Projects 1950 Studebaker gasser
Discussion in 'Traditional Hot Rods' started by CGkidd, Sep 4, 2013.
  1. CGkidd
    CGkidd
    I am planning on it. Just going to take awhile. getting ready to retire from Active duty Coast Guard soon and need to join real world get a job and such. We are on our way home from Antarctica be home soon. I can't wait to get back to work on this. I have 120 days leave saved up so I plan on getting as much done on the g***er before hopefully getting a job. Man I haven't had to worry about finding a job in 24 years. I am nervous.
  2. D.N.D.
    D.N.D.
    Hi Eric
    What type of work did you have in the Guard, looking for the same thing back on the ground ?
    4 month's you could get your g***er pretty well along, i'am tuned in to see how you are doing
    G Don
  3. CGkidd
    CGkidd
    I am a electrician in the guard. Been busy settling back in. I am working on a set of heads for the engine which should flow better. Got to crawl under the body and finish prepping it for paint then mount it back on the frame.
  4. Paul
    Paul
    Editor
    Don't know what the transition would be like but commercial construction is booming in Seattle right now.
    I'd imagine you'd have to talk to the hall and take their tests to determine your level.
    All the halls are hurting for good hands right now, carpenters, labors, iron workers and operators, probably electricians too
  5. CGkidd
    CGkidd
    I have been checking into a couple shops. I have until September when i lose my active duty pay.
  6. Tyresmoke
    Tyresmoke
    from Norfork
    Hi Are you electronics radar radio or larger switch gear ??
  7. CGkidd
    CGkidd
    switch gear, control systems 460 mostly
  8. CGkidd
    CGkidd
    Well started fitting my Hilborn unit.
  9. CGkidd
    CGkidd
    Anyone have a aluminum timing cover they would sell?
  10. ALLSTEELWILLYS
    ALLSTEELWILLYS
    from TEXAS
  11. CGkidd
    CGkidd
    Started mocking the fuel pump.
  12. CGkidd
    CGkidd
    Well change 50 I am pulling the 4 speed. Just worked a deal with a gentleman for a B&M unblown compe***ion hydro with shifter all NOS never run. I will post pic when I can.
  13. Paul
    Paul
    Editor
    the one on craigslist?
    been watching that one myself..
  14. CGkidd
    CGkidd
    Turns out to be a friend of a friend so getting a good deal
  15. D.N.D.
    D.N.D.
    Hi Eric
    You sure you want to use the Hydro, as the un-blown cars ran quicker with a clutch
    The blown cars used them as the stick tran's would hold up with their power
    My Buddy Tom Larkin saw the light and took his out of his 37' B/g***er , put in a chevy 4 speed and picked up a tenth and a half
    Back then they had very little stall speed, and the clutch car could leave full tilt and it took a bit for the auto to get the rpm up and by then the clutch car was long gone
    Don
  16. CGkidd
    CGkidd
    I have heard that also. But the car will mostly see nostalgia drags and have fun with it. I think the cool factor of running a original B&M will make it worth it
    Bigcheese327 likes this.
  17. Paul
    Paul
    Editor
    can't deny the cool factor
    now get rid of that 8-3/4 rear and put an Olds back there
  18. 64 DODGE 440
    64 DODGE 440
    from so cal
    I'm with you on that Eric. Looking forward to seeing the beast run!
  19. CGkidd
    CGkidd
    Well picked up the shifter and worked a deal for the B&M hydro.
  20. Paul
    Paul
    Editor
    excellent!
    CGkidd likes this.
  21. 64 DODGE 440
    64 DODGE 440
    from so cal
    Art from an earlier time. Too cool!
  22. CGkidd
    CGkidd
    Anyone know the PN for the front seal in a Weiand timing cover to the olds engine?
  23. Jkustom
    Jkustom
  24. CGkidd
    CGkidd
    Well picked up the B&M yesterday. I got a stock crossmember also should help with making my rear mount
  25. CGkidd
    CGkidd
    Started mocking up my Weiand cover and got my stacks on the hilborn.
  26. Paul
    Paul
    Editor
    looking good Eric!
  27. Jimbo17
    Jimbo17
    I remember another Studebaker G***er from years ago names the "QUARTER HORSE"
    Jimbo
  28. loudbang
    This is getting better and better.
  29. CGkidd
    CGkidd
    1 step forward half mile back. Decided to pull the heads today and check everything for the last time since running the engine for the first time. Well good thing I did. Valves kissed the piston. Need to figure out what happened and start over. So bummed but glad I checked before firing it up with a heavy load. Almost tempted to pick up some 11-1 pistons anf have more valve relief cut In. When i started the build it was a street car with occasional strip so it was 10-1 compression. I have since gone to the hilborn injection and more strip with occasional street.
  30. Dog_Patch
    Dog_Patch
    Ouch! Wonder if that would mess up the valve ?
    CGkidd likes this.
