Technical '49 Chevy Engine Fan Removal?
Discussion in 'Traditional Customs' started by JohnnyGretsch, Jul 16, 2015.
  1. JohnnyGretsch
    JohnnyGretsch
    Hey guys,
    I'm trying to change the water pump on my '49 and I can't seem to separate the fan from the pulley. I've taken the four bolts out but it won't budge. I can't see anything about it in the w/shop manual, but figure someone on here would know.
  2. engine138
    engine138
    from Commack NY
    Might need to give it the blue flame job (HEAT) Mate
    JohnnyGretsch likes this.
  3. aaggie
    aaggie
    It's just stuck from being on there for a long time. Try all of the usual methods like heat and BFH.
  4. jcmarz
    jcmarz
    from Chino, Ca
    WD-40, screwdriver, and a hammer.
  5. hacknwhack
    hacknwhack
    from mass
    There is a centering pin on the waterpump hub. 1/2 " in diameter
    It cteates a snug fit for the fan and pully. Add time and corrosion it becomes tighter.
    Spray a some pb blaster on it and soak overnight.
    Put a prybar between the pump and pully apply medium pressure and tap fan hub with a hammer .
    This induces a harmonic
    Wave that pops them off
    180 the fan and repeat.
    May take a few rounds.
    Btw if the radiator is still in
    Put a cardboard or similar sheet between the fan and radiator or you will risk damaging the rad.
    Good luck
  6. JohnnyGretsch
    JohnnyGretsch
    Sure enough, I put some WD40 on it yesterday afternoon. I wailed on it with a rubber mallet for about 10 minutes this morning and it came straight off! Cheers fellas!
    hacknwhack likes this.
