1952-59 Ford Need help with molding clips
Discussion in 'Off Topic Hot Rods & Customs' started by k5mog, Jul 28, 2015.
  1. k5mog
    k5mog
    On the front fender there are to 6 positions for moulding clips 2 of these I can't use
    a bolt on clip. This is the only place down the whole side I'm unable to reach the nut.
    I hope someone knows of a press in clip that will work, or the ford part number
    for the clips used on the front fender. I couldn't find any part numbers on my CD.
  2. dodg66440
    dodg66440
    Should be able to find a press in clip at any auto parts store that sells body repair and paint supplies.
  3. Texas57
    Texas57
    ditto what Dodg said...I got all mine at an auto paint supply house. On the '57's all the round holes were the bolt-ins, all the square ones were the snap-ins. I prefer the nylon clips when I can find them. Don't forget the dab of caulking on each hole under the clips to seal it off from water leaks.
  4. k5mog
    k5mog
    There is not a shop here that sells molding clips. It's a 60 mile trip to get them so I was hoping to order them on line, just wasn't sure of part number.
  5. HOTRODPRIMER
    HOTRODPRIMER
    I've had great success with aftermarket ****erfly clips,you can usually find them at auto parts houses.
    You should take your trim with you,they are available in several different sizes and these are all I used when putting the trim back on the wagon.HRP
  6. bobss396
    bobss396
    Check with Jeff at Restoration Specialties. He has some real obscure trim clips. If you don't see it on the site, call him.
  7. Texas57
    Texas57
  8. mikhett
    mikhett
    from jackson nj
    I have used the "****erfly clips " on my 62 galaxy the ones they sell that look like OEM clips do not work.Sometimes you have to IMPROVISE! I got them at RESTORATION SPECIALTIES WINBAR,PA
  9. chopd top
    chopd top
    from Florida
  10. bobss396
    bobss396
    He has an eBay store too and answered a couple of questions that I had.
  11. k5mog
    k5mog
    I've solved my molding clip problems, thanks for the reply, guys.
  12. HOTRODPRIMER
    HOTRODPRIMER
    Good deal. HRP
