1952-59 Ford Classic Auto Air
Discussion in 'Off Topic Hot Rods & Customs' started by okiedokie, Aug 16, 2015.
  1. okiedokie
    okiedokie
    from Ok
    Has anyone used their sure fit for 55-56's? I have used Vintage Air in three builds and am very fond of their product, but they don't have the 55 controls function.
  2. Dobie Gillis
    Dobie Gillis
    I'm also interested in this. I have not used them but have heard good things about them.
  3. HOTRODPRIMER
    HOTRODPRIMER
    My pal Dave has used them a couple of times and he was happy with the product. HRP
  4. rick55
    rick55
    I have their 55 kit in my 55 Tudor. The controls on mine are reversed though I followed their instructions. Ialso used double row pulleys. They say you can run it all off one belt but mine even squeals occasionally. Great system but.
  5. Yutan Flash
    Yutan Flash
    from Gretna, NE
    Any pictures of what the setup looks like in a '55?
  6. HOTRODPRIMER
    HOTRODPRIMER
    I used Southern Air in the '54 wagon...works great. HRP
    You can see the vent's I added to the dash. HRP
  7. brassspike
    brassspike
  8. HOTRODPRIMER
    HOTRODPRIMER
    I had to do a little hammer work on the outer side on both the drivers side and p***enger side of the dash to tighten up the natural curve of the dash to accept the new air vents.
    Since I wanted the vents symmetrical I filled in the old heater delete blank to drill the hole,,this on and the other I don't have to do any modifications.HRP
    fordsbyjay likes this.
  9. krusin
    krusin
    from ga
    have you looked into the vintage slide control adapters? they are super easy to work with.
  10. brassspike
    brassspike
    Have their system coming in Tuesday for the 460 swap. Will let you know what its like.
  11. okiedokie
    okiedokie
    from Ok
    Are you referring to Vintage Air? Now that I know they have one designed for 56's I will see if it will work on my 55.
  12. brassspike
    brassspike
    cl***ic auto air.
