Projects 1952 Buick "Pearl" a factory custom. My first chop
Discussion in 'Traditional Customs' started by LiveActionMotorsports, Mar 19, 2015.
  1. Chili Phil
    Chili Phil
    I was hoping that you'd keep the stock rear gl***. I smell what you're cooking, and I like it.
  2. Blase
    Blase
    Are these frames known to be weak? This looks exactly like the frame under my Olds and I'm concerned about it even more so after reading you bent your's on a speed bump!
  3. I'm reading what your writing and I appreciate it! Hahaha
  4. I don't think so but apparently they are, I just don't want to take a chance.
  5. cmarcus
    cmarcus
    Watching along! Keep up the great work!
  6. Thanks!
    Well I started off the night with a chunk of slag burning through my glove and through my finger nail and let me tell ya, it did not feel good!!![]
    Then I got the rear window frame mounted in. I mounted the center section first then cut in both corners.
    I need to take a little bit of the crown out of the roof to get it to line up now, but it's close. I love how this window is fitting!
    here you can see where I had to make a few relief cuts on the corner windows
    ImageUploadedByH.A.M.B.1439629946.866714.jpg ImageUploadedByH.A.M.B.1439629997.692219.jpg
    I got my belt line cut out and moved forward as well. It's just tacked on for some quick measurements I will need to re shape it a little bit but not a whole lot, I'm really glad I decided to keep the belt line moulding I think a lot of people just give up on it. ImageUploadedByH.A.M.B.1439630030.740582.jpg ImageUploadedByH.A.M.B.1439630109.197000.jpg ImageUploadedByH.A.M.B.1439630125.104641.jpg
    It's 2am my time, I'm gonna clean up shop and back at it tomorrow!
    Also I'm most likely going to run Lexan in the rear for now, what's your guys thoughts on making the rear 1 piece instead of 3? Thanks for the input
  8. xpletiv
    xpletiv
    from chiburbs
    3 window, again, to go with the stock look.
    LiveActionMotorsports likes this.
  9. linkstar69
    linkstar69
    Love the lines, as you mentioned earlier way to many cars are over chopped these days. Looks like that roof has some work left at the blend but you've got it covered by what I can see. Great skill and great attention to detail
  10. Peanut 1959
    Peanut 1959
    Definitely keep the three-window look. I agree that Lexan would probably be the best solution.
  11. I think your right I shall stick to all 3!
  12. Yes I plan to have the blending done today then move on to the cat walk area! This is the first car I've chopped so the thanks for the kind words!
  13. I agree with you guys to I think Sticking to the 3 window will be the route I go!
  14. BJR
    BJR
    "here you can see where I had to make a few relief cuts on the corner windows"
    How are you going to make "relief cuts" in the gl*** so the gl*** fits the frame?
  15. Going to run Lexan in the rear
  16. ImageUploadedByH.A.M.B.1439687819.547247.jpg t ImageUploadedByH.A.M.B.1439687915.858639.jpg ImageUploadedByH.A.M.B.1439687945.690909.jpg ImageUploadedByH.A.M.B.1439687969.703210.jpg ImageUploadedByH.A.M.B.1439687987.679021.jpg
    I got the belt line moved to where I need it and one c pillar tacked in, along with the roof shaped and matched to the new angle of the window. Now onto the other side!
    LONG likes this.
  17. CHOPMERC
    CHOPMERC
    On my Ford I used one piece of lexan to make up the "3" piece rear window. I then drilled it to fit in the window dividers. Can't tell its one piece. Your car is looking great. ImageUploadedByH.A.M.B.1439693755.672643.jpg ImageUploadedByH.A.M.B.1439693793.789495.jpg
    pecker head and Peanut 1959 like this.
  18. That's a great idea I may have to go that route! Was it tricky to get the Lexan to bend to the curve?
    Sweet ride!
  19. CHOPMERC
    CHOPMERC
    Thank you. It wasn't too tricky. I used lexan the same thickness as the stock gl***. Cut it to fit with a template, left it outside for a few hours in the hot summer sun and with the help of a buddy, we fit it into the opening. I welded 2 small tabs to hold the corners in. I used the stock weatherstrip and after the stainless went on, it looks great. It's been in there for about 6 years with no problems at all.
  20. James D
    James D
    Could you use the stock gl*** in the centre section and lexan for the corners?
    Chop looks really good btw.
    Eric H and LiveActionMotorsports like this.
  21. Caprice89
    Caprice89
    :cool: Very nice job. Keep up the good work. Subscribed.
  22. Cool thanks for the advice!
  23. Thanks! It's coming along!
  24. Yes this is my other option! I'm not 100% which route I'll go yet.. Thanks!
    I made some peices to weld to the out side of the inner structure on the c pillars I will do the same for the interior structure of it. I also marked out with sharpie some even areas to cut it so my patch panels aren't weird small shapes and this was I won't be welding really close to another weld and try to avoid making a bunch of heat! ImageUploadedByH.A.M.B.1439739245.967957.jpg
    ImageUploadedByH.A.M.B.1439739341.132298.jpg ImageUploadedByH.A.M.B.1439739396.576733.jpg
    And I do a quick mock up with tape and spray paint of my tail lights! Still on the hunt for a 55-56 Buick bumper and 54 grille! ImageUploadedByH.A.M.B.1439739573.532982.jpg
    pecker head, LONG and Surfcityrocker like this.
  26. Peanut 1959
    Peanut 1959
    Those taillights look terrific with that body. Great choice!
  27. Thanks I can't wait to see it with a bumper to!
  28. Who turned up the heat today? 107 in the shop today, it isn't stopping me!
  29. hacknwhack
    hacknwhack
    from mass
    Glad to see you are going back to the larger window.
    Thats a lot of work to do over.props to you for taking it on
    The 50 chevy didnt look right in mine either.
    Is your red engine orig****y an automatic with hyd lifters? Did you know, the crank and rocker ***y are different from the stick?
    You said you were rebuilding it .wasnt sure if you were planning on using both engines to build one.
  30. Thanks man that chevy rear was killing me.. Yes I also found out after tearing into it that the other motor is a 248.. I decided to just go through the my 263 and pray for the best. It's not in the bad of shape , I don't think "famous last words!" Good looking out tho!
