have a 53 olds super 88 and want to change my original rims and put modern ones with radial tires. can anyone let me know what 70's or 80's tire rims i can use. thnks for the help
My 60 has 5x5 I am using Cady 60 wires. Rad well work on your 53 rims they have a lip seal. I think your bolt pattern is 5x5 ? same as big GM.
Stolen list don't sue me if any bad info also back spacing probably an issue with some wheels like jeep Note: 5x5 bolt pattern is also 5x127mm BUICK LE SABRE, RIVIERA 64-87 BUICK Riviera 64-78 BUICK Roadmaster 91-98 BUICK ROADMASTER, ESTATE WAGON 90-96 CADILLAC Calais 68-85 CADILLAC Deville 68-84 CADILLAC Fleetwood 68-84, 86-98 CADILLAC Seville 77-79 CHEVROLET 1/2 TON BLAZER, JIMMY, SUB FULL SIZE 2X4 71-91 CHEVROLET 1/2 TON TRUCK ALL MODELS 2X4 67-87 CHEVROLET 1/2 TON TRUCK ALL MODELS 2X4 88-98 CHEVROLET 1500 ½ Ton P/U (2WD) 88-98 CHEVROLET ALL 5-LUG HALF TON TRUCKS up to 99 CHEVROLET ASTRO/SAFARI 85-on CHEVROLET Caprice 88-98 CHEVROLET CAPRICE CL***IC 90-97 CHEVROLET IMPALA SS 94-99 CHEVROLET Suburban 1500 (2WD) 88-98 CHEVROLET TAHOE, YUKON 2X4 92-99 CHEVROLET VAN G-SERIES 1/2 TON 71-96 CHEVROLET WAGONS & HD models 55-95 CHRYSLER Imperial 67-70 FORD FULL SIZE (CUSTOM, GALAXIE, T-BIRD) 73-78 FORD Custom 73-78 FORD Galaxie 73-78 FORD LTD 73-78 FORD Thunderbird 72-76 GMC 1500 ½ Ton P/U (2WD) 88-98 GMC Safari Van 1500 85-2002 GMC Suburban 1500 (2WD) 92-98 GMC Van 1500 88-99 GMC Yukon (2WD) 95-98 JEEP Grand Cherokee ALL MODELS 99-06 LINCOLN CONTINENTAL, MARK III 73-79 LINCOLN Versailles 73-77 MERCURY COUGAR 73-78 MERCURY Grand Marquis 73-78 MERCURY Marauder 73-78 MERCURY Meteor 73-78 MERCURY Montclair 73-78 MERCURY Park Lane 73-78 OLDSMOBILE ALL FULL SIZE 88, 98, RWD (W/403 ENG.) 64-92
I've got a 53 olds. Perfect car problem is the motor is shot and the guy I bought it from already has a 350 small block in it. Only mocked up. Anyone ever put a 350 in a 53?
