Technical best bang for the buck
Discussion in 'The Hokey Ass Message Board' started by porknbeaner, Jul 31, 2015.
  1. Engine gurus and none engine gurus alike are more then welcome to chime in. Please don't call someone an *** hat unless they really are one, lack of knowledge does not an *** hat make.
    Ok so here's the deal, a couple of recent threads have brought me to this thread. One is a thread asking what the new cheapest engine is going to be and the other was a statement about a set of headers.
    Not to name anyone or single anyone out just to make a statement one of the fellas the other day said that a set of headers were going to cost him more then *5K to have built. I read it and immediately began to clench if you know what I mean.
    We used to say that the single mod that brought the best bang for the buck was a set of headers. Now any single mod that runs over a grand in my mind is not much bang for the buck unless it adds like a bazillion HP to the current stock motor.
    so tell me fellas what single engine mod brings the best bang for the buck these days. Lets try and keep it to mods one may have done before the age of the computer. OK?
    I'll start off I am big on port work, always have been. It is something that all it takes is time even if all that it amounts to is blending the bowls which isn't good for a lot but any whistle head can blend the bowls, and it is almost free.
    Next?
    *in that price range not an exact quote
  2. trollst
    trollst
    Old timers know, it's any basic thing. First, dual exhaust, may not be faster, but sounds faster, next 4 barrel, goes faster, next some timing work or ignition upgrade for bragging rights, then the almighty rumpy cam to make it a handful at stop lights.
    volvobrynk likes this.
  3. malcolm1943
    malcolm1943
    My choice would be a streetable cam, along with exhaust headers.
  4. squirrel
    Depends what engine you're starting with. Might even be a set of rearend gears....
  5. oldrelics
    oldrelics
    from Calgary
    My dad always told me compression was very crucial to making good power, so I'll go with a good set of pistons/rings.
  6. Saxon
    Saxon
    from MN
    Flathead - mill the heads.
    flatheadpete likes this.
  7. Turning the air cleaner lid upside down :)
    It's a case by case study with applicable wisdom.
    If the engine/drivetrain package is already in perfect compromise, balance and tune - ANY single modification will make things worse.
    So a study needs to be made as to where the package is lacking. Then you can easily get the best bang for the buck. Knowing where the factory choked up its grip on EPA stuff will help.
    Most every modification needs another to maximize its potential.
  8. Hmmmmn I would have thought that tune up may have been mentioned. I know that for a motorhead a tune up is a given but it is cheap and easy to do and many a dyeing engine has been saved with a simple tune up. LOL
    Ok just being an *** hat here. :D
    W may actually build a hot rod here if we try. ;)
  9. flatheadpete
    flatheadpete
    from Burton, MI
    ...I was gonna say a set of hi compression heads on a Flatty. After that, headers and exhaust.
  10. steel rebel
    steel rebel
    ****** I'd just advance the timing and put better gas in it. Cheap and fast. Hot coil and a bigger Carburetor. Maybe some hotter plugs.
    Gary
  11. Yeah, if you're starting with something that has some power that can be a whole different ball game compared to a grocery-getter. But generally speaking, having 'good' exhaust is the foundation for anything that comes after. But I will say that the cost of stroker kits these days makes them a pretty attractive power-adder; there's no subs***ute for cubic inches...
    Ratrod_Rhysie and volvobrynk like this.
  12. HOTRODPRIMER
    HOTRODPRIMER
    I think a good set of heads will improve a engine's performance as well as anything,,and 5 K for a set of headers is more money than sense...IMHO. HRP
  13. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    Well since part of the criteria is BEFORE the age of computers, I guess signing onto The HAMB is out. Besides that, depending on the engine you are starting with, a supercharger, granted usually more than a $1k, can make a huge difference on the right engine and setup. I guess the biggest bang for the buck would be a good book on building and modifying engines. Knowing the right part for the right application (and how to correctly set it up) is worth a lot more than just throwing parts at something and hoping it works in my opinion.
  14. 69fury
    69fury
    from Topeka
    if you are asking for the best bang for buck with NO restrictions on type of engine or other prerequisites is Nitrous Oxide- period. Been used since WWII so yes it's traditional.... -rick
  15. Saxon
    Saxon
    from MN
    But for the cost of "new heads" vs milling. Milling is much cheaper. Bang for buck. Hey Im cheap! :)
    Then I might go with a 2x2 intake...
  16. My buddy ran some nitrous and blew his engine to pieces. That Wasn't so cheap but man it was a big increase till she let go.
    kiwijeff and volvobrynk like this.
  17. They say there's no replacement for displacement. However there are subs***utions - boost and RPM. There's plenty of 4clyinder honda's that will spank a healthy high stepping V8 and take its lunch money.
    chessterd5 likes this.
  18. J. A. Miller
    J. A. Miller
    from Central NY
    I thought this was a thread about callgirls.
  19. falcongeorge
    falcongeorge
    from BC
    ***uming you are starting with a 4 bbl motor, curve, headers and gear, in that order. well, yea, and nitrous, but I don't roll that way.
  20. seb fontana
    seb fontana
    from ct
    Don't laugh, real example..I put a bigger exhaust on my Crosley and can now top one particular hill 7 mph faster than before.:D
  21. chessterd5
    chessterd5
    from u.s.a.
    You got to respect fast no matter how you get there
  22. Here's a story from my past. I bought a new 427 FE in '63. It ran about 14 sec flat bone stock with 3.50 rear end first run out of the box. There was a guy with a bone stock '57 Buick that was running 14's. The story was that he had sawed the intake and exhaust manifolds in half and completely polished them inside and welded them back together. I ***ume he polished the heads too. Can't verify if this is true or not, but it would be quite noteworthy if it is.
  23. kidcampbell71
    kidcampbell71
    PnB ... I skipped over everything ..... in the hopes you blow the dust off of the high compression winder engine hiding in your garage. Almost free counts higher then 100 octane gas tank refills. At least for a little while. Imagine the smile you will have twisting frame with that thing at 7000 rpm.
  24. falcongeorge
    falcongeorge
    from BC
    Nothing "low buck" about that...now crack *****s, that's a whole nother matter...
    Ratrod_Rhysie likes this.
  25. Got phone numbers?
  26. JOECOOL
    JOECOOL
    ****** ,one thing I tell people all the time is its all about the combination. I wish I had a buck for every speed part I've seen bolted on and the car runs worse. It all has to work together. Compression, carb size, converter, gears, and the most abused miss applied part ,the camshaft. The wrong choice on any of these will waste the money spent on all the other parts. Just my opinion, I could be wrong.
    X38, cptn60, brad2v and 5 others like this.
  27. saltflats
    saltflats
    from Missouri
    How about some cold air intake
    I did the poor mans cowl induction on my heap (you know adjusted the hood so the back set up)made a pan to seal to the bottom of the hood and open to the back and my car picked up .20 seconds in the quarter.
    falcongeorge likes this.
  28. 69fury
    69fury
    from Topeka
    so it's the best bang for the buck for the NEXT guy that put in a smaller pill! Just like a 6-71 that gets a different pulley size next time around. :) -rick
  29. Rusty O'Toole
    Rusty O'Toole
    I was going to say tuning. Stock car racers proved in the fifties, you could get 10% to 25% more HP than the factory, using all stock parts, just by careful tuning and possibly a few subtle mods.
    If I was building a mild street engine on a budget I would go basically stock with a good cam, intake, single 4 barrel and headers. And if I had to skimp even harder, would use a stock 4 barrel manifold and used carb.
  30. Jimmy2car
    Jimmy2car
    from No. Cal
    I'm right there with Joecool. It is always the combination.
    Me. I like gearing, but that often is not cheap or easy.
    I'm also a fan of Overdrives, in that you can have much bettrer
    acceleration and good highway manners.
    Jim
