Projects My 1928, 5-Window Coupe, build thread. Thanks for playing along.
Discussion in 'The Hokey Ass Message Board' started by ChoppingBlockCustoms, Aug 4, 2015.
  1. Howdy guys; I've been posting questions here, bits there - figured I should settle down and commit to a lengthy build thread - for your lunch time internet merriment, as well as for my early failing memory ;-). Hell, I'm only 38..! Enough blabbering...
    My Father-in-law came across this body while deer hunting on his buddies property, that he just bought. His friend said that I am more then welcome to get it, or it's going to the s****per. These are the picture that my FIL text messaged me:
    What you DON'T see in those pictures is the entire frame, with some brackets, etc, still buried in the ground. Needless to say, I came unprepared. To dig that is...
    But I wasn't leaving without the coupe! We luckily found an old broken shovel in a nearby barn and was able to dig it free and eventually pull it out with the truck.
    This is after we had it loaded and was on our way home:
    This was back in March of 2012. I got it home and it then sat for about 2-1/2 years while I finished up home projects, etc.
  2. Fast forward a couple of years. Got the coupe into the shop and actually cleaned it up some to get a better feel of the condition. Cleaning it up helped visual matters a lot:
    Over all, it was pretty solid, with the Right hand side being the worst off. But it's coming totally apart anyway to fix rust issues at the seams, etc.
  3. drifters cc
    drifters cc
    Awesome looking coupe and a heck of a cool starting point. Back from the dead!
    It is August now and from the look of the trees and the mention of deer hunting it would seem you could have 8 months of progress on that thing by now. Are you holding out on all of us?
    lothiandon1940 likes this.
  4. The moving forward plan is pretty simple... I'm using ASC '32 Ford rails - that will be fully boxed with a blown 331 Hemi.
    Starting off with these rails:
    The rails have been jigged and pinched to fit the 28/29 subrails.
  5. Deconstruction of the body continued... Found some more rusty issues, etc. A few stress cracks. Nothing that can't be fixed... IMG_0338.JPG
    I tend to get busy and "forget" to do***ent steps... The entire body is taken apart, down to the individual panels that I will take and sandblast at some point.
    The next point was to make a subrail jig based off of this original one. This one is too far gone to repair when I can buy an entirely new subrail replacement.
    davweed34 likes this.
  6. PKap
    PKap
    from Alberta
    Love that line" pretty simple, 32 rails and blown.331 hemi"
    Awesome
  7. After the body was off, I squared the old sub-rails up the best I could and fashioned a small jig table with appropriate jig markers, etc. I tried to verify original subrail dimensions from the internet, etc and didn't have a bunch of luck though. So I forged ahead with my own taken measurements.
    New rails are layed into place and clamped tight to draw them out:
    Checking fitment with the stock Cowl/A pillar dimensions. It lined up really well:
    Seems like a nice, correct, fit.
    Surprisingly, the new rear cross member seemed to fit spot on as well.
  8. Installing the cross braces was a little more tedious that I thought. I fab'd the cross braces and attachment points exactly like Ford did on the originals...
    Which involved pie cutting, stair stepping and rewelding the cross rails to follow the contours of the subrail stampings.
    I elected to not do rivets, but rosette welded to "resemble" rivets. When it's painted you will never know the difference. The subrails did get welded on the bottoms too for added strength. But I didn't want to get them too rigid either.
    Check for squareness..... check!
    And for ****s-n-giggles, I overlaid the orginal subrails to compare the two - to check my work and the accuracy of the repo rails...
    And the finished subrails:
    volvobrynk, kidcampbell71 and hipster like this.
  9. hipster
    hipster
    nice! Looking forward to seeing the results!
  10. Which leads me to this point...
    Anyone that has experimented with fitting 28/29 bodies to '32 rails knows the fitting issues. They don't just "fit". The subrails need to be modified. LUCKILY I have a brand new, solid subrail starting point... to cut up. Ugh.
    Granted this is just chucked up there, you can easily see the issues... model A's are flat... '32's... not so much.
  11. After lots, and lots of research on how other people where fitting these, I came up, with what appears, to be an ORIGINAL idea on how to fit the subrails to the frame rails...
    Quick under view shot showing the spacing:
    So I decided to just rejig the back rails and reangle them to fit, up, INSIDE, of the subrails.
    But in order to get the body to drop down, first I had to bob the frame rails off on the rear roughly 16":
    If anyone needs the rear frame extensions, let me know. They'll be going in the cl***ifieds soon!
    Next up was pie cutting and re-angling and welding up the rear of the rails to not swoop out so much.
    You can see the outward swoop. these needed to be straight and parallel with the rear subrails:
    Rear rail corrected and finished. I also added a small relief step to allow the subrail to sit down flat on the rails. Keep in mind these rails will be fully boxed as well.
    Both sides are stepped: (hey, look - there is my model A body... on the floor!)
    Now that the frame is ready to receive the subrails, the subs needed to be sliced and diced...
    Basically I cut open the entire top of the rear rails like a tin can to allow them to drop over the frame rails
    Here the subrail is "test" fitted to the frame:
    And it fits.
    Quick view of the step area showing the subrail fitting:
    This inside portion will require a but more fab work to curve up and maintain the same drop lip.
    Then came the fun part of reinforcing the rear subrail sections. The outside part was easy.
    And that's basically where I am as of right now.
  12. Stutz
    Stutz
    Well... I am subscribing out of pure envy. Excellent stuff.
    ChoppingBlockCustoms likes this.
  13. Man, finally, between work and home ****, I get some time to wrap up the subrails. I had to finish the inside yet for the channeled area.
    First step was to make the new inner floor structure lip. I decided to try my hand at hammer forming on a wooden buck to form the new piece:
    ImageUploadedByH.A.M.B.1445745625.996174.jpg ImageUploadedByH.A.M.B.1445745656.032502.jpg ImageUploadedByH.A.M.B.1445745684.821380.jpg
    First p*** at the roughed out piece:
    It actually turned out pretty damn good. Initial fit up was close, just needed a little tweaking and some t******* after the stretching.
    As a refresher, this is what I'm altering:
  14. Skip ahead a few hours and no pictures later...
    Both sides are basically done. I didn't have any fine discs to metal finish it, so that will be later this week.
    ImageUploadedByH.A.M.B.1445746156.533551.jpg ImageUploadedByH.A.M.B.1445746190.979535.jpg ImageUploadedByH.A.M.B.1445746234.298295.jpg
    And to illustrate the kick up from a traditional model A subrail - which is totally flat:
    ImageUploadedByH.A.M.B.1445746323.465086.jpg ImageUploadedByH.A.M.B.1445746363.049444.jpg ImageUploadedByH.A.M.B.1445746410.976013.jpg
  15. very nice work! subscribed
  16. Started on boxing in the frame rails yesterday. This is going to take a while. Lots of trial and error fittings.
    The frame rail lips are pretty wave, as evident in the pictures. So I had to heat and persuade the lip with a hammer & dolly to smooth them out.
    volvobrynk and kidcampbell71 like this.
  17. RainierHooker
    RainierHooker
    from Tacoma, WA
    Very cool. Looking forward to seeing where this goes.
  18. kidcampbell71
    kidcampbell71
    Damn ...... novel as hell approach on the sub rails. Ingenuity at its finest ! Please continue ......
  19. Johnnee D.
    Johnnee D.
    love it... keep up the good work...
  20. Did a little more rail boxing.
    It ****s.
    cadillacoffin likes this.
  21. Pete
    Pete
    Excellent step by steps.
  22. rusty1
    rusty1
    ...this is a great 'how-to' thread, very nice work, kudu's to you for saving that model A.
  23. I'm watching, a great thread!!
  24. wheeldog57
    wheeldog57
    Great post. Boxing the rails UGH! Seems like miles and miles of weld, right? You will need them strong if you are putting a hemi bullet though
  25. It totally does. But what is really making me mad right now is I tried taking a short cut and ordered boxing plates from Speedway motors #Speedway and they aren't even close to fitting in the middle sections. So I have to pony up and go by some other sheet plate and now am making my own... Which I should have done from the start.
  26. wheeldog57
    wheeldog57
    That blows, I work on power plants so I have "access" to plate. I just go in the metal dumpster. It is a ****-ton of work cutting, fitting, cutting, fitting, welding, grinding, welding, grinding, blah blah blah. But, I love doing it, hahaha
  27. general gow
    general gow
    MODERATOR
    really neat solution to the subframe kickup over the frame rails. looking forward to watching this come together.
  28. artificer64
    artificer64
    from maine
    Fine job, excellent work.
