Technical Studs Keep Shearing Off!
Discussion in 'The Hokey Ass Message Board' started by Greaser Bob, Aug 10, 2015.
  1. oldsjoe
    oldsjoe
    Hope you have it all sorted out! Good luck indeed! Joe
    Greaser Bob likes this.
  2. Greaser Bob
    Greaser Bob
    Ok, test drive went very well and tomorrow will be the at speed test as I'll be going to Horton's Hayride in San Pedro. Freeways there and back! So wish me luck and thank you ALL for the stories/insight/advice:)
  3. gimpyshotrods
    gimpyshotrods
    Stay safe.
  4. dirty old man
    dirty old man
    ^^^^^^^^^^^^^^^X2
  5. ROADSTER1927
    ROADSTER1927
    Glad to see it got figured out! Enjoy, Gary:)
  6. verde742
    verde742
    have you still got ball bearings in the hub, or have you upgraded to roller bearings..
    just thinkin' out loud....
  7. Rocky
    Rocky
    Classified Editor
    My brother put aftermarket wheels on his 57 Pontiac and kept breaking studs. I took a look to find the 2 original Pontiac 5/16ths cap srews holding the drums on...the wheels wouldn't fit flush on them, I removed the bolts and the problem was gone...I'll bet those rivets were causing the same problem.
  8. Kerrynzl
    Kerrynzl
    Scary thing. But I'll chime in [ hopefully too late because it is sorted by now ]
    I had two trailers do the same thing but similar but slightly different causes.
    The first trailer was shearing a stud flush with the drum [repeatedly] .
    The cause was the studs [or same stud in this case ] wasn't drilled perpendicular to the drum.
    When I tightened it, it would put a bending load on it and eventually break.
    The second trailer kept breaking studs at random halfway out [similar to yours]
    The cause was the fancy chrome wheels I insisted on using.
    The countersunk holes were not centering the lug nuts correctly. I didn't want to repair the wheels and damage the chrome so I switched to OEM wheels an it never did it again.
    Check your wheels around the lug nuts to see if the are central and no side-load on them
    volvobrynk likes this.
  9. schreddr
    schreddr
    from ND
    This is a (Physical) problem. Although I can not see what's in front of me' I would guess that your vehicle is producing more stress on the front right side. As a process of elimination I would buy some good American made grade 8 lugs. The will be more brittle' But the will be stronger. I suggest you tighten the lugs by (Hand) so as to not (Stretch) them. That will weaken them and make them break. Tighten them until you feel they are tight. And stop. Al ways worked for me. Remember. Cars are like women. You gotta listen to them. Otherwise they never shut up... Just sayin.
  10. verde742
    verde742
    tell me the rivet was the problem ???
  11. Greaser Bob
    Greaser Bob
    image.jpg Drove over some ****py freeways, bridges, and surface streets this weekend to attend The Horton Hayride in San Pedro and NO lugs or studs popped off! Here's a little pic of her there enjoying the amazing weather we were blessed with.
    Thanks again for all the help-hopefully this is behind me!
  12. hotrod1948
    hotrod1948
    from Milton, WI
    Was it the rivets?
  13. Atwater Mike
    Atwater Mike
    Just the DRUM? I'm crushed, it had to be hub/center register interference!
    ...just HAD to be... (dyin' hard here...in A****er...):(
    Glad it fixed, though...after losing the 'bullet centers'... (?)
  14. Greaser Bob
    Greaser Bob
    The rivets on the drum I switched over to were original, in tact, and untouched. The rivets never did come in contact with the rim on either drum. When I layed the newer drum on the rear of the rim laying face down (as in the video I posted earlier), it never rocked back and forth like the old one.
    So the old drum was definitely warped!
    Additionally, after feeling how tight 70 lbs is with the new torque wrench, I don't believe I ever had the lugs tight enough to begin with!
    As far as centering the rim goes, the studs (even on OEM rim) are the only method of centering. It does not fit tight on the center spindle register. Rolled the installed tire/rim and all was straight!
  15. Greaser Bob
    Greaser Bob
    Oh dang I forgot, I strongly believe the push through center bullet didn't help matters either!
  16. squirrel
    that was my thinking all along..
  17. Greaser Bob
    Greaser Bob
    That's why I thank you all, it seems to me like you ALL nailed it!!!
    gimpyshotrods likes this.
  18. 29moonshine
    29moonshine
    thanks for posting the fix. most people do not. and i am trying to learn
    volvobrynk and Greaser Bob like this.
  19. 55Caddy62
    55Caddy62
    Agreed, it's GREAT when folks come back and tell us what actually fixed their issue. Thanks!
  20. oldsjoe
    oldsjoe
    Really glad you posted the cure also! It's always good to hear the fix! Now drive the wheels off of it! Well not really, you already did that! Joe
    Greaser Bob and volvobrynk like this.
  21. verde742
    verde742
    thanks for sharing the fix,, sure good looking..
  22. Bert Kollar
    Bert Kollar
    Just a suggestion. Make sure you are not mixing metric and SAE. 7/16 is very close but won't hold. I was installing wheels for a friend a this happened to us.
  23. geoford41
    geoford41
    from Delaware
    Just read thru this entire thread and I am glad the problem seems resolved. I did note on one of the first few pictures that the dust cover was missing from the front hub. I have seen guy's not install them/forget to re-install and the grease is thrown out all over the wheel to the point the outer bearings do not have any lubrication and can heat up & seize. I suggest that the dust covers be installed after a good repack of the inner & outer bearings.
    geoford41
  24. Greaser Bob
    Greaser Bob
    Well, made Ventura Nationals And back, from here in Brea last weekend without a single problem!
    Thanks again everyone!
    gimpyshotrods and RichFox like this.
  25. Mr48chev
    It's good to see that you got it squared away.
