  1. rooman
    rooman
    Snake out on his own in 1966 in the B & M Torkmaster car. The car was owned by B & M and Dave Zeuschel built the engines.This is the first paint job, by late summer it was candy red with silver accents. And contrary to popular legend he did run it all season with the Torkmaster drive line which was developed by the Spar brothers and Don Alderson.
    Roo
    Drewfus and hendelec like this.
  2. D.N.D.
    D.N.D.
    I believe as the story goes they had 3 brake calipers on each side trying to hold it on the line, cause it did not have much hi-stall in it and he had to leave early
    Then after getting back into a clutch car he red lighted till he got his leaving game back in order
  3. saltflats
    saltflats
    from Missouri
    Kinda looks like hes holding the brake in this shot.
  4. saltflats
    saltflats
    from Missouri
    Man look at the size of that fuel line.
  5. dmorago
    dmorago
    Ah, the fog and smog at the Beach
    tommyd likes this.
  6. rooman
    rooman
    I will have to ask him about that the next time that I talk to him.
    Roo
  7. Tom S. in Tn.
    Tom S. in Tn.
    Did this car use all 3 speeds?
    We talked and dreamed for years about a torque convertor hi-gear car.
    tommyd likes this.
  8. D.N.D.
    D.N.D.
    The TorqueMaster did not have 3 speeds , just one gear like a clutch car but had the convertor instead of a clutch
    You would have to push the car faster so the convertor would lock up, and then start to turn the engine over so the driver would check for oil pressure hit the gas petal to prime the injectors and then the on switch then out of gear in a short period of time
    There was a lever on the left side of the clutch can and you could heel & toe it to get it in & out of gear, so once the engine started you would kick it out of gear and hit the brakes hard and make the turn around - get lined up and kick it back in gear and pull up to the line ready to go
    So it was in gear when you were on the starting line and you hit the throttle and away it went but at lower rpm's till the tires got to smoking hard
    loudbang and tommyd like this.
  9. Tom S. in Tn.
    Tom S. in Tn.
    I had never seen this explained before.
    Still have to wonder if it might not be more successful with modern technology.
    Thanx; Tom S. in Tn.
  10. D.N.D.
    D.N.D.
    Hi Tom
    It was a good idea but with out a hi - stall convertor it was not as fast leaving the line as a clutch car was
    By the time it took to get the engine & tires up to rpm, the clutch car was long gone
  11. chase knight
    chase knight
    Jerry Gwynn on the tire.....
  12. chase knight
    chase knight
    Vance Hunt's "twin engine" top fuel car. Under AHRA, that would put them in a different class to run for Top Eliminator. Make one run for the class win (reducing the amount of runs required), and they would then run off against the single engine top fuel class winner. That loophole lasted for about one event. Regards, Chase
    hendelec likes this.
