1952-59 Ford 1955 gas tank in a 54
Discussion in 'Off Topic Hot Rods & Customs' started by k5mog, Jul 28, 2015.
  1. k5mog
    k5mog
    Jeff suggested I post some photos of an installed 55 tank in my 54. You can see the filler tube exit the body at a slight different angle, also you can see it's larger and the straps have to be extended. The tank was installed without any modifications. IMG_0513.JPG IMG_0514.JPG IMG_0514.JPG
    Rui and 59Bisquik like this.
  2. chopd top
    chopd top
    from Florida
    I've always wondered if it would work. Thanks for posting!
  3. JeffB2
    JeffB2
    from Phoenix,AZ
    THANKS!! I'll post a link to this in the "FAQ Sticky file" :D
  4. Dos Cincos
    Dos Cincos
    Out of curiosity, would tank straps from a 55 have worked or are the 54 straps different on the ends that mount to the car?
  5. HOTRODPRIMER
    HOTRODPRIMER
  6. k5mog
    k5mog
    The straps I used were for a 55 tank, it's the position of the attachment points. A person
    could use a bolt coupler and some all thread and use the straps without welding on some
    extensions. I just had some extra pieces and used them. The tank I used came from
    Bob Drake and has provision for a in tank fuel pump, which they also sell.
  7. JeffB2
    JeffB2
    from Phoenix,AZ
    chopd top likes this.
  8. 54sunliner
    54sunliner
    what a money saver, I like it
  9. ajracing9
    ajracing9
    I am doing this swap right now but I'm tapping in a return for efi....my question is do you open a bigger hole in the trunk floor for access to the sending unit? And where did you run your vent tube?
    54 Mercruiser likes this.
  10. JeffB2
    JeffB2
    from Phoenix,AZ
  11. Texas57
    Texas57
    I would think you definetly want access to that sending unit. My '57 is different, but similar. I needed to enlarge/add my oem sending unit hole to also have access to my in-tank fuel pump. I chose to enlarge the opening. On the '57's the vent tube goes along the inside of the trunk and exits above the licence plate. I used 1/4" copper plumbing tubing for the run and connected it with rubber fuel lines and clamps.
  12. ajracing9
    ajracing9
    Thanks Jeff that's a great read! And Texas 57 that sounds like what I'll have to do. The sending unit is at least 6 inches off. Out of curiously where did you put your return? There's no clearance on the top side of the tank to the trunk floor.
  13. buymeamerc
    buymeamerc
    from s.c.,usa
    I don't get where you have to extend the straps, my new(55) tank is in, put longer bolts in and still the tank "floppy" in the hole" ???
  14. buymeamerc
    buymeamerc
    from s.c.,usa
    Sending unit almost lines up with the original hole. it's still "back"(towards front of car) only lacks about 3 inches from lining up...???
    JeffB2 likes this.
