Technical Why do side windows break?
Discussion in 'The Hokey Ass Message Board' started by David Gersic, Aug 5, 2015.
  1. David Gersic
    David Gersic
    from DeKalb, IL
    Walking around car shows and cruise nights, it was always puzzling to me why so many of the cars have one or more cracked windows. Nice cars, too, not just old rusty beaters. And it seems like it's always the back ones.
    Now it's happened to me. I noticed today that my left rear window in my '37 has a crack. It wasn't there last week. I've rolled it down and up a few times (original regulators), and driven a few miles, but nothing I'd expect to crack a window.
    Why?
  2. squirrel
    Getting the channels and fuzzies in just right, and getting it all adjusted, and having the gl*** cut properly, are all challenging things to do. Especially on a 70-80 year old car.
    lothiandon1940 likes this.
  3. 2racer
    2racer
    they get broken the same way my socks get stolen out of the dryer
  4. unkledaddy
    unkledaddy
    It's because the window gl*** in the old cars is laminated. Laminated gl*** is much weaker and cracks very easily because it can't be tempered.
    lothiandon1940 and loudbang like this.
  5. Drive'em
    Drive'em
    Really!
    2racer likes this.
  6. dana barlow
    dana barlow
    from Miami Fla.
    Something likely put a load on them,the trick is finding what? Often its the tracks they slide in have lost padding or become out of line from a track bracket broken letting them flex
  7. unkledaddy
    unkledaddy
    In newer cars the windshields are laminated to keep objects from coming through them, where side windows and back gl***es are tempered to allow you to break-out in case of emergency.
    Most auto gl*** shops don't have tempering equipment so they only use laminated gl*** when doing vintage cars.
  8. trollst
    trollst
    Yes really, in our old cars the gl*** is cut from laminated gl***, don't like slamming doors or movement, tends to crack.
  9. chopolds
    chopolds
    from howell, nj
    That's why I get my side gl*** from a place that can do them in tempered. Especially on chopped cars!
    Pinstriper40 and lothiandon1940 like this.
  10. bobss396
    bobss396
    Not sure when they started laminating side gl*** but the OG door gl*** in my Ford was laminated and cracked.
    Now I have new gl***, all the vent seals, channels and fuzzies. I'm good for another 56 years...
  11. HOTRODPRIMER
    HOTRODPRIMER
    Many times it can be traced to where a rivet or screw interferes with the window channels and fuzzys or the gl*** is in a bind.
    Slamming a door can also play a part in a cracked window.HRP
  12. lothiandon1940
    lothiandon1940
    I always watch as kids (and unfortunately) uninformed adults slam the living daylights out of car doors. Call me old school but I would have gotten a severe scolding when I was a kid if I SLAMMED a car door shut. I get annoyed with people who ride with me, get out, turn away, and slam my door. It calls for a bit of "counseling".
  13. beebing
    beebing
    from milwaukee
    I'm an ex-Autogl*** guy.
    Side laminated gl*** usually cracks because either a screw or rivet is sticking out of the fuzzy, a small chip along the edge of the gl***, or gl*** not set right in the channel.
    I use to cut laminate for Case tractors and other heavy equipment manufacturers. They were strict on having perfect, chip-free gl***...because to them chip=crack.
    When I put new chip-free laminate sidelites in, I made sure that I marked on the old gl*** the position where it's on channel for reference. That way I'm sure its not going to bind and have smooth operation.
    I never used rivets or screws for the fuzzies. Instead, I would pre fit, apply urethane on the door where fuzzy meets door. Then roll up window to hold fuzzy in place and let it sit overnight.
    Never had problems with cracks.
  14. low budget
    low budget
    from Central Ky
    Yeah, Non old car people automaticly think they need to slam the door on a old car, or maybe its just the adrenaline rush taking affect and causing a unrealized overpowering door slam after taking a awesome ride in a old car.
    clem, Kan Kustom and lothiandon1940 like this.
  15. swifty
    swifty
    My gl*** guy always does tempered gl*** for the doors and laminated for the fixed gl***. Avoids the problem of broken gl*** from slammed doors etc by the "uninformed"
  16. 325w
    325w
    Coupes been built since 96. No broken gl*** yet. The slamming of doors is a big killer. Screws are another. I use a tiny wood screw that sinks deep into the fuzzy. No cracks in several years of doing this.
  17. bobss396
    bobss396
    All of the gl*** channel and fuzzies on my Ford, the ones where it was not possible to staple or adhere the clips, I used countersunk head pop rivets. So I know they're below the surface and won't touch the gl***.
    I have one son, I finally broke him of his door-slamming habits. This was on my OT car, he got sick of me saying "don't slam the door!" when I dropped him off at the train station.
  18. squirrel
    Chevy started in the early 60s. 1961 was all laminated, 1965 was all tempered...somewhere in between, they made the change.
  19. Gman0046
    Gman0046
    lothiandon1940 has got it right. Non car people think you close the door on an old car as hard as you can.
    Gary
  20. 1934coupe
    1934coupe
    So true. My windshield on my OT 88 GMC cracked right down the middle just sitting in the driveway.
    Pat
  21. Then you get twist and shake that doesn't help much either.
    We were chatting about that exact thing last night, the engine we have in the T roadster twists the frame pretty good (even though the frame is boxed) well duh it went from the 15 or 20 HP that it had originally to 400 plus from the maybe 25 pound feet to 440+ :D
    Atwater Mike likes this.
  22. DDDenny
    Yea, many, many years of extreme hot and cold cycles, and door slam'n *****s.
  23. Truckedup
    Truckedup
    Modern vehicle doors have tight hinges and cushy weather strip acting like a shock absorber ..And yes laminated gl*** is pretty much just float gl*** so it cracks easily
  24. Bruce Lancaster
    Bruce Lancaster
    Another bunch of reasons I like roadsters.
  25. town sedan
    town sedan
    Thank you. That's good information. Slammed shut or just closed it really bugs me to see people shut a hard top door by the gl***. -Dave
  26. lothiandon1940
    lothiandon1940
    ...................That's true for the gl*** protection but, new cars are so tight you can blow out a speaker, especially if it's in the door by slamming it too hard, and never mind the annoying rattles it can cause.
  27. On a hot day you can blow the gl*** right out of them too. Seen it happen more then once.
    I have discovered a little trick about these old heaps that we drive. Lexan makes good side gl***. ;)
    its that damned cold air down the back of my neck that I don't like. You can thank my big sister for that. :D
    hey while I got your attention I got a couple of Bruce questions if you don't mind. Check your mail please?
  28. 30panel
    30panel
    Just go some new side gl*** for a cracked 1/4" laminated window. Shop recommended tempered when I pick them up I used a caliper to see if it was 1/4" it measured 6mm just a little thinner, they side in the fuzzes easier may be to loose. Shop said the don't make 1/4" tempered only 6mm.
    Any one know about this.
    Mike
  29. 6MM is inly .013678 less that 1/4. I wouldn't want crank clearances to be that much too loose but I wouldn't think that it would make that much difference on gl***.
    I am going to fathom a guess here, economical availability verses production. Maybe they make 1/4 but the shop you're dealing with can't get it or can't get it at a price they are willing to pay.
  30. unkledaddy
    unkledaddy
    The fuzzies should make up for that little difference by not crushing as much.
