Projects '37 Trans in a '29 Model A
Discussion in 'Traditional Hot Rods' started by bunnyc, Aug 18, 2015.
  1. bunnyc
    bunnyc
    Hi, I hope I'm in the correct place to ask this question. I have a '37 V-8 transmission I'm contemplating putting in my stock '29 Model A Tudor. I'll be using the adapter kit from Cling's. I'm not sure what I'll need to connect the trans output shaft to the A's closed driveshaft. Anyone knowledgeable with this swap that can guide me?
    Thanks,
    Bunny
  2. Last edited: Aug 18, 2015
  3. CTAV8
    CTAV8
    As Charlie says, you will need the 4 bolt V8 torque tube bell often called clamshell that goes with the V8 gearbox. The Model A u-joint splines marry with the V8 output shaft, and in fact the U joints are all the same '28-'48.
    bct and scrap metal 48 like this.
  4. bunnyc
    bunnyc
    CTAV8: Thank you. That is the information I wanted.
  5. 1932tub
    1932tub
    You will need to mount the model A pedals and hand brake onto the 37 trans. Does the Clings kit include this?
  6. To the best of my knowledge "YES" but you should address the question to them directly (sometime things change). I believe it also includes the mount for the wishbone.
    Charlie Stephens
