Projects A 1933 Ford 5w coupe from a 4 door sedan...
Discussion in 'Traditional Hot Rods' started by Fordgasser1, Jun 4, 2011.
  1. DeLuxe 32
    DeLuxe 32
    Check out Rotten Leonard for seats, they are well priced. HAMB discount too.
    wedjim likes this.
  2. Fordgasser1
    Fordgasser1
    from Jersey
    i have looked at his seats a bunch of times..Very nice and priced right..my opinion too nice for this roached 33 of mine.
    345 and Runnin shine like this.
  3. Mart
    Mart
    Hey! That's great news!
    Mart.
  4. Fordgasser1
    Fordgasser1
    from Jersey
    Just got back from a much needed weeks vacation but blew my back out at work!. Got a little bit done tonight..Here's how it looks With the hood and headlights on.. IMG_1777-2.jpg
  5. brady1929
    brady1929
  6. Runnin shine
    Runnin shine
    All I see is the racing #666!
  7. Looking bad*** man!! cant wait to see pictures of it at TROG!!!
  8. onekoolkat1950
    onekoolkat1950
    I'm in love .... Can't wait to lineup against you on the sand!
    Fordgasser1 likes this.
  9. 1952B3b23
    1952B3b23
    from Western MA
    Looks awesome, it'll be a blast to see it in person at TROG! I agree, it deserves number 666 on the sides. It looks so bad ***.
    -Chris
  10. 40Standard
    40Standard
    from Indy
    can't believe how well that 4 door turned out
  11. -Brent-
    -Brent-
    Thanks for this build thread. It was really neat seeing your skills progress. This car is SHARP. Really nice work.
  12. jerseyboy
    jerseyboy
    That one's already been taken. A roadster that ran in the 1st TROG was running 666.
  13. Runnin shine
    Runnin shine
    I know, I've seen the car. I was just indirectly describing the car as "Evil" which I already recently described another car. I don't want to get called out for being redundant.
  14. Fordgasser1
    Fordgasser1
    from Jersey
    Thanks for all the compliments guys!..I really appreciate them..I already have my number 36c which #36 has been on all my race cars for the last few years..Kinda my lucky number..Gotta get back out in the shop and get some work done, Later! George
  15. Pete
    Pete
  16. Fordgasser1
    Fordgasser1
    from Jersey
    I'll take that as a compliment ,Thanks Pete!..Looking forward to lining up with the Torrnados iron this year!
  17. Fordgasser1
    Fordgasser1
    from Jersey
    After alot of small issues the new Flattie is on my homemade run-in stand and RUNNING!.My original plan was to run a set of vintage 59A style Offy heads but when I checked valve to head clearances they were hitting in some of the valve pockets and the piston to head clearance was tight even with a thick copper head gasket. These old heads were milled at some time which tightened everything up.With TROG time approaching ,I could've ground the heads out for clearance or had the machine shop flycut the valve pockets,I decided to use an untouched set of Offys instead and the clearances were much better,little work was necessary. Got the motor on the stand and couldn't get any oil pressure up cranking it over with no plugs in! I removed the oil pressure fitting from top /rear of block and poured oil in the p***age,Voila! 30 psi of oil pressure just cranking over with starter! .Hooked everything up,put some gas to it,ignition on and she lit right off first shot! My excitement was soon over when I could hear the starter still engaged and grinding on the flywheel!.Tried another starter fixed that issue but then I noticed water leaking from the dual pulley water pumps(these were used and I figured i try them)..Pulled them off,took them apart today and rebuilt them..No leaks! Ha!Had her running on the stand for the last hour at about 2500 rpms to break the motor in..70 psi of oil pressure and temp stayed around 180 degrees..She sure sounded SWEEET! 013.JPG 016.JPG
    brEad and wedjim like this.
  18. Dick Stevens
    Dick Stevens
    Cool, just have to love it when it all comes together! :cool::D
  19. 3banjos
    3banjos
    from NZ
    Thats a pretty special effort for sure. Well done.
  20. 62hotcat
    62hotcat
    sounds good from my house.
  21. wedjim
    wedjim
    from Kissimmee
    Sounds like a typical day in our world! Looking awesome though! Glad to hear it all got worked out, knuckles in tact !....so far.
  22. Fordgasser1
    Fordgasser1
    from Jersey
    Got the "race" flattie in the car the other day. Needed to fix a few minor issues, a few leaks and a problem with clutch releasing which was solved by cutting and lengthening the adjuster an inch.Made some dump tubes off the headers and finished wiring the car. Some race numbers added for TROG..Drove it around the neighborhood a bit..Lots more to do before October! Still don't have any seats! Did traditional hotrodders ever use a milk crate for a seat??ha ha! George
    brEad, thommoina33, 1952B3b23 and 3 others like this.
  23. Runnin shine
    Runnin shine
    Even with milk crates it be one of my all time favorite builds!
  24. Fordgasser1
    Fordgasser1
    from Jersey
    Thanks Runnin Shine!..
    Anyone got a cool seat to lend me for TROG?? Bomber, tudor sedan bucket seat,military seat.PM Me!!! I'm desperate,no time to make one!
  25. It is turning out so great! I'm sorry I can't help with a seat!
  26. Fordgasser1
    Fordgasser1
    from Jersey
    Thanks Cactus..Its all good bro!..If I have to strap a friggin' 1950's lawn chair in this damn thing I will to make TROG!
  27. Runnin shine
    Runnin shine
    George... I got'm!
  28. Mart
    Mart
    It looks great, George. Good think about running on a beach - nobody minds if it drips a bit of water. Can't help with the seats, I put some early MGB buckets in my roadster - they look good.
    Mart.
  29. Fordgasser1
    Fordgasser1
    from Jersey
    Thanks Mart!.. may have the seat dilema solved at least for TROG. I was looking at some old MG seats myself but they were really pricey!
  30. mike bowling
    mike bowling
    Dodge Caravan middle seat ( not the back) fits perfect ( 50+/- bucks at a junkyard)- at least you'd have a place to sit for TROG; strip all the junk off ( headrests, etc.) and throw a blanket over it?
    Car is WAY over the top-nice job!
