1930 Ford Coupe Project
Discussion in 'The Hokey Ass Message Board' started by BenLeBlanc, Dec 5, 2014.
  1. general gow
    general gow
    MODERATOR
    Oh cool. Look at that.
    I still contend that for a first attempt at building a car, starting with a good original frame is the way to go.
    BenLeBlanc, volvobrynk and patmanta like this.
  2. general gow
    general gow
    MODERATOR
    And if Bens gonna use a banger, the aftermarket crossmber lacks the trough for front engine mount.
    patmanta likes this.
  3. patmanta
    patmanta
    from Woburn, MA
    I keep sending him CL ads for flatheads though ;)
  4. BenLeBlanc
    BenLeBlanc
    I will follow your advice. I am going to find a good frame; I have an ad up on the cl***ifieds for a frame both here and on fordbarn.
    A man got back to me at fordbarn with an ok frame at a higher price and about a hundred miles away, so I held off.
    Meanwhile mr. Bowling has been helping me and has been on the search. First one was a wee expensive and had some work that was still needed to it crossmember wise, so I am still in the hunt.
    EDIT: been re-reading the thread and I am sorry for the ****ter-brained plans going on. I guess I am just going through a novice cycle as in 'make it work' and then 'just buy it new' and finally 'O ****, those people on the hamb do make sense sometimes and I can get an original frame that is better than mine for a whole lot less than a new one'.
    So, apologies extended to you all. I will try to make a real 'build' thread from now on as in me doing the building more than the stupid planning. Thanks for all of the patience though!
  5. BenLeBlanc
    BenLeBlanc
    On lighter news, I love my speed blaster...
    ImageUploadedByH.A.M.B.1437440459.236374.jpg ImageUploadedByH.A.M.B.1437440479.970774.jpg ImageUploadedByH.A.M.B.1437440508.904410.jpg
    Ppg dp90lf with the 401 activator and medium temp reducer along with hf spray gun tomorrow morning once I set up my 'booth'
    Edit:
    Set up my booth and it came out great. But now it is already too hot for my reducer. Paint tomorrow morning.
    ImageUploadedByH.A.M.B.1437481232.348499.jpg ImageUploadedByH.A.M.B.1437481253.913686.jpg
    patmanta and volvobrynk like this.
  6. patmanta
    patmanta
    from Woburn, MA
    Fill us in on this Speed Blaster!
    EDIT:
    One of these things???
    volvobrynk likes this.
  7. BenLeBlanc
    BenLeBlanc
    Yup. Gets the job done for me. Can get bad rust off, but since I got mol***es, I can put the piece in there and then I get to use less media.
    Anyway, laid paint this morning. IMHO, the wheels look really cool after the paint. Everything else also looks nice...
    patmanta, volvobrynk and AHotRod like this.
  8. wheeldog57
    wheeldog57
    Looking sporty Ben. Hope to see you at Candia Sunday
  9. BenLeBlanc
    BenLeBlanc
    Will be there.
    I hope to start getting a lot done now that I am out of work for the summer. I was on a six month co op that had me working ~50 hrs a week. Now I get to spend the money...
    The front spring was super easy. Too easy. Put on my flip flops after...
    Now these are tough! One came out good. I smashed the threads on the other one, but I had the c***elated nut on there and it was ripping threads off! Decided I had to save at least one part, so I will try to straighten the threads soon. Definitely makes you feel tough after you take these out!
  10. wheeldog57
    wheeldog57
    Whoah! I had to get a friend with a torch to get mine apart- tough guy. The tire on that orange wheel, you have two of those? I need tires 16in
  11. BenLeBlanc
    BenLeBlanc
    I do have another orange. The red is actually a 15 inch I picked up at candia because it holds air and wheels around good. The orange other one don't hold air and has flat spots. Tire is a Mohawk? Or something, mike bowling said he had the same treads...
    Btw, that three pound hammer earned its stripes...
    Anyway, having a problem with this ******. The bearing must have rust in it or some grit; don't turn good at all! Need a wrench to turn it. So I have the torque tube off, but I cannot take the shaft out! Ideas???
    (I oiled the shaft and scotch brited some surface rust away. Good thing I took it apart!)
  12. waxhead
    waxhead
    from West Oz
    I'm glad to see that you have decided to go with an original Model A frame. It makes the most sense to me, given what you have planned for the car. Good luck with the build.
  13. BenLeBlanc
    BenLeBlanc
    Yup, correct, and thanks.
    Now on to how it is, I have made my decisions on the build for how it is to be done. I am going to keep it unchanneled, as I believe the right way to channel the car would be to have an integrated floor without box reinforcement; which would require the use of a bead roller; a 16 gauge one would run a grand. Would be sick; but not for this build. Once I get one under my belt maybe.
    So, that brookville floor actually cost the same as materials, so I will get that once I get the drivetrain finished. That will also sure up the body alignment process. I will keep the splash aprons on the car and chop once I feel like it; as I want to drive it one day!
    Still hunting for a frame, a local man named Clyde is on the lookout for me. I need tips to get the driveshaft out, because those bearings are bad.
    And to end on a high note, here is my truck all loaded to go to candia. A ton of junk going cheap to just give me more space! Some will be free at the end of the day.
    Edit: just wanted to add that I was able to free up the bearing with a torch, penetrating oil, and a blow gun. Lubed with bearing grease and works like a champ.
    And I just wanted to thank you guys for the help, and I hope that this is the first rid of many, so that is why I am taking the route I am, just to get it on the road. I think that a hotrodder back in the day my age would do the same modifications to their car as my build will show. Thanks!
    norms30a likes this.
  14. BenLeBlanc
    BenLeBlanc
    Another shiny byproduct from about three hours of sanding... Ends and intricate spots to be gotten by blasting.
    Now onto the swap meet. Nice to see everyone, but didn't move anything. Kinda sobering I guess as I saw person after person walk by chuckling at the rust... But I guess it is what it is; as I brought only stuff I no longer need.
    Tomorrow I move onto the front end as the rear is done; excluding brakes.
  15. BenLeBlanc
    BenLeBlanc
    Kinda a one sided conversation going on here, but here is the ultimate video of my frame. Covers everything you could ask.
    I was just doing some time figuring out and if I bought a frame, it would be September at least before I got a rolling ch***is. Now, I just want to make sure that you guys think this frame is roached, as I put some money into it. Look at code 504 boxer plates and tell me if those could maybe save me.
  16. patman
    patman
    I'm ***uming you have seen this frame for sale, no connection to the seller, no idea if is what you need or if it's any better than the one you have, but...seems close enough to you to be worth checking out.
    http://nh.craigslist.org/pts/5120338439.html
    volvobrynk and norms30a like this.
  17. patmanta
    patmanta
    from Woburn, MA
    Man, you gotta start posting stills and not just video.
    Bring that thing by tomorrow and we'll go over it if you want. I can show you where the Woburn Metal Supermarket is too.
  18. CrazyUncleHarry
    CrazyUncleHarry
    That NH frame is Roachy....
    I need to talk with General Gow, but we might be able to help on the frame front.
    Keep moving forward!
  19. BenLeBlanc
    BenLeBlanc
    I am going to visit pat because from what I am seeing, the new frames will need more work that the one I already have. If I can use 504 boxing rails, I would rather do that, but if it is toast, it's toast.
    Only reason I did the video was so that I could get everything. I did the squareness tests as well as the full frame review. I understand the handiness of stills, but i believe I covered a lot more in stills than I could of in photos.
  20. BenLeBlanc
    BenLeBlanc
    I was only at pat's house for a quick look at each other's project and then this happened...
  21. patmanta
    patmanta
    from Woburn, MA
    Yeah, grabbed my neighbor, Paul and had at it today!
    volvobrynk and BenLeBlanc like this.
  22. volvobrynk
    volvobrynk
    from Denmark
    Does this mean that patmanta did your Tardel style kick up, and you are running you frame, or did he find you a frame, and did the kick up?
    Loks good!!
  23. BenLeBlanc
    BenLeBlanc
    Well, it has some meat on it in some spots, and it will definitely work with my boxing plates; no need to run 504 plates. He did the kickup with his portaband, as I only have an angle grinder and the portaband gives a great finish. We marked it out to be 4 inches in so that hopefully body mounts will remain the same-ish.
    Look at what I made this morning for it...
    norms30a, patmanta and volvobrynk like this.
  24. patmanta
    patmanta
    from Woburn, MA
    Nice! Now you're cookin!
    Where do the holes on your boxing plates land?
  25. mike bowling
    mike bowling
    Wheelbase 103 1/2" C front X member to C rear X member, and make sure you do diagonals!!! With that, everything will line up as stock. You will have to modify your sub frame for the kick, no big deal.
  26. BenLeBlanc
    BenLeBlanc
    I took a look today and figured that I can run that kind of piece shown above for any real length from two, as shown, to maybe four inches. That will allow me to get around the hole issue. Still debating leveling the rear.
    And to mike, good to know! That must be a horizontal measurement. I will have to run a plumb bob or like to the floor and measure that.
    And to you all, just wanted to ask what this meant; inside the torque tube behind the bearing. Love finding this kinda stuff...
  27. mike bowling
    mike bowling
    I just put bolts up through the spring locater pin hole; also works for the diagonals- radiator holes in front, body mounting holes on outside "ears" of the rear X member. Keep in mind with the diagonals, if there's a 1/4 " difference, it only takes an 1/8 inch to correct it- when you gain on one dimension you loose the same amount on the other. Balance, Gr***hopper.
  28. patmanta
    patmanta
    from Woburn, MA
    We checked it laterally from the center crossmember and diagonally once we found good holes. The first ones we tried were a quarter off from each other!
    I only put 2 tacks on there so it'll be easier to move if need be.
  29. BenLeBlanc
    BenLeBlanc
    Bought front brakes today. Can someone tell me what is up with this kingpin? Only bought the drums setup. Just trying to make it work...
    Here is what the rear end looks like. P***enger radius rod is not cooperating.
  30. patmanta
    patmanta
    from Woburn, MA
    What do you mean about the kingpin? Looks like a kingpin to me.
    Try taking the rods off and switching them to the other side.
