Projects '24 T Roadster build
Discussion in 'Traditional Hot Rods' started by Anderson, Aug 21, 2012.
  1. brad2v
    brad2v
    Looking better all the time. I really love this car
    Anderson likes this.
  2. Bugsy
    Bugsy
    from Kansas
    This was a fun build to watch and turned out perfect. You nailed the era on this too. EXCELLENT JOB.
    volvobrynk and Anderson like this.
  3. Runnin shine
    Runnin shine
    Noooooo don't loose the Merc caps. Didn't you go some lengths to run or have a set?
    volvobrynk and falcongeorge like this.
  4. Six Ball
    Six Ball
    from Nevada
    Either way is cl***ier than chrome steelies.
    volvobrynk likes this.
  5. PurdueSD
    PurdueSD
    Those look great too! Did you ever find another turtle deck? I'm looking forward to seeing it get some junk in the trunk!
  6. Runnin shine
    Runnin shine
    The frame is literally "in the weeds"
  7. dentisaurus
    dentisaurus
    from Boston
    Love it
  8. 3spd
    3spd
    Don't raise it! Mount a lawnmower blade under it and have the most bad*** mower on the block!
    Kidding aside - that car is damn near perfect in my eyes. Usually I can pick out atleast 10 things I would change on a car but I can't find any on yours.
    Ryland
    davo461 likes this.
  9. 2OLD2FAST
    2OLD2FAST
    from illinois
    Curious as to how much rear suspension travel you have without notching the turtle deck...
    dave
  10. nitrobrother
    nitrobrother
    Did you decide on a color?
  11. Runnin shine
    Runnin shine
    What happened to the over under deck setup? I thought that was just about lack of time too?
    Tim_with_a_T likes this.
  12. davo461
    davo461
  13. Gary Addcox
    Gary Addcox
    Was it OLDS or Caddy at the finish ? Just gotta ask !
  14. Equipped28
    Equipped28
    I had the same thing with my T I need to swap the T spring out for an A one as mine has sagged big time! I've now got a tail dragging roadster! Your T is looking perfect though.
  15. falcongeorge
    falcongeorge
    from BC
    now that the car is running, how is the sideways mounted '35-up box working out? any bumpsteer issues?
  16. TexasSpeed
    TexasSpeed
    from Texas
    I may have a spare T top spring leaf laying around if you still need one.. I'll look tonight.
  17. Deadelvis2000
    Deadelvis2000
    from Austin, TX
    Anderson,
    I've got an exploded t rear spring in the shop. You're welcome to take a few leaves if you need 'em. Shoot a PM.
  18. steel rebel
    steel rebel
    You do have an eye Anderson. I see you have stepped back, way back and looked/starred at your roadster's profile. You'll be surprised how an inch up in back will change/improve the look. The engine will visually look almost perfectly level.
    Post more profile photo's when you do it.
    I too love the look of your roadster.
    Gary
    brad2v likes this.
  19. falcongeorge
    falcongeorge
    from BC
    That's the answer I expected...;) You see the same thing on probably 60% of the early 50s built hot rods you look at. Contrary to modern, history revisionist hubris, those guys weren't all a bunch of total retards...;)
    I still remember what Jake said in R&C about his first midnight drive in the restored Niekamp car...
    volvobrynk and brad2v like this.
  20. Equipped28
    Equipped28
    They are the best steering boxes I have one in mine that's converted to put the pitman arm down!
  21. orangeamcs
    orangeamcs
    What steering box is on it again?
  22. TexasSpeed
    TexasSpeed
    from Texas
    If you haven't already taken up Elvis' offer, I can dis***emble this for you if the top leaf is the one you're looking for.
  23. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    @Anderson wow man... thats crazy- you're gonna have to call that car the "twizzler" (-: (-:
    touring20 likes this.
  24. falcongeorge
    falcongeorge
    from BC
    Man, that's kinda scary. I am doing a '39 convert (probably 1200lbs heavier than your car) with a pretty healthy 324 (4 94's, ported heads, 10.5-11/1, solid cam) and a side-shift cad coupled to a shortened torque tube, man if yours will pretzel one at 1800/2000lbs ish, whats mine gonna do to one at 3200lbs?...:eek:
    RoddyB34, Runnin shine and volvobrynk like this.
  25. Six Ball
    Six Ball
    from Nevada
    Oh Lord guide and protect us. We've been eating brisket for breakfast.
    Wow! Thats a closed driveline? Made of toilet paper tubes? I've broken a lot of old Ford stuff behind stout engines but I've never done that. It'll make a nice floor lamp stand.
  26. volvobrynk
    volvobrynk
    from Denmark
    I've seen the same thing with a stock 1935 Ford truck fireengine. It ****s.
    But other then that you did a great job!
    I looks good, and if you can take you one hand of the steering wheel, all is well in the handling department[emoji4][emoji106]
    Your friends got som nice cars too.
    It's beyond me why anybody what's to call there firm for ***.
    I know a guy over here who called is firm for Max Motor service, and that's the Danish name for Launchpad McQuark, the guy from a cartoon series who crash most every time he lands. He didn't get much work, and a lot of laughter.
    That's beside the point, keep at it, and post plenty of pics!
  27. Six Ball
    Six Ball
    from Nevada
    Sometimes it's hard to understand just how much work a particular piece is doing until it lets go. Someone once explained that the closed drive line system just pulls the car around by the motor mounts. I would have thought an axle key, U-joint, or gear would have gone before the tube.
  28. Jungle Jalopy
    Jungle Jalopy
    Wow. The car car turned out great. Great fab skills and a keen eye.
  29. RoddyB34
    RoddyB34
    I was thinking my model A driveshaft might not hold up but that looks like exhaust tube,,,,,in regards to your original brake conversion that you didn't use what stopped you from using it because the backing plate part looked pretty good,,,I would like to do that with original drums,,,
  30. rod1
    rod1
    Such a *****in build..Just wish there wasn't so many Xs for photos...
