Technical 1931 Pontiac Coupe
Discussion in 'Traditional Hot Rods' started by Chris Lie, Jul 29, 2015.
  1. Chris Lie
    Chris Lie
    Hi
    I m new to this forum and I m living in Norway.
    I ve just bought a 1931 Pontiac Coupe and I was hoping to do some chopping, lowering and maybe channeling. The plan is power it with a 303 Olds Rocket I have in my garage.
    Apparently Pontiac parts for lowering is not that easy to find. Does anyone have some ideas for where to buy a dropped front axle or any other lowering tips.
    Thank you.
    volvobrynk likes this.
  2. scrap metal 48
    scrap metal 48
    Well, I won't LIE to you and you can't LIE around when building a hot rod, but you probably will have to adapt a Ford dropped axle front end to your Pontiac.. Welcome to the hamb and show us some pics of your coupe...
    Chris Lie likes this.
  3. TFoch
    TFoch
  4. bostonhemi
    bostonhemi
    Hello. Can't wait to see the 31.
  5. volvobrynk
    volvobrynk
    from Denmark
    Pictures or it never happened!! [emoji41][emoji111]️
    I would talk to this guy:
    http://www.droppedaxles.com/index.html
    He can drop yours.
    I most confess going to a M2 would be just as silly to me as a ford front end!
    With or without fenders, but a dropped front axle always looks good, and is available. and with a tape measure, it's possible to find replacement. A new spring can give you more drop, and better spring, if you need em.
    And with some shock and brake fixing, it should handle and feel good, maybe be as good or better as a Chevy AD truck!
  6. Texas Webb
    Texas Webb
    How complete is it? they are a nice car,ie: the grill is cool.And welcome from Texas.
  7. Chris Lie
    Chris Lie
    Thanks.
    I ve been doing some searching and measuring today and it looks like I can use front axles from 47-53 Chevy pickup.
    Actually my father bought this 31 coup and have just got it home from oversea.
    But he also bought a 1932 Oldsmobile. He has a lot of other cars, and now it became one to many.
    That's why I am buying his 31 Pontiac Coupe. But before I buy this coupe I have to make sure that it will be possible to build it like I want to. Therefore, I m doing some research :)
    I will se if I can get some pictures in a couple of days.
    I am also working on my 1941 Oldsmobile and my new garage, so unfortunately I will not start on the Pontiac until Olds is running and my garage is ready.
  8. Mendon Matt
    Mendon Matt
    I do like the Pontiac choice...:)
  9. Jeff34
    Jeff34
    Where are you in Norway? I was just in Oslo and Hamer in May. Any pics of the coupe?
  10. Chris Lie
    Chris Lie
    Here comes pictures :) It is a good projekt.
  11. Chris Lie
    Chris Lie
    Jeff. I live in Stavanger. South west cost og Norway.
  12. Tn. Trash
    Tn. Trash
    Nice looking Pontiac, not something you see too often.
    Best of luck with the build.
  13. TFoch
    TFoch
    That's a great looking Pontiac! Good luck with your project and keep us updated.
  14. volvobrynk
    volvobrynk
    from Denmark
    Just curios.
    Is the 31 Pontiac with hydraulic brakes?
    That looks mint! Very nice car!!
    If it's anything like the Chevy it's a fine automobile.
    Does it run 5 or 6 bolt circle? Do yo plan to run it as is first?
  15. Jalopy Joker
    Jalopy Joker
    nice ride to start with - have you built a modified car before?
  16. 28 ponti
    28 ponti
    Wow! Nice Pontiac. Like all GM cars of that vintage it has a wood understructure in the body. So it is a bit more difficult to chop the top than a Ford. Also, I have lowered Chevy front ends by using a Speedway 6 inch dropped axle and their 49-54 Chevy spindle combination. I mounted the axle between the spring and the frame. But I had to notch the frame a little and cut the bottom off the front cross member and move it up so the axle has room to move. Or you can do as already mentioned... replace the front cross member with a Ford member, remove the original front springs and mount the front spring and axle as a Ford. Ralph
  17. rtomss
    rtomss
    Without having to buy new parts I would think having the front axle dropped while removing a few springs and dearching the rears would be the way to go.
  18. Chris Lie
    Chris Lie
    It does not have hydraulic brakes. I will convert to hydraulic brakes of some kind.
    I don t know if it has 5 or 6 bolt circle jet.
  19. Chris Lie
    Chris Lie
    Thanks again for all your suggestions and recommendations.
    I realize that I am not able to handle all your suggestions until I have got the car home in my owne garage and can look under it while I am reading your suggestion.
    I am settling with the fact that it will be possible to lower it somehow, now that I know that someone can drop my original axle, if I don t get anyting else to fit, and I have decided to buy the 31 coupe. But I need to sell the 61 C-10 to give room for the 31 coupe since my new garage is not finished jet.
    When I start the work on the Pontiac I will start a new project treat and we can catch up there.
    Again - Thank you all so much.
  20. kidcampbell71
    kidcampbell71
    Nice car man ... yes indeed.
  21. Verbal Kint
    Verbal Kint
    from Washington
    Very clean coupe, can't be many of those out there.
  22. ct1932ford
    ct1932ford
    Looks nice the way it is! Go slow and enjoy the build.
  23. olgraybeard
    olgraybeard
    3" chop would look good....Pontiac's rule
  24. Welcome to HAMB from Minnesota, wishing the best on your build, I'll be watching.
  25. 31 pontiac
    31 pontiac
    welcome to hamb i have a 31 pont also that is being worked on i will try and post some pictures but kind of dumb with computers. DSCN3743.JPG DSCN3739.JPG DSCN3721.JPG DSCN3732.JPG DSCN3735.JPG
    TFoch and B Bay Barn like this.
  26. Chris Lie
    Chris Lie
    Thank you!!
    What type of front suspesion did you use?
  27. Chris Lie
    Chris Lie
    Almost ready for inspection. Hoping to get plates on it this easter. Then I can start the real work.
    Sent from my SM-G920F using The H.A.M.B. mobile app
    TFoch likes this.
  28. sloppy jalopies
    sloppy jalopies
    nice car... only ever seen one of those, a parts car for a '31 poncho cabbie restoration...
  29. Chris Lie
    Chris Lie
    [​IMG][​IMG][​IMG][​IMG]
    Car is finished for now. Now I need to build my new garage before I start building it.
    Lissjos likes this.
