Projects 32 Sedan Lakester roof chop
Discussion in 'The Hokey Ass Message Board' started by the metalsurgeon, Jul 16, 2014.
  1. DeLuxe 32
    DeLuxe 32
    Frame is pinched and bobbed, it uses a super flat Model A style crossmember. Spring will be reverse eyed, but over the axle not behind like Rolling Bones. Using split wishbones, with Houdaille shocks, not sure if they will be mounted inboard or not. Gary Maxwell (Blackboard Hotrods) is doing the ch***is.
  2. 383deuce
    383deuce
    Sounds very interesting and I sure would love seeing some photos when you get it done. I am building a bones style 3 window and frame, but doing the spring behind the axle like the bones do.
    Thanks for the reply.
  3. jeta12
    jeta12
    Hard to say anything different than everyone else.....Fantastic work!!!
    Thank you for taking the time to post.
  4. Mart
    Mart
    Don't know how I missed this thread! Fantastic job. Jon, I'm Rog W's friend from England, glad he told me to look for this build. It's an education.
    Mart.
    gonzo likes this.
  5. gonzo
    gonzo
    Now thats a funny avatar^^^^^^^^^^
  6. DeLuxe 32
    DeLuxe 32
    Cool, I'll keep an eye out for progress on your coupe...the "engineers" down here who do the licensing had kittens when I told them I wanted to weld the spring perches to the wishbones. They weren't completely convinced about split bones either .
  7. patterg2003
    patterg2003
    I have enjoyed & learned a lot from your threads. Thank you for sharing.
    Glenn
    the metalsurgeon likes this.
  8. PRIMER STUDIO
    PRIMER STUDIO
    from Butte,MT
    Awesome chop job.
  9. the metalsurgeon
    the metalsurgeon
    from Denver
    Hey Mart hows it going?, thanks for following!
    The sedan is now home down under!
  10. 383deuce
    383deuce
    Bet it is nice to have it home.
  11. the metalsurgeon
    the metalsurgeon
    from Denver
    Need to add to our body work team @themetalsurgeon
    Our cl***ic/custom car restoration company is looking for a skilled body guy that has minimum 5-10 years experience in the car restoration business (collision doesn't count).
    We are a high end finish company that requires highly skilled and motivated applicants.
    Duties include
    -body work/skim coat using filler after metal work is completed.
    -be able to block down applied fillers on various panel shapes in an acceptable amount of time of which will be discussed prior to beginning of each project.
    -Spray and block sand applied primers.
    -Compensation depending on experience
    -this is a full time position
    email resumes and pictures of your work to valerie@themetalsurgeon.com
  12. hasty
    hasty
  13. the metalsurgeon
    the metalsurgeon
    from Denver
    Need to add to our body work team the themetalsurgeon
    Duties include
    -Compensation $25 per hour and upwards
  14. the metalsurgeon
    the metalsurgeon
    from Denver
  15. the metalsurgeon
    the metalsurgeon
    from Denver
    Duties include
  16. the metalsurgeon
    the metalsurgeon
    from Denver
  17. 55willys
    55willys
    Very excellent work on the flow fit and finish. The job opportunity is tempting but not sure I want to move to Denver.
  18. the metalsurgeon
    the metalsurgeon
    from Denver
    Need to add to our team @ The Metal surgeon
    Our cl***ic/custom car restoration company is looking for a combined skilled body and metal work guy that has minimum 5-10 years experience in the car restoration business (collision doesn't count).
    Duties include
    -Can Mig weld,Tig a plus
    -perform making basic patch repair panels and graft in
  19. danmanman
    danmanman
    from california
    Post #196 asked about "draw filling".
    Your Post #199 showed the position of the file but didn't explain.
    To draw file a regular file is held perpendicular and moved sideways across the metal to show highs and lows.
    Your metalwork is extraordinary. The picture taking is the work of a true teacher. Thank you for sharing both.
  20. clem
    clem
    Any updates..... ? Thanks.
  21. rusty rocket
    rusty rocket
    Yes, I would be interested to hear and see what happening also.
  22. DeLuxe 32
    DeLuxe 32
    Hey All.....sadly there is little to update on this build. Although my wallet is still hemorrhaging, ive had a friend build a 390 Caddy for the sedan, as well as having a T5 put together for it. In the mean time we've recently finished building a house, and once my obligations are fulfilled ill be back onto my projects. Im going to put together a 32 pickup before i finish the sedan. If time allows, chopped, channeled hi boy, swept and z'd, 302w/c4 with 3 x 2 intake, along the lines of Jeff Norwell's pickup. Cant believe where the time goes.....
    Sent from my SM-A520F using The H.A.M.B. mobile app
    clem, LAROKE and kidcampbell71 like this.
