Introducing my Fuel Coupe-styled Tudor
Discussion in 'The Hokey Ass Message Board' started by Just Gary, Sep 18, 2006.
  1. dragrcr50
    dragrcr50
    i see you have one like it on the avitar, lets see it:cool:
  2. AHotRod
    AHotRod
    Any updates on your progress Gary ??????
  3. Swedester
    Swedester
    looking godd there my man.I´m building in that direction too,se pic,and I found a vintage pic that might inspire you
  4. 2manybillz
    2manybillz
    Swedester, I've kept that hemi coupe picture around for inspiration since it was first published - perfect late 50s early 60s drag look if you don't mind a little spit and polish.
    bchctybob likes this.
  5. I've got that T-shirt autographed by "Big Daddy" at Paso 94 for some reason I put it on a hanger and it's never been out of that closet till 5 minutes ago. I had forgot all about it.
    mine is a later coupe/ g***er
  6. HOTRODVAN
    HOTRODVAN
    Gary,
    I love the car. I know this thread is old, but what does it look like now? I have Pop's old car.
    kidcampbell71 likes this.
  7. Just Gary
    Just Gary
    Wow- this is an old thread.
    I finished the angle chop last summer. Here's the thread:
    http://www.jalopyjournal.com/forum/showthread.php?t=377233&showall=1
    The 354 is getting rebuilt by Carl at Black Mountain Hemi.
    http://blackmountainhemi.com/
    Recently, I've been polishing some M/T valve covers and trying to fabricate a Greer-Black Prudhome-style scoop/airfilter.
    The next step is the ch***is. I have a 9" with 4.11 gears and trac-lock waiting to be narrowed and a dropped '33-36 Ford axle waiting under the workbench.
    Here's what it looked like just prior to the Washington DC blizzards:
  8. indygasser
    indygasser
  9. AHotRod
    AHotRod
    I'm back to bug ya Gary.... how ya doing on the Sedan?
    Glenn
  10. Just Gary
    Just Gary
    Thanks for asking, Glenn. I'm making glacially slow- but steady- progress.
    I rescued a stroked and exploded Hemi oilpan- details will follow in the next tech week but here's a peek:
    I'm almost finished sanding and buffing the valve covers:
    The shortblock is finished: It's a 354 with 392 10:1 pistons and a 224' @ 0.050" cam. The heads are next and we'll fire it ~ Labor Day.
    I gathered parts for a front axle- a dropped '33 I-beam and a rear axle- a 9" with 31 splines and trac-loc. Won't bore you with pictures of those.
    Finally, I'm experimenting with a grille insert. This one isn't quite right- I'm gonna add more holes around those I've already drilled, so they continue under the edges of the grille shell:
  11. lorodz
    lorodz
  12. Candy-Man
    Candy-Man
    Grill shell looks great..... Perfect.....
  13. Just Gary
    Just Gary
    Instead of starting another sporadic “Tudor Update” thread, I’ll dust off this original one.
    Progress has been slow for a while, trumped by family and work. But now I’m in a position to give the Tudor some love.
    Fortunately, fellow Virginia HAMBer OJ is nearby and is fabbing a Deuce frame to match my ’28 A, using JW Garage rails, boxing plates & crossmembers. He’s adding fixtures to a basic table, positioning the components based on Wescott dimensions and a plywood template of my Tudor body:
  14. Just Gary
    Just Gary
    The pinion is centered. Wheelbase is 107.5".
    A ruler is cleco'd to the top of the alignment bar/'driveshaft', from the pinion support along the centerline. It shows the true distance to the rear axle.
    The front crossmember fixture locks it at 6* caster.
  15. Kan Kustom
    Kan Kustom
    I am right with you on the type of build with the exception of what you said way back in the beginning of this thread. The part of where this all lost excitement when the gl*** cars came in. I like them too. I am building a 29 Vicky, I built a steel body then built molds to do it in fibergl*** sat on 32 rails with 671 blown early Hemi, Enderle finned bug catcher, CRAGAR blower pieces, CRAGAR gas pedal ,Winters Champ quick change adapted to 40 Ford bells, 31 spline axles, Halibrand Champs and original 11.00x16 Goodyear Blue Streak slicks on rear. Matching raised rib slots and Goodyear Blue Streak speedway specials, Buick finned drums on the front, a 2 gallon Moon tank up front, etc. I like where your going and I think there are a bunch of us out here that will be showing up soon with these type of builds.
    chryslerfan55 and Just Gary like this.
  16. hrm2k
    hrm2k
    Good choice of OJ to built the frame. He does spectacular work
  17. mad mikey
    mad mikey
    Love the build Gary! Here is my coupe , I am with you. WIN_20150412_145154.JPG
  18. Just Gary
    Just Gary
    More of OJ’s magic:
    Frame rails’ insides have been primed with rust inhibitor and captive nuts are to mount the body.
    The jig is configured so the frame rails can be removed and the fixtures stay in place. After the front crossmember is welded, that fixture can be removed and the spring takes its place with the front axle & spindle mockup. DSC00743.JPG DSC00754.JPG DSC00755.JPG DSC00756.JPG
  19. boutlaw
    boutlaw
    Awesome build Gary, subscribed, Envy the hemi/blower, I had to settle for a sideoiler with a crossram, but it works for me, Fuel coupes baby.....Get you some
    brEad likes this.
  20. AHotRod
    AHotRod
    ............. uh Gary !!!! ...... it's been 5 years brother :)
    Glad to see the Dream is still Alive !!!
    Glenn
    chryslerfan55 and brandon like this.
  21. Just Gary
    Just Gary
    Dave & Glenn, Yeah- I’ve done a few things- albeit slowly:
    …filled the roof:
    http://www.jalopyjournal.com/forum/threads/’28-tudor-update-6-steel-roof-covered-by-stock-vinyl.636247/
    …drilled & peaked the front axle and fabbed a mesh grille insert:
    http://www.jalopyjournal.com/forum/threads/’28-tudor-update-7-peaking-the-i-beam-and-adding-a-grill-insert.814111/
    I also scored a free 350 SBC off Craigslist :rolleyes:, which I promptly traded straight-up for a ’92 C-10 700r4. :)
    Finally, I rebuilt the rear brakes and drilled the backing plates. Then welded, ground & filed smooth the F-150 axle housing.
    Meanwhile, fellow VA HAMBers, “ClutchDumpinDan” and “BurnedOutOldMechanic” (Dan & Al) rebuilt the differential.
    The level of talent around here is both humbling and inspiring…
  22. Just Gary
    Just Gary
    More progress from OJ’s Clarke County Speedshop:
    The one-piece ss brake & fuel lines will run inside the frame with “dimples” at the stubs where they enter & exit the rails. The first picture is an experiment to see how they’ll look. Kinda like racy lightening holes, dontcha think?
    Also, electrical conduit is welded inside the boxing plates, through which we’ll route the car’s wiring.
  23. Kan Kustom
    Kan Kustom
    That there is a slick idea.
  24. Just Gary
    Just Gary
    More frame progress:
    The front crossmember is finally tacked in and boxing plate "backstops" are welded into place.
    Then boxing plates are clamped into place and center and rear crossmembers are positioned. Also, the rearend housing ends are cut off in preparation for narrowing.
    Looking at these pictures is like watching ultrasounds of my kids. :D
  25. Just Gary
    Just Gary
    ... while I mocked up the rear wheels/tires & body to determine required axle width:
  26. lothiandon1940
    lothiandon1940
    Watching now with much interest.:)
    Just Gary and kidcampbell71 like this.
  27. Just Gary
    Just Gary
    I gl***-beaded the Fenton Gyro front wheels and polished their outer lips, both front and back. Their centers will get painted to match the ET-III rears. The polished/painted treatment lends a more of a purposeful- less showy- appearance.
  28. Just Gary
    Just Gary
    …and buffed the rear tires’ sidewalls smooth. Sometimes the coolest features are the subtle ones you don’t see. IMAG0629_1.jpg IMAG0631_1.jpg IMAG0650.jpg
  29. Just Gary
    Just Gary
    Thanks to my friend Bob for helping bring the frame home. OJ did a terrific job on it- besides the hidden brake & fuel lines; he also tweaked the center cross-member for extra transmission clearance, narrowed the rearend housing and welded the ladderbar brackets. Plus he emailed regular picture updates. All-in-all, I’m really happy with it.
    Next step is to mini-channel the front subrails & fab new rears, following Rolf’s & DRuss’ technique.
  30. Phillips
    Phillips
    Watching! Care to share tire and wheel sizes? Nice combination of height and width
