Projects 33 Terraplane
Discussion in 'Traditional Hot Rods' started by 33essex, Aug 24, 2015.
  1. 33essex
    33essex
    just thought I would post some on my 33 Teraplane I'm building. There was not a whole lot to start with. Made lower patch panels by hand with plywood bucks to shape them. I chopped the top 2 inch's. IMG_20150620_182826.jpg
    brEad, ABONES, '37-4D and 3 others like this.
  2. OlAZGuy
    OlAZGuy
    from Phoenix
  3. tb33anda3rd
    tb33anda3rd
    very nice!
    volvobrynk likes this.
  4. 33essex
    33essex
    body is going to be chaneled even with the bottom of frame.
  5. 33essex
    33essex
  6. 340HilbornDuster
    340HilbornDuster
    Very COOL! ....subscribed!
  7. Sweet. Love those :)
  8. That's a great looking body. :cool:
    Hudson products are becoming more Rodder friendly lately, but I own a 28 and 29, so I'm a little biased. :D;)
  9. 33essex
    33essex
    here is a pics 2881_output.jpg 2880_output.jpg 2882_output.jpg befor i did anything
    volvobrynk and kiwijeff like this.
  10. Jalopy Joker
    Jalopy Joker
    Cool - you do like a challenge
  11. rusty1
    rusty1
    essex 042.jpg ...cool project, amazing what a 2" chop does to change the profile,.... anybody need one?..here's my 30,000 mile original 33....maybe too nice to cut up...
  12. 33essex
    33essex
    I'm very patient and pretty good with metal shaping,welding and fabrication.
  13. timwhit
    timwhit
    The frame looks to be heavy duty! Your moving along real well and welcome to the Hamb. Tim
  14. 33essex
    33essex
    Thanks soon I will have to put everything away for winter .No garage to work in yet.
  15. nightmoves
    nightmoves
    Looking forward to following this build. Such a cool body style.Subscribed.
  16. mgtstumpy
    mgtstumpy
    Won't see too many of them when finished!
  17. 32 hudson
    32 hudson
    Welcome to the HAMB. Nice body and start on your project. Would like to see more on the the plywood bucks you made. My 32 Terraplane coupe project in my avatar. I am subscribded.
    volvobrynk and mtwalsh23 like this.
  18. 33essex
    33essex
    I will take some pics of the wood bucks .I made and used to make panels tomorrow and post them here.
  19. nice project, I see the frame sticks out a long way behind the body, have you thought aboyt what to do with that? '32 fuel tank maybe?
  20. Nothing is to nice to cut up. The old guys used to say, "the better the sheet metal the better the rod." ;)
    @33es*** nice work friend. I have been contemplating building some bucks to build panels from. I vacillate as I can buy the parts already made but it would be fun to do, a feeling of accomplishment when done. You should feel exceptionally accomplished at this point.
  21. 33essex
    33essex
    The frame I have already cut off when I put body down over frame see first pic in thread. For fuel tank I'm useing a 17 gallon fuel cell. That will be behind rear seat. I'm boxing off that spot from inside of car so if anything happens like a leak or what ever it just stays out side of p***enger compartment.
  22. 33essex
    33essex
    Hear are pics of plywood bucks and pic of panel made from buck. First will be lower cowl panels. Lines are for switching left or right . IMG_20150826_171842.jpg IMG_20150826_172159.jpg IMG_20150826_172144.jpg
  23. 33essex
    33essex
    Here are next pics of lower quarter panels behind doors and pics of panels made from them. Left and right side of car. IMG_20150826_171856.jpg IMG_20150826_172210.jpg IMG_20150826_172134.jpg
  24. 33essex
    33essex
    Here is the buck I used to make the shape on left and right side on rear of car. Back of car is not how is was originally made , but I like how it came out. IMG_20150826_171918.jpg IMG_20150826_172121.jpg IMG_20150826_172059.jpg
  25. malcolm1943
    malcolm1943
    That is some really good info on how to make patch panels from scratch! Thanks for the pictures of the bucks and the finished product.
  26. 32 hudson
    32 hudson
    Thanks for the pictures very interesting . How did you make the beveled edge on the buck and what did use for a tool to pound into the recess ? I am thinking you made your own by grinding a piece of stock to fit in the recess. Did you use 18 ga for your patches ?
  27. 33essex
    33essex
    I used 20 guage theres not much difference between 18 and 20. The 20 guage takes much better to shapeing than 18 guage. What I used for shapeing was a 1 inch wide by 1/2 inch thick chunk of flat stock. I rounded one end.I also used a peice of the same flat stock that had been beat into a nice curve shape. I will have to look around for them and I will take pics. You have to slowly work into shape. As far as a bevelled edge there in not one. The pic for some reason makes it look like there is. Also the metal is screwed to the buck for shapeing to hold I place.
  28. 33essex
    33essex
    Also plywood bucks are not and will not live through multiple uses before new ones need to be made.
    volvobrynk and dana barlow like this.
  29. mtwalsh23
    mtwalsh23
    from Troy, NY
    Looks great man!!
  30. 33essex
    33essex
    This is to 32Hudson if your not in any rush. I noticed you need patch panels for your cowl. Driver side the most. If you have not already patched. I would be willing to hammer out one for you. The bucks have one more round left in them. Cover shipping you can see for your self. I can make it have enough metal to go up to belt line The ends of panel will need to be capped off. If it works for you we can talk price on more panels. It dose take a fair amount of time to make.
    brEad likes this.
