Hot Rods Hydroboost
Discussion in 'The Hokey Ass Message Board' started by CayoRV, Jul 18, 2015.
  1. CayoRV
    CayoRV
    Does anyone have experience with GM Bendix hydroboost brake systems? I have one on my COE and it seems to have gradually developed a problem. It needs an excessive amount of pedal pressure to stop now. The pedal is firm which makes me not suspect the master cylinder of brake system. It feels like its just not boosted. I have run one recommended test, push the pedal 4/5 times, hold it down and then start the truck. The results would indicate that it is working but evidently not properly. Any insights would be great.
  2. Power steering working correctly?
  3. CayoRV
    CayoRV
    Yes, no problems with the power steering, just feels like no boost for the brakes. All four corners on the brakes are working so I don't think its a master cylinder issue.
  4. CayoRV
    CayoRV
    Changed out the hydro boost with another I had (used but was known to be working) and I now have ***ist. Pedal feel is still pretty firm but she stops now without having to stand on it with both feet!
  5. Sounds like you cured it.
  6. Jakes52COE
    Jakes52COE
    Hi, I'm planning a hydroboost on my COE, do you have photos of your build?
