Technical 62 t bird drag link removal
Discussion in 'The Hokey Ass Message Board' started by chainsaw, Aug 2, 2015.
  1. chainsaw
    chainsaw
    Trying to remove drag link with pickle fork. The rod seams to be lifting up but the bolt through the pitman arm is not moving. I have about 1/2 inch play between the bar and the pitman arm but the bolt has not moved, am I somehow pulling the bolt out of the bar or should I keep on pounding on it? Thanks.
  2. 2racer
    2racer
    whack the big part of of the drag link end from each side, then go back to the pickle fork
  3. gatz
    gatz
    Yep, it's pulling out of the socket.
    As 2racer said, and if space allows, it helps a great deal to use a "bucking" hammer/sledge or heavy chunk of steel on the opposite side of that end while whacking it, to get it loose.
    Don't be afraid to lay into it.
  4. FrozenMerc
    FrozenMerc
    If all else fails.....Heat helps
  5. chainsaw
    chainsaw
    All I have is a propane torch, dont think it will get hot enough. Also very little room to get any leverage on the small sledge I have. Going to borrow a tie rod puller tomorrow but any other ideas ? I'm afraid if I keep at it with the pickle fork it will pull the stud out of the socket then Id really be screwed.
  6. gatz
    gatz
    if it has 1/2" movement, it should be replaced
  7. 2racer
    2racer
    go to youtube and look at some of the videos people have posted on removing tierod ends and pitman arms, you might get some useful tips
  8. chainsaw
    chainsaw
    Rented a tie rod puller. Tightened the puller down and hit it with bfh and it finally popped loose. Now on to the other side.
  9. This ^^^^^ about 99% of the time.
