, grill looks super on the car, nice job. 3d parts look great...Jim
  9. Stefan T
    Stefan T
    from Sweden
    That was a wail since i posted some pics of my shoebox build
    But now have i done some more work on it
    I have a problem
    The ford 8" rear end is to wide to the rims and tyres i think to use
    I have bought some new shafts in type cut to fitt
    Here on toghter with the old shafts
    The rear end out of the car
    I will do a cut on the long side of the banjo
    I take of the brakets to the springs
    A stright cut and clean up the end from the old pipe
    The end is pressed in to the cut of the pipe
    The rear end is here weled and the brackets in place
    Painting is left
    Drive shafts is in for test after cuting
    The drive shafts bouth the original one and the old ones
    The rear end is narowed near 2½" (62mm not 63,5mm)
    The car is down on the floor aigin with Amercan racing torque thrust type D rims
    The rear rims are 8,5"/15" with 245/60 15 tyres and the front is 7"/15" with 215/65 15
    A pic from rear
    /Stefan
  10. dlandberg
    dlandberg
    from Sweden
    Looks great! Good work on the rear axel!
  11. Stefan T
    Stefan T
    from Sweden
    Thanks
    Eller skall jag säga tack
    /Stefan
  12. dlandberg
    dlandberg
    from Sweden
    Haha ja vi talar ju samma språk, får jag fråga vart du köpte drivaxlarna? Planerar nåt liknande till vintern med en 9 tummare i k-link på min. / David
  13. Stefan T
    Stefan T
    from Sweden
    Jag köpte drivaxlarna på summit racing
    Jag köpte även lager och plattor som håller fast axlarna och för säkerhets skull även nya ändar
    men dom behövde jag inte
    De är samma grejer till 9" med små lager och 28 spine så det var inget konstigt
    I bougt the drive shaft of summit racing
    I bought even berings and backing plates to hold the shafts and to be shore eve new ends
    but i don't used them
    That is same parts to 9" with small bearings and 28 spline shaft so it's nothing strange
    and i did't use google translate
    /Stefan
  14. dlandberg
    dlandberg
    from Sweden
    Thank you Stefan! / David
  15. oldman2
    oldman2
    Stefan, everything is looking good...Jim
  16. johnod
    johnod
    Nice work the car is looking really good.
    Thanks for posting.
  17. Stefan T
    Stefan T
    from Sweden
    Thanks for the coments
    There will more post later this sommer
    But if not post annythig tomorrow it won't be before week 30
  18. Stefan T
    Stefan T
    from Sweden
    An update before i go on a summer holday trip
    I have begin to put on bondo on the roof
    And some other places to
    The roof was not perfect shape after loto of weldig and blasting so i have already
    used 4,5kg (10 pounds) of bondo
    /Stefan
  19. James D
    James D
    I was a little surprised by the choice of wheels, as I was expecting something more `kustom` looking, but they actually look really fine.
  20. Rui
    Rui
    You have come a long way. Congrats
  21. Stefan T
    Stefan T
    from Sweden
    Thanks for The coments
    I havet choise The wheels With lott of care
  22. Finnrodder
    Finnrodder
    from Finland
    Nice progress,Stefan!
  23. Stefan T
    Stefan T
    from Sweden
    That was a wail since i updated the thread
    The shoebox is out door on American racing Type D wheels
    I have worked a lott on the car this last weeks
    I have begin to flaten the roof with bondo and some more places on the car
    It was not easy to get good shape on the roof and i have only done the worst
    /Stefan
    loginrc likes this.
  24. BrerHair
    BrerHair
    Wheels & tire combo make it look like a hot rod, not a custom. I like it.
  25. KustomKarlsson
    KustomKarlsson
    from Sweden
    Nice work ! Rims really say "Hot rod", in a good way ! ;) Maybe time for a visit ? Anything i can contribute with ? Maybe something from the "Brewery".....
  26. Baldies
    Baldies
    Just found this thread. Don't leave me hanging. I want to see your car with windows. I cannot believe the method you used for chopping that top.
    Out standing work.
    If I visit relatives in Smaland I will have to try to visit you at a car show.
