Technical Bear Precison Dy-Namic Balancer
Discussion in 'The Hokey Ass Message Board' started by convx4, Aug 21, 2015.
  1. convx4
    convx4
    Hopefully I'll be looking at a Bear Precision Dy-Namic Balancer this weekend.
    Its a craigs list find, some what local. I was able to look up the Patten numbers from its tag and get so interesting info. I would like to balance drive shafts, but I like have the capability to balance other rotating ***embly's. I know its old technology and not as accurate as todays computer balancers.
    Does any one have an operators manual for it?
    Or any other experience?
    What do you think?
    What would you pay?
  2. convx4
    convx4
    Well I pulled the trigger and brought it home. Now to get it wired up.
  3. blowby
    blowby
    from Nicasio Ca
    Neat. Let us know how it works.
  4. 2OLD2FAST
    2OLD2FAST
    from illinois
    If you have 3-phase elec. service , you're good to go , otherwise you're gonna need a phase converter , they ain't cheap....
    dave
  5. F&J
    F&J
    There was a company selling electronic converters on ebay some years ago. Mine was $ 75. Purchased so I could use a milling machine. Working perfectly.
    Anderson or Andersen from maybe AZ or western states.
    mine might have contact info for the company printed on it
  6. blowby
    blowby
    from Nicasio Ca
    Yep, mine was $50 and runs my Coates wheel balancer.
  7. convx4
    convx4
    I got the 3Phase converter covered.
    dana barlow likes this.
  8. doyoulikesleds
    doyoulikesleds
    looks like the little guys ready, great picture made me smile
    convx4 likes this.
  9. dirty old man
    dirty old man
    I never operated the machine, but there was one in daily use back in the 60s or maybe 70s at the local Ford dealership. It took a bit longer, sometimes usewd more weight, but it could compensate for some other problems with the right tech on it. watched them balance mine and others, but never deciphered the operation.
  10. convx4
    convx4
    Doyoulikesleds- My two small boys love helping with my projects and I love having their help.
    I got it opened up and took a look at what I have.
    Picture #
    1 Brake
    2 Br*** ring with spark plug wires to dial
    3 Indicator Dial
    4 Control panel
    5 Cut wires
    6 Adjustable pedestal with built in pickups
    7 Transmission
    8 Running speeds
    Now to correctly get the wires re attached.
  11. Atwater Mike
    Atwater Mike
    BZZZZT! Careful there...Volt/ohmmeter will be a good bet whilst matching wires. Take your time.
    Nice find, BTW. Properly balanced tires let you find all the annoying squeaks, rattles, and vibrations elsewhere.
  12. convx4
    convx4
    I won't be balancing tires on this machine.
  13. dirty old man
    dirty old man
    Now you've really got my interest level boosted!
  14. convx4
    convx4
    Dirty Old Man- I hope to balance drive shafts that I cut down/make. The machine has the capabilities to balance automotive cranks or any other rotating equipment electric motor rotors. This piece of equipment was very expensive in its day.
  15. Dan Timberlake
    Dan Timberlake
  16. convx4
    convx4
    Dan, I sent an e-mail to them. I also e-mailed Northwest sales equipment and sviinternational they did not have a manual or any info. The search continues.
  17. dana barlow
    dana barlow
    from Miami Fla.
    This is about one part drive shafts; Drive shaft balancing,for any type machine you have to start with a pair of U-joint centering jigs+you'll need to make or buy, they hold the u-joints so the shaft spins on its ture spinning center,not off the drive shaft tube. Now in real life shorten drive shafts for hotrod an race cars are just that"Short" an if done right*** don't have to be balanced,but if done wrong,some times can not be balanced with out redoing them right. { what is right? first off cut short very sq./strait and dress U-joint end casting so it is also sq./strait,and when they are add to tube again they must line up with the one at the other end of tube= so when the joints are in,there axles are even. Many don't line the two ends up just right,so the shaft will vib. Also most shafts as made stock will have steel Wt. welded on at one end or both/don't remove them from the end you are not cutting off,but the cut end,you do not re-add any{except if you are going to balance the shaft=then only can add as needed. Most of the time it will not need balancing. I did this stuff for years before retiring,my shop was Comp. Tech Miami Fla.
    convx4 likes this.
  18. convx4
    convx4
    Thanks for the insight, Dana.
    I'll have to make some centering jigs.
    The drive shaft ends must be square and straight along with being the same plane to each other.
