Technical Wiring american auto to column switc
Discussion in 'The Hokey Ass Message Board' started by RCM59, Aug 3, 2015.
  1. RCM59
    RCM59
    Now before you guys hammer me...I have not done much wiring so, go easy. American American Autowiring kit... highway 15 to a speedway to a speedway turn signal switch. This what I know....
    AA15 lights/what it does Indicator Switch
    yellow lr dk blue
    dk green rr blk
    dk blue rf lt blue
    lt blue lf green
    white stop switch orange
    purple key switch hot red? labled flasher L
    Brwn hazard/not in play
    blk horn relay/not in play
    labeled flasher p yellow?
    I have led rear lights and regular front indicators l&r. No parking lights, by choice. No hazards. I put an led flasher in. Now, all work but, not properly. Brakes lights work, running lights work. Problem indicators shut brake light off depending on right or left selected. Flasher buzzes but, does not flash light. What am I missing?
    I also know there are other threads, that I have a hard time following.
    Thanks
  2. RCM59
    RCM59
    Sorry for the site edit, it was laid out more spreadout.
    Thanks again....
  3. d2_willys
    d2_willys
    from Kansas
    Does the brake light opposite the turn signal selected go off? Or does the opposite brake light stay lit and the turn signal selected go off? The other thing that needs to be mentioned is that the flasher needs to be grounded if it has a pigtail.
  4. HOTRODPRIMER
    HOTRODPRIMER
    Just keep checking for continuity. HRP
  5. Kiwi 4d
    Kiwi 4d
  6. bct
    bct
    Not enough amp draw from led lights will cause flasher problems. Change your flasher to l.e.d. friendly or if possible put in 1157 to test.
  7. RCM59
    RCM59
    NO. With brakes applied, Select right...right brake light goes off. Flasher which is LED type with extra wire starts buzzing.
  8. RCM59
    RCM59
    Thanks Gents...
  9. d2_willys
    d2_willys
    from Kansas
    The turn signal switch is doing exactly what it is suppose to do, switch to turn signal circuitry. With that clarified, your flasher is the culprit. If it has a pigtail, the pigtail MUST be grounded.
