Projects 56 Chevy 210 Hardtop Build
Discussion in 'The Hokey Ass Message Board' started by Smoothy, Aug 4, 2015.
  1. wow! great start to a nice project, thats going to be fun driving !
  2. Smoothy
    Smoothy
    Well today I managed to spend a whole lot of time thinking instead of doing. The only thing I managed to get done tonight was install a tube in between the frame rails. Tomorrow I will go ahead and remove the lower splash pan and make sure to take some pictures. Here is earlier today before I installed the tube between the rails.
  3. II FUNNY
    II FUNNY
    IMO I would leave the A arm suspension...a set of ball joint spacers and a taller spring will give you the stance most mid 60's tri-fives had...and if you get sick of it later you can change it easier than with an axle up front... ImageUploadedByH.A.M.B.1439437674.367611.jpg
    pivir123, AHotRod, powrshftr and 8 others like this.
  4. Smoothy
    Smoothy
    FUNNY, it's funny you say that. As my dad and I were looking at how to take the splash pan out he was doing some other investigating of his own to see why exactly my 56 sits up higher than his 57. Well he glanced at my a-arms and pointed out that the car actually already has ball joint spacers as well as bigger springs. I'll make sure to post some pictures sometime tomorrow
  5. Smoothy
    Smoothy
    So today I finished the tube bumper, let me know what you think. 20150813_201336.jpg 20150813_201326.jpg
    Also here are the pictures of the ball joint spacers/springs
  6. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    Looks good and I like the stance it has now , Put some elbow grease on those wheels and you will really start getting excited!! Larry
    Smoothy likes this.
  7. HUSSEY
    HUSSEY
    Great looking car, I like the rear radius wheel wells. I've seen tube axles installed on these while maintaining the stock front frame, that is not lopping it off and installing 2x4s.
    Smoothy likes this.
  8. loudbang
    Front end looks like we did them "back in the day"
    lawman and Smoothy like this.
  9. kidcampbell71
    kidcampbell71
    Very cool ! Good to see a '56 get played with. That one is very nice.
    Smoothy likes this.
  10. Smoothy
    Smoothy
    So I've decided to go with the slots that are already on the rear for right now and to go with something different on the front. I'm thinking a set of cragar s/s or gts. I have a set of each but am uncertain as to which would be more appropriate for my build. I also went ahead and polished one of the rear slots, didn't turn out great, but far better than what they were. 20150816_170044.jpg
  11. I'm thinking yourve got it figured out pretty well for a guy your age.
    I look forward to watching the progress.
    powrshftr and Smoothy like this.
  12. 2racer
    2racer
    Looks nice, you have to be careful with the backspacing on the front wheels or the tires will hit the upper control arms when you run ball joint spacers.
    loudbang and Smoothy like this.
  13. Smoothy
    Smoothy
    Thanks for the info, that's the kinda stuff that really helps out in the long run!
  14. Smoothy
    Smoothy
    Okay, I'm trying to find the rules that pertain to what cl*** you would figure your car to run in 1965, 66, or 67. I think it was some sort of formula that used your cars weight and cubic inches that decided what cl*** you ran. I could be wrong, does anyone else have any info on that subject?
  15. II FUNNY
    II FUNNY
    Here's is the NHRA weight breaks for the NA gas cl***es... ImageUploadedByH.A.M.B.1439861645.033047.jpg
    Smoothy likes this.
  16. Smoothy
    Smoothy
    Exactlt what I was after, greatly appricate it!
    timmy2times likes this.
  17. II FUNNY
    II FUNNY
    Smoothy likes this.
  18. Grandadeo
    Grandadeo
    My favorite example of a real deal trifive g***er that was dominate at Niagara drag strip in the mid '60s was Jim Zakia's 'red '55 Chevy. Google His name and a bunch of pictures will show up. And yes it had a straight front axle. Jim went on to race a '33 Willys coupe, an Anglia, and an Opel GT in various gas cl***es. Still races the Opel and has found and is restoring the Anglia and just turned 73. I'd try to post a pic of it but as you can see from my previous picture post of the E/G '56, I'm not very good at it.
    Lee
    Smoothy likes this.
  19. slammed
    slammed
    Spin the car to face the street/downhill on the driveway. Take a few pix for stance and measure from the lip of both front & rear fender to ground. Then add a 100-200 lbs or so in trunk. Take a few pix of the new stance & measure distances. Leave it be in the rear and now floor jack it at the crossmember and raise it an inch or so. Pix. Raise a bit more, pix.
  20. Smoothy
    Smoothy
    I know just what you're talking about. I've read about Jim and his cars before, his 55 was B-A-D. And Slammed, I may toy around with the stance a little, but I doubt it will change dramatically because I defintely like the way it is sitting level right now. However the car has airshocks so I believe if I let some pressure out that should lower the rear some.
  21. slammed
    slammed
    Nothing permeant. Only to see what this combo has hidden by changing each end slightly. For a bit of time & no money. And another mock up would be to max the rear shocks AND raise the front a few inches (floor jack) for that near Street Freak effect.
  22. II FUNNY
    II FUNNY
    ImageUploadedByH.A.M.B.1440073780.202043.jpg ImageUploadedByH.A.M.B.1440073795.692830.jpg
    This is just my two cents, but to me this car sits perfect.
  23. Gotgas
    Gotgas
    from DFW USA
    I love it, but IMO it deserves paint. It does have a perfect stance, wheels, and tires.
  24. brut4s
    brut4s
    I love it the way it sits. No paint needed.
    lawman likes this.
  25. Martin Harris
    Martin Harris
    I like where this project is headed. Seeing the car "as is" in grey primer immediately reminded me of the movie "Two Lane Blacktop".
    g***ers are cool right now, but many of them are cartoonish, so it would be great to see one done "era correct". You've got all the right ideas.
    I think you should keep the rear slotties permanently, they look great as they are.
    powrshftr, Smoothy and loudbang like this.
  26. low budget
    low budget
    from Central Ky
    Yeah, youve got ball joint spacers but judging from the space between the top aframe and the frame it doesnt look like you have bigger springs to actually raise it (you could have, its hard to tell from a pic)..on second glance, with a bump stop in place I doubt its raised.
    The original "idea" of ball joint spacers was to allow room for the car to come up in the front, on launch, shifting the weight to the back tires, dont really know if that helped at all but anyway........... with bigger springs also, you can raise the car in the front, Ive heard guys say to use 409 station wagon springs or some other kind of heavier springs???
    ...........tho it may look a little jinky heres what I used on a 55 I had a few years ago and it worked fine "for me".
    ............also I would turn the black walls out on those tires if I were gonna keep em, and yes like mentioned earlier you can only have around just over 2 inches of back space on your front wheels depending some on how wide your tires are.
    Smoothy likes this.
  27. Smoothy
    Smoothy
    Yessss! You hit the nail on the head with this one. This is exactly the stance I'm going for, and it doesn't look like I'm too far off at the moment. And Low Budget, I'm lead to believe that it's raised slightly at least. It sits about 3" higher than my dads 57 up front. I have heard of the station wagon springs being used to raise the car in the front, my dad and I actually looked into that for his car awhile back. As for the tires in the back, I've been wanting to thinking about getting the 28/12.50/15LT M&H Racemaster cheater slicks that are on Coker Tire website for an ungodly amount of money.
  28. Smoothy
    Smoothy
    It's been about a week or so since I've posted due to starting this semester of college cl***es, but during my time away from posting I've been doing some wiring on the car. I'm at the point where I'm trying to wire the headlights. What I've got left is running all the wiring from the firewall grommet to the headlamps. I believe it's called the ch***is harness. As this is my first wiring project I'm very unfamiliar with it all.
    As for the engine I've been thinking about building up the 350 that's in the car. Ive been wondering what kind of compression Im going to make from the 1972 195hp 350ci by putting 64cc chamber 462 double humps on and keeping the stock pistons. Im wanting something to run off of the pump so I figure this would be my best bet for the street/strip setup that I'm after.
  29. falcongeorge
    falcongeorge
    from BC
    So cool to see this car is alive, well, and pretty much intact. Man, I was SO in love with this thing in high school.
    Note: While the word "bracket" appears 6 times, and the phrase "street/strip", or "street machine" appear a couple of times, NOWHERE in this article does the word "g***er" appear. Back then, this was just the way tri-fives looked, and "Gas" was an NHRA cl***. The word "g***er" as it is used today didnt even exist in the hot rodders lexicon. Its so refreshing to go back to that unpretentious time when we could call cars what they actually were. I miss those days...:(
    PHR Sept. 74
  30. II FUNNY
    II FUNNY
    Looks like the term was around to me...
    Tman, timmy2times and powrshftr like this.
