Technical Leaf spring lowering
Discussion in 'The Hokey Ass Message Board' started by Ian hall, Apr 26, 2015.
  1. Ian hall
    Ian hall
    from Uk
    I'm fitting a 3" dropped axle to my jailbar pickup. I'm looking to get a total drop of 4". The intention is remove 1 or 2 leaves to get a further 1".
    Should i remove a longer or shorter spring?
    Is it a good idea to lubricate the leaves or fit some kind of slippery material between the leaves, I intend to paint the springs packs when I'm done
    Thanks
    Ian
  2. earlymopar
    earlymopar
    For "lubrication" I use the plastic spring liner material that fits between the main leaf and each spring below. Removing leafs is not the best idea but it's hard to answer without knowing how many leaves you're starting with. What I did to achieve the same result that you're after is had new main leafs made with the eyes reversed (on the underside of the spring rather than being on top).
    - EM
  3. fordor41
    fordor41
    I tried all sorts of leaf combos and settled on reversed main, stock 2nd and every other leaf removed. 11 leaves to 7
  4. Ian hall
    Ian hall
    from Uk
    I'm hoping removing one or two leaves will soften it up a little as it currently has very little suspension travel
    Ian
  5. Rusty O'Toole
    Rusty O'Toole
    Long leaves carry the weight and the short ones stiffen the spring.
  6. Ian hall
    Ian hall
    from Uk
    Right, so which would lower it a little?
    Ian
  7. Just Gary
    Just Gary
    It's a trial and error process.
    In general:
    If you remove longer leaves (and leave shorter leaves in place), the spring will be lower & stiffer.
    If you remove shorter leaves (and leave longer leaves in place), the spring pack will be lower & softer.
    I ***ume you've already reversed the eyes on the main leaf? That's usually done first, before experimenting with leaf removal, and lowers the car about an inch.
  8. Ian hall
    Ian hall
    from Uk
    I haven't reversed the spring as yet, I want to lower it and soften it a little
    Ian
  9. Pete1
    Pete1
    from Wa.
    Reconditioning a early Ford spring.
    First, inspect the top of all the leaves for grooving.
    If grooved, grind and taper the tops of all the leaves
    for the last 3 inches.
    The number of leaves you use will depend on the final
    weight of the car and the "ride" you want. On a typical
    early Ford it is possible to get a 100 lb. per inch spring
    rate which will give a very comfortable "touring ride".
    Have the shocks disconnected when checking spring rates.
    The easiest way to check spring rate is measure the height
    of a point on the front bumper. Apply a known weight to
    the front bumper such as a 200 lb. person. Measure the
    same point again. Say it went down 2 inches. You have
    roughly a 100 lb per inch spring rate on the front.
    DO NOT USE GREASE BETWEEN THE LEAVES. It will only attract
    dirt and then you have grinding compound. I Parkerize
    the leaves (optional) and then spray them all over with
    SlipPlate (trade name) which is a graphite spray or
    Moly Kote (trade name) which is a molybdenem disulfide
    base spray.
    DO NOT PAINT ANY PART OF A SPRING. The graphite or Moly
    spray will stop rust. Slip Plate can be had at John Deere
    dealers. Moly Kote can be had at auto parts dealers.
    I use 1/16 UHMW plastic between the leaves.This is the
    same as Teflon but about 1/3 the price. This is optional
    but really decreases friction and prolongs spring life.
    After determining the final configuration of the spring
    I wrap it with black electrical tape from the eyes to
    the U bolts. This keeps dirt out. There are commercial
    spring covers available also.
    If you use a reversed eye main leaf, be sure the second
    leaf is short enough that there is no way it can bottom
    on the eye when at full compression.
    Sometimes the original spring clips will not reach over
    the spring after the UHMW is added.
    It is a simple matter to fabricate ones that will.
    The inside top of the cross member where the spring seats,
    usually has a radius.
    BE SURE the top leaf of the spring has a radius to match.
    A sharp corner on the spring leaf can cause a cracked
    cross member.
    I use moly filled Delrin shackle bushings because they
    have almost no friction and they never wear out.
    mink, warbird1 and Texas Webb like this.
  10. Jalopy Joker
    Jalopy Joker
    post some pics of what you are working on
  11. Ian hall
    Ian hall
    from Uk
    I removed the mountings on the rear leaves and intend to remount them 2 1/2" higher and then remove leaves to hopefully get 4-5" of drop
    Here is my rear leaf pack, I hope to get around 2-3" drop, how many leaves to take out?
  12. Pete1
    Pete1
    from Wa.
    It is not a cut and dried process. Each spring is different...To get in the ball park try removing leaf 3-5 and 7 numbering up from the bottom. Do not remove number 2 under any conditions.
  13. Ian hall
    Ian hall
    from Uk
    That's interesting, I was thinking of removing every other leaf, what's the deal with number 2?
    Ian
  14. Thor1
    Thor1
    Ian,
    I am interested to hear the answers to this as well. If I understand what you are asking you're looking for information on how your spring pack will respond to leaf removal WITHOUT doing any other work such as reversing the eyes on the main leaf. Correct?
    I need to lower my '47 Tudor and eventually will add a dropped axle. But for now I want to remove a few leafs to lower the car as much as possible without doing anything else at this time. Thanks for asking your question on the forum.
    Thor
  15. Ian hall
    Ian hall
    from Uk
    I'm saving the reverse eye mod! If it isn't low enough I will reverse eyes front and rear
    Ian
  16. Pete1
    Pete1
    from Wa.
    The main leaf and #2 have the most strain on them. If either one fails you can get the car stopped safely. If you remove #2 the main leaf is doing all the work. If it fails you are as they say in railroad
    talk, on the ground.
    If you go to a reverse eye main leaf, be sure the ends of the second leaf absolutely do not touch
    the eye of the main leaf at full compression.
  17. pdq67
    pdq67
    UHMW Polyethylene is not Teflon.\
    The cheapest, but not the easiest way to do this is to hunt up an old 150 pound or heavier blacksmith anvil and a 3 to 5 pound blacksmith hammer and reverse bend each leaf by beating on them until they bend the way you want them..
    Just walk the hammer down the center of each leaf as you watch your blows carefully bend them.
    It won't take much to do this and if you are lucky enough to find or know an old Blacksmith, he can help you do this in several hours..
    My old Blacksmith Buddy taught me this back when I was a pup in HS...
    I figure a commercial spring repair shop nowadays will use a "cold roller" or maybe a "trip hammer" instead of a blacksmith hammer to do this easier and faster.. BUT it still is kind of an art. You know, onna those "feelie" deals to get the drop you want..
    pdq67
  18. Pete1
    Pete1
    from Wa.
    "UHMW Polyethylene is not Teflon.\"
    You are right. I should have said it has similar characteristics for the application we are talking about.
    They are both very low coefficient of friction materials.
  19. Ian hall
    Ian hall
    from Uk
    Isn't it easier to use a jig and a small bottle jack to rebend the spring? Haven't done it but seen a few posts and vids on the subject
    Ian
  20. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I used a HF press to flatten the main leaf in my '37. Just marked it off in 3" segments and put the same number of pumps at each location. (Go easy at first, you'll get the hang of it) First one took about a half hour, second one about 15 minutes.
    Straddle the press frame and let the jack do the work.:)
  21. Ian hall
    Ian hall
    from Uk
    I am now ready to refit the front axle(had the kingpins fitted today)
    Have a 3" dropped axle from Sid and want a further 1-2". The front leaf pack has 7 leaves, I initially removed number 2, now I wonder if that is wrong and maybe I should refit no 2 and remove no 1
    Not a big deal removing leaves later but would be nice to get in the ballpark initially
    Thanks
    Ian
  22. Ian hall
    Ian hall
    from Uk
    Finally back together. Not super low but looks so much better
  23. Ian hall
    Ian hall
    from Uk
    Front suspension is very firm, make that very very firm!!
    I have only removed the shortest leaf, should I put that back and remove a longer one? Don't mind if it drops a touch more but would like to soften the ride
    Ian
  24. coolvato
    coolvato
    Looks good, I just installed a 4" dropped axle from Sid as we'll and removed two leafs (1&2) but now I'm starting to second guess removing them.
  25. Ian hall
    Ian hall
    from Uk
    Wondered if I should have used a 4" drop but then I would still need to remove leaves to soften it.
    Would be interested on pics with that axle,how did you do the rear?
    Ian
  26. coolvato
    coolvato
    3" blocks on rear no leafs removed.
  27. Ian hall
    Ian hall
    from Uk
    What year truck is that on? Blocks wouldn't work on mine
    Ian
