Art & Inspiration Ever have one of those days in the garage?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Aug 10, 2015.
  1. HOTRODPRIMER
    HOTRODPRIMER
    I just came in to grab a sandwich and to cool off.
    I had today off and planed to do a little cleaning up and some maintenance on the sedan.
    First I gathered up all the loose tools and cleared the work bench,no problem there and then I decided to move the old 9" Bronco rear axle that I recently purchased from a wrecking yard but I needed to remove the two leaf springs that the genius at the salvage yard cut with a fire wrench.
    I sprayed the nuts with PB blaster and started looking for my 1" deep well socket,no where to be found so I decided to use the zip wheel and cut the U bolts.
    I finally found my zip wheel and a brand new cutting wheel and within a few minutes one side was loose I started on the second side and the wheel came apart.
    Went to the cabinet where I keep the extra wheels and guess what...none there.
    So I'm making a list to go to the hardware store after lunch and hopefully by the end of the day I can say I accomplished something. HRP
  2. NashRodMan
    NashRodMan
    LOL...pretty much every time I enter the garage! I feel for ya!
    Lcats, 302GMC, patmanta and 1 other person like this.
  3. lothiandon1940
    lothiandon1940
    Some days you win, some days the garage wins.:D
  4. dirt t
    dirt t
    I have had the same experience.
  5. slowmotion
    slowmotion
    HRP I'm in the process of having one right now. Needed the hot wrench to heat a stubborn strut mount bolt. No acetylene of course. Off to NAPA I went...
  6. Jalopy Joker
    Jalopy Joker
    some days do not make it to the garage - remember or, see things in house or outside that only some "quick" attention and bingo the day is shot. watch out for those easy trips to the hardware store, or parts place - end up remembering that as long as out & about need to stop at other places for other stuff - yikes!
    nothing is easy
  7. 4thhorseman
    4thhorseman
    from SW Desert
    My wife knows this rant of mine all too well... When you have a job to do and your tools let you down. The socket wrench's guts come out, the drill bit snaps off or the drill motor dies, the last bit of welding wire is suddenly gone, the solar welding mask isn't charged up (doh!). Yup been there too many times.
  8. HOTRODPRIMER
    HOTRODPRIMER
    I didn't say anything about my torches because like you I already knew I was out of acetylene and the company I got my tanks from has gone out of business and the new company here in town refuse to fill them,they want me to buy or rent tanks from them.:mad: HRP
    lothiandon1940 and slowmotion like this.
  9. fergusonic
    fergusonic
    from Kokomo, In
    Don't run out of gas on the way to the Hardware store !!!
  10. 383deuce
    383deuce
    HRP that ****s that the new company will not fill your tanks. I bought mine in Kansas some years back and now live in Nebraska and do not have any problem filling them. WTF selling gas is selling gas.
    40fordtudor likes this.
  11. volvobrynk
    volvobrynk
    from Denmark
    Wasn't it dale Earnhardt who said; you win some, you wreck some.
    And that's how it's goes down for most of us. It's just a matter of how often you have those days lol.
  12. Deuced Up!
    Deuced Up!
    No that never happens to me. I NEVER MAKE A LIST! I just make about 20 trips to the hardware or parts store etc. LOL!
  13. patmanta
    patmanta
    from Woburn, MA
    I had a day that DID NOT go that way this weekend... until I stepped on a piece of metal with a big spike of cut off angle on it that I had cut off 3 hours earlier. It was almost a trip to the Emergency Room rather than the Hardware Store. I'm going to remind myself of that the next time I have to drop what I'm doing to go get a correct size drill bit or cutoff wheels (which I'm out of now too come to think of it, thanks!).
  14. RB35
    RB35
    Measure all the bolt lengths for the intake manifold and the front suspension to install ****on head bolts. Go to Robnet-a bolt store from tiny screws to bridge bolts and will sell only one bolt at a time if that's what you need. Got everything in 5/16ths, get home and ...... I needed 3/8's. About a 20 mile round trip.
    lothiandon1940 likes this.
  15. hotrodA
    hotrodA
    Sounds like a "normal" day to me. I've started claiming smaller victories, the FUBABS were winning. The one hour jobs were taking a day, and the one day jobs were taking a week. But I refuse to surrender.
  16. Verbal Kint
    Verbal Kint
    from Washington
    HRP,
    I'm still under the opinion that the worst day in the shop is better than the best day at work
    with the exception of patmanta's, but anything this side of an injury... I'd rather be in the shop
  17. slowmotion
    slowmotion
    Yep, never surrender. Sometimes ya gotta walk away from it & regroup. Usually helps. When I was a pup I'd work my way into a ****fit when a job sent sour. Dunno if the age/wisdom thing happened, but I'm a helluva lot mellower now. :D
  18. vert1940
    vert1940
    my zip wheel came apart and sent a piece across the garage dead square center int0 the door of the merc....I looked like a thermometer about to explode
  19. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    I could go on for days, but instead I'll just say 'You're not alone!'......
    volvobrynk likes this.
  20. patmanta
    patmanta
    from Woburn, MA
    I put on a fresh sock and limped back out there so I could get the cowl on the subframe I was working on so I could at least SEE what I got hurt for. I'd rather be there now with a hurt foot than at my desk with a sore ***!
  21. olcurmdgeon
    olcurmdgeon
    C'mon guys, your worst day in the shop sounds like Nirvana to a guy who no longer has a shop (garage) due to life's twists and turns.
    slack and patmanta like this.
  22. HOTRODPRIMER
    HOTRODPRIMER
    NO! :eek:,when did that happen?
    Both the sedan and the wagon are outside when I am grinding and cutting. HRP
  23. oldsjoe
    oldsjoe
    Yes sir, some day's by the time I get to the task I started to do, it's a week later! Joe
    patmanta likes this.
  24. pat59
    pat59
    Hey HRP then ya get back home take out one disc and go to put the rest away only to find the pack of twenty you couldn't find earlier. :)
  25. The37Kid
    The37Kid
    Knocked off early today, stopped by the cardboard dumpster in the shopping center for some boxes to ship the weekend sales. Two boxes just the right size sat all alone in an empty dumpster. Didn't want to loose my reading gl***es so I set them on the unopened lid while I fished the two boxes out. When I got home I wanted to check that auction site and the HAMB............were are my gl***es? Bob
  26. Gene Boul
    Gene Boul
    Gl***es gl***es gl***es! I either lose them or step on them or my buddy sits on them when he gets into the car. I take my gl***es off to work on my cars and I need about 6 pair to make one repair!!!
  27. HOTRODPRIMER
    HOTRODPRIMER
    Went to the hardware store and got 10 cut off wheels,hopefully I wont loose them before I get back to separating that axle from the junk springs. HRP
  28. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    The quickest way to find lost tools is to go buy a new one. The old ones are always front and center when you get back. And whatever you do, NEVER clean your garage! It'll be month's before you find anything.
    jetman and 2racer like this.
  29. HOTRODPRIMER
    HOTRODPRIMER
    I don't clean the shop to often but both my tool boxes were almost empty!
    Plus it's my turn to host the club meeting Thursday night and the guys need a place to sit. :rolleyes: HRP
  30. aaggie
    aaggie
    Every now and then when the planets align and the Moon is in phase you have a day that just makes you smile. No bugs landed in the wet paint and the Shop Vac hose doesn't come loose from the bead blaster or the hot slag from the torch doesn't burn the hoses. Just for that briefest of moments do you forget the normal.....
    clem and HOTRODPRIMER like this.
