Hot Rods 331 Hemi - Water Plumbing (what are all these holes?)
Discussion in 'The Hokey Ass Message Board' started by CHEN, Aug 5, 2015.
  1. CHEN
    CHEN
    Hey Guys, I'm trying to get a better grasp of whats going on with this motor. I think I have a pretty good idea, but still kinda confused about a few things; hopefully you guys can help. I've added some pictures with numbers so its clear what i'm talking about.
    So there are 8 holes / ports in question:
    1 - Gonna run this into a Crossover to connect to #2 and #5 with a thermostat in the crossover. Aiming to have the same setup as B. B***
    2 - See #1
    3 - Return from Heater Core. Not planning to run a heater core; what should I do with this?
    4 - This hole is threaded and I took out the fitting that was in there; also no idea what this is
    5 - See #1
    6 - Originally a feed for Heater Core. Not running a heater core; what should I do with this?
    7- No idea where this coolant is supposed to go to.
    8- Threaded hole for Oil Pressure Gauge
    Any help is greatly appreciated! I've been learning so much from you guys. Also, I want to get a manual so I don't have to ask these seemingly dumb questions; any good recommendations on a book?
  2. daliant
    daliant
    #8 is oil for the oil pressure gauge.
    #3 and #6 are for the heater core.
    #1 and #2 are usually built into the stock manifold, yours is obviously aftermarket.
    #5 would go to the thermostat housing on a stock manifold (thermostat byp*** hose)
    #4 is just another location for the heater
    stillrunners likes this.
  3. CHEN
    CHEN
    Thanks!
    I didn't plan on running a heater core; will there be cooling problems if I don't run one? Do you know what guys usually do with all the heater holes (#3, 6, 7?, and 4) if they aren't running one?
  4. daliant
    daliant
    Just plug em if your not running a heater.
  5. CHEN
    CHEN
    Thanks! Appreciate the help. So I'm just gonna plug up 3,4,6, & 7. Simple enough :)
