......every couple of minutes. Have to log in before I can even finish reading a thread. Using an iPad. Had to log in again to even post this!!!
Did you hit the remember me box ? If not, try that. Depends on your carrier, depends on your signal........ some Apps are a issue and not suer freindly depending on what program you are using and have to use your PC.
I have been having this issue for a long time now. I check stay logged in and no difference. Good luck
No issues with the app on an iPhone. Laptop is not a problem....Actually the app on the iPad works...just unable to stay logged in on the regular HAMB site, including the OFC and Fordbarn.
I was having a similar issue after I upgraded the software in my phone, I logged off, cleared the cache, logged back in and the phone asked if it should remember the p***word, opt yes always. Seems to be working fine now, quicker and stays logged in.
I'm having the same problems, I'll look at the suggestions, but I'm wondering if there is a setting to allow a time period to keep you logged in. I'm on a PC and I'm logged out automatically every few minutes.
I've been knocked off 3 times today,I cleared everything,checked the keep me logged and and everything seems to be ok now. HRP
my pc's work fine, no issues never used the app, use my phone straight like a pc still a bit slow but haven't been timed out for a while
iPad......lap top ok. Tried posting a new thread using the regular website and was bounced 3 times using the iPad and app
I've personally found........ I pads and laptops just don't work worth a **** sometimes. I've NEVER had a problem with a PC I work with a IPad with work and a Smartphone with work and they kick me off now and then and don't work worth a **** sometimes. It is what it is fellas...... iPads and smartphones are inconsistence so knowing that when it doubt....PC ........ and I've NEVER had it kick me off.
