What did #2 look like? Hard tell any difference from the pic. They both look good. There, that was pretty noncommittal.
I like 1 the best but for some reason in the picture you posted of number 2 galled up or not looks the most uniform
They both look good, nice stagger on the lines, you must have a nice setup. Back when I worked at a Bugatti restoration shop I got to do a lot of firewalls and dash panels. We would start with a buffed sheet of aluminum, had an alignment jig, and used a very course custom blended valve grinding compound with a pad in a hand drill. Great memories, Bob
I have a mini milling machine so it's easy to get them straight. But there are may ways to do it. Like 50% staggered, Left to right, Zig-Zag, overlapping. Just trying to get the best look is all.
OK, now I see the differance, I like #1 with the 50-50 stagger, like looking at a black & white tile floor, you see the even spacing. Number 3 has the swirls in a random pattern. Bob
No one would know the difference but you until you pointed it out and even then hard to discern. Great that you can do that yourself.
I like the one you used, I did my own on a drill press. Took close to 4hrs of standing but I love it.
My self I was thinking of #1 , but this look's nice, is the pattern 50/50 over lap ?? And did you use scotch bright or sand paper roll , what grit ?
I've used grinding bits, I believe from McMaster-Carr that are a rubber material imbeded with an abrasive. You can turn them down for different sizes
Gorgeous, yes please give us the down low on the technique, method and tools. I have read about many different ways to do it, but seeing these results and knowing just how you accomplished it would be great. I believe you about it being hours of hard work. You did a fine job sir.
To be honest I don't know. I have a grizzly mini milling machine and I just timed it 4 cranks turn 4 cranks turn and then for the next row I offset is by 2 turns then did 4 cranks again. Each row is also 4 cranks apart. I found a hard rubber rod that was just under 3/4" in my junk pile and I used 80 grit lapping compound. I coat the whole piece then just have at it. I take the compound off with WD-40 very gently as not to scratch it. I polished the part first (to almost a mirror). Polishing made a big difference in the way it came out. I also set the stops on the table so I started in the same place each time. Even though the part is tapered I treated it like it was square and just ran through the sequence till I came to the part and then started turning. This way they would all line up as if it were a solid piece and I cut it out after it was turned. You just have to be careful on the edges and try to use equal time and pressure. I hope this helps.
I'd say you nailed it. Looked into it when I joined up here in 09, and got the name of a stick that was popular, can't recall it now, but when I asked around where to get the stick, no one knew what I was talking about.
Jeff they are called Cratex sticks. Basically abrasive impregnated rubber. They come in all shapes and sizes. For me they were too expensive. Oh and thanks for the "Nailed it" feedback. This will probably be the only perfect part on the whole car...LOL
I like the way you left the center points exposed. It creates some different geometric patterns depending on how the light hits it.
I might not be able to tell much difference in the patterns, but the one you chose and completed looks excellent to me. I think engine turned stuff looks so cl***y.
Thanks everyone. It was a lot easier than I expected. Just very time consuming is all but well worth is in the end.
Just stole this off the Lets Talk Cycle Cars thread here on the HAMB, when you get real good you can do the whole body. Bob
I wanted to replicate the engine turn look of the original dash insert on our wagon when I added real world gauges,I love the look. HRP
I think it was engine turned, I know this one was, saw it at Hershey a few years ago. Every hood louver was turned as well. Bob http://farm4.static.flickr.com/3176/2613488659_ddc9788bcb.jpg
That's just insane. It would take a year to do all the panels. And then if it ever got wrecked you'd have to do that panel to match? Wow they had a lot of time on their hands back then.
