Shop Press Tooling
Discussion in 'The Hokey Ass Message Board' started by lawman, Jan 3, 2012.
  1. Dyce
    Dyce
    I think the die set you have pictured would work if you made a slice for each louver instead of using the die to shear. Then the dies will self center and just slide down the cut. I would also find a way to bolt the lower bed solid to the uprights.
  2. budd
    budd
    i bet you can buy louver tooling for an ironworker, i worked in a plant that had 5 CNC turret punch presses and some of that old tooling would be perfect, i have to go by there on Monday i think i'll ask to go through the junk tooling.
  3. realkustom51
    realkustom51
    The Ironworkers I work with mostly are GEKA. The distributor is Comeq in Baltimore, Maryland. Here is what it looks like. Works best with the deeper throat units.
  4. realkustom51
    realkustom51
    Just scored another freebie tool. Its a old Unitool MNC33 Corner Notcher (.125 cap., 3"x3"). Upper body is the upper blade. Lower blades are just one sided but still sharp. Weighs 35lbs. Seems to work pretty good.
  5. lawman
    lawman
    Keep your finger's out of it !!!!!!! LOL
  6. T Hudson
    T Hudson
    This made from way too heavy duty stock, but every piece was s****. Except for the valve springs it was all sourced at the recycle yard. $30 in s**** weight.
  7. Bcap55
    Bcap55
    from PA, USA
    I always find that the upper table elevation holes are too high and the next set of holes are too low. I needed a way to locate the table half way between these holes. Instead of drilling new holes between, I made these spacers from 2" square tube and some pipe. Slip them over the cross pins and you can locate the table half way between the existing holes. This can save a lot of needless pumping on the jack handle.
      97.5 KB
      99.5 KB
      95.3 KB
    lothiandon1940 and Hnstray like this.
  8. rusty rocket
    rusty rocket
    Kool thread. So many great Ideas out there.
  9. lawman
    lawman
    Thats "Neat" !!!!!!!
  10. I picked up a 20 ton press for $150 this weekend off Craigslist. Stopped at Northeren Tool on the way home for a $119 air over hydraulic jack to replace the hand pumper. For some reason, they sell the maual press for $300, an air over jack is only $119, but a press with air over already on it is $1200! Anyway, I saved some money even if I have to do a little modifying. The press I got has bent bent under the jack, and a piece of channel "welded" in there. I'll need to take this thing apart and probably add some bracing to it.
  11. lawman
    lawman
    Richard, Keep us up on what you did to change the press. I have been thinking of doing the same thing of "Air Over".
  12. Sure, I'll take some pictures while I do it.
  13. lawman
    lawman
  14. Chairmnofthboard
    Chairmnofthboard
    from So Cal
    Wow! Great work, thank's for sharing the ideas.
  15. willymakeit
    willymakeit
    Oh hell . Now I've got more tools I want to make. Thanks for posting.
  16. lawman
    lawman
  17. lawman
    lawman
    I'm going to make me some of these !!! Great Idea.
  18. vh41
    vh41
    from Sydney
    This is a cool thread
    I'm making a male die and hope to use a lower rubber pad.
    The first pic is a hand made patch panel. The bottom pic is a die I hope to use to make the same patch panel with a press.
  19. Hutch built
    Hutch built
    Here are some pictures of how I made a press brake with some s**** steel I had laying around. I used a mill in some operations but a grinder with a steady hand could probably pull it off.[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Sent from my SPH-L720T using The H.A.M.B. mobile app
    54reno, charleyw, lawman and 6 others like this.
  20. lawman
    lawman
    Very nice work !
