Advices for home made top on a roadster?
Discussion in 'The Hokey Ass Message Board' started by staleg, Jul 15, 2013.
  1. staleg
    staleg
    My 34 Roadster is close to road legal, and I'm starting to think about making a nice and convenient top on it. As I see it, there are two ways: A carson top, or a foldable convertibe top.
    A foldable top would be most convenient, but this is an all new area for me, and I'm not sure where to start.
    My budget si limited, so buying some custom fitted top is out of the question.
    And since I have a home made Duval windshield, and the bodyplate between the seats and the rumble lid is home made as well, I guess that roule out many standard fit solutions.
    What I'm thinking of is to buy for example a MG Midget Austin convertible frame for cheap like this one:
    http://www.ebay.com/itm/181176335629?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
    And modify it until it fits my car and then cover it with canvas. What do you think?
  2. Pete1
    Pete1
    from Wa.
    I made a top for an A roadster once. I found a guy that had one I liked the look of and took some measurements. I bent the bows up from 3/4 steel tubing, made the header from a piece of alder. While mocking it up I just d****d an old sheet over it to get an idea where I was going. After I had the shape, I took the car with bows on to an upholstery shop and had them sew up a cover with a plastic window in the back. It folded up just like an original.
  3. da34guy
    da34guy
    Built this 1 outta 1/2 round tube in less than 2 hrs,
    whittled a header outta oak,
    took to trim shop and had covered
    Less than a days work and $500 buckaroos
  4. I'm using a Midget hood frame on my 27T - it needs cutting about and narrowing. I thought about making it folding but the geometry is beyond me. I'm going to make a Carson style roof from it.
  5. F&J
    F&J
    I saw two of those english tops at a local swap, $25 each asking. I looked at them several times that weekend for my 32 cabriolet/coupster....and since I had made a complete folding top for a 2dr convertible sedan, I knew it would be trauma trying to chop/or shorten an existing top, and still have it fold in a neat pile.
    And, get the styling correct would be a job.
    There are several threads on what you want by hambers. Just like was just posted here, or folding versions....all made from conduit.
    My advice is buy some hand bendable material just to experiment with, to see if you can get the folding areas to work like you need, and still have a good style when you d**** some cloth over it. I find stuff at the local s**** recycle place for cheap.
    If you get a working pattern, then do stronger conduit.
  6. prefect20
    prefect20
    from scotland
  7. 33sporttruck
    33sporttruck
  8. Retrorod
    Retrorod
    We made this one on Flower's T roadster. It isn't that hard.
    This one has almost 8 years and a zillion miles on it
  9. staleg
    staleg
    Thanks for the advices and a lot of inspiration!
  10. RICK R 44
    RICK R 44
    used M G B frame on my 32. Had to widen and lengthen it. made it removable by taking out 4 screws, but seldom take it off, usually just fold it down for top down driving. p m me if you want more info or pics
  11. Anderson
    Anderson
    mike bowling likes this.
  12. staleg
    staleg
    When the frame is ready, do you make up the fabric yourself, or du you pay someone else to do it?
  13. chinarus
    chinarus
    from Georgia
    Theres a top iron frame kit on ebay for less than 300 that might work:
    Search 1932 FORD TOP IRON KIT
    Early Austin Healey Sprite(1961 to 65) frames were simpler and designed to store in the trunk and should be easy to modify:
    Search item 350836556494
  14. Anderson
    Anderson
    I had mine upholstered by someone I knew and it was a lot nicer than I could have done.
  15. 36cab
    36cab
    I bought a mid 70's MG top frame on egay for $25 for my chopped 36 Ford cabriolet. I had to widen it 10" and lengthen it 18". I also wanted the top to fold down in the well behind the seat and be completely hidden by the tonneau cover when it was down. I had to hinge the last 4" of the 18" extension to allow it to fold down small enough. Once it folded down small enough to fit in the well, I played with the location / height of the cross bows to get the side profile that I wanted. I used white paper taped to the top bows to help visualize the profile.
    When I was satisfied with the profile, my brother, who used to work on an auto upholstery shop, d****d junk material on it as a practice top and fastened it with duct tape and wire ties. We then folded the top up and down a few times to make sure the fabric would fold correctly with the bows.
    My brother used the practice top fabric for patterns and cut and sewed up the real top out of white material. I took a lot of photos and may start a new step-by-step thread on how we built it.
  16. wowwy
    wowwy
    from california
    36cab.....Please show how you did this. I need idea's for my project.
  17. mrquickwhip
    mrquickwhip
    Staleg and wowwy....you both have pm,s.....hopefully it will help you.....bob in glasgow
  18. wicarnut
    wicarnut
    As a former roadster owner (8 years) Definatley make yourself a folding top, that fits in trunk to carry with car. I had a carson style bolt on and it does not do you any good in garage or motel room when weather surprizes you. It looks like have recieved some good ideas on how to. Good Luck! John
  19. HOTRODPRIMER
    HOTRODPRIMER
    My roadster never had a top,,man did I get wet a lot but I never shrank! :D HRP
    dana barlow likes this.
  20. 117harv
    117harv
  21. 325w
    325w
    HRP, you didn't shrink but your hair faded!
  22. Gary Addcox
    Gary Addcox
    That's a good one, HRP. I talked to several roadster drivers at the LSRU in April and was surprised to find many had NO tops. Several from Cal. and at least one from Maryland. 1500 to 2000 miles with no tops. Now, that's ********.
  23. Pewsplace
    Pewsplace
    I made the one on my 33 roadster using 3/4 steel tubing and an electrical conduit bender. Lots of work but inexpensive ( under $50). The top material in our area runs about $1500 which is split $600 material and $900 labor. Make your own.
    Here is mine with a Duvall windshield. The shape was determined using a plywood jig.
    Here is the final profile which looks like a speedster to me and that is what I was after. The top does not fold.
  24. 29AVEE8
    29AVEE8
    Pewsplace.
    That is the best proportioned top on a '33 I have ever seen.
  25. Hemi325
    Hemi325
    from Boerne, TX
    Staleg,
    Shoot me your email and I'll put you in touch with a friend who has a top maybe for sale.
    Steve
    ssteers323@gmail.com
    Boerne, TX
  26. falcongeorge
    falcongeorge
    from BC
    Didn't Dana just do a thread on this? And pewsplace, yes that top is pretty damned nice, good job, nice eye.
  27. falcongeorge
    falcongeorge
    from BC
