History Time Capsule: 31 Ford Model A Drag A/Gas Coupe
Discussion in 'Traditional Hot Rods' started by Chris.., Jul 14, 2015.
  1. Chris..
    Chris..
    from CT
    Thought I would start a new thread in reference to my recently purchased 31' Ford Model A Coupe in hopes some members would know it's past. I recently purchased this coupe that sat in a garage in/around NYC untouched for 49 years. I believe it was raced in the late 60's/70's in Middletown NY, up and down the East Coast. The car is the CLEANEST model A coupe body I have ever seen. Zero bodywork, zero patches, everything is as per Henry. The car has a mid 60's 327, edelbrock crossram with dual carbs, powerglide trans currently; with a 4 speed with it/ansen scatter shield, Olds rear, vertex magneto, late 40's front end with juice brakes, aircraft harness, vintage rollbar, all custom vintage interior and guages, MH Racemaster original slicks, eelco tank, from the looks of the setup the car was running on alcohol. I've tried to do some searching on the internet but haven't been able to come up with much.
    Curious as to what the current value of this car would be? I have a steel 32' 5w and another chopped 31' A coupe with a flathead and am having some serious issues deciding which one to let go!
    volvobrynk likes this.
  2. 55 Ford Gasser
    55 Ford Gasser
    Pictures? Sounds like a good find. Looking forward to pictures and hopefully info about it from other Hambers.
  3. Chris..
    Chris..
    from CT
  4. Chris..
    Chris..
    from CT
  5. Chris..
    Chris..
    from CT
  6. Chris,that is a very nice car,I hope you find the history on the car. HRP
  7. Chris..
    Chris..
    from CT
  8. Chris..
    Chris..
    from CT
  9. Chris..
    Chris..
    from CT
  10. Chris..
    Chris..
    from CT
  11. Chris..
    Chris..
    from CT
    bct, 55 Ford Gasser, kiwijeff and 2 others like this.
  12. Chris..
    Chris..
    from CT
  13. Chris..
    Chris..
    from CT
    55 Ford Gasser and volvobrynk like this.
  14. Chris..
    Chris..
    from CT
  15. 55 Ford Gasser
    55 Ford Gasser
    WOW!! I love it. Keep your other cars and sell this one (to me, that is). As I said above, great find. They are still out there. Why can't I find one?
  16. czuch az
    czuch az
    WOW!!!
    Keep em all, sell one of the white ones.
  17. Chris..
    Chris..
    from CT
    Tuck, 55 Ford Gasser and volvobrynk like this.
  18. It was running alcohol,it would not be an A/Gas car...different classification if running alcohol...more like A/FC...
    meaning A/.fuel coupe
  19. Chris..
    Chris..
    from CT
  20. Chris..
    Chris..
    from CT
    volvobrynk and 55 Ford Gasser like this.
  21. Chris..
    Chris..
    from CT
  22. Well that car aint worth nuthin it aint got no firewall or dash. :D :D
    neat old car easy enough to tell if it was burning methanol open the carbs up the insides of the bowls should be eaten pretty bad, it would also have larger then original needle valves and huge jets.
    That said gas or alchy it is a neat old car and I would sure enough sell whatever other car would not make the best hauler to get that one.
  23. Chucky
    Chucky
    Very cool!
    1927graham likes this.
  24. wheeldog57
    wheeldog57
    That is wicked pissah! Put headlights on it and use it every day
  25. mike bowling
    mike bowling
    That is incredible- although the door panels are not what I expected! - a time capsule indeed. I don't envy you for the decisions you'll have to make- Keep it ( yes), clean it (?), race it (?), build a big glass trailer to keep it in and do the Nostalgia circuit? Stare at it for hours on end? Good luck with it!
  26. Wow, great find. Congrats.
  27. studebaker46
    studebaker46
    is the engine rebuildable I would love to find something like that. I would keep period set-up like it is but that's me congrats on the find and keep us posted. Tom
  28. Great Find! So here's some thoughts....I know,worthless.......... Like everything else- Original state ONCE.
    Plans? Once detailing/cleaning,it's gonna loose the 'time frame " factor.......
    If it's gonna be yours= Clean/detail/re-furb- But please don't loose that vibe or time frame......
    Don;t get to shiny if so...... Mechanical FIRST!
    Hope you do it up/preserve it's mean demeanor.....
  29. I bet it would be "fun" at about a hundred!!!!!
    kidcampbell71 likes this.
