Customs 1954 Ford Crestline Victoria Firewall swap.
Discussion in 'The Hokey Ass Message Board' started by VonMoldy, Aug 17, 2015.
  1. VonMoldy
    VonMoldy
    from UTARRGH!
    I have the above 1954 Crestliner Victoria 2 door hardtop and it got hit right on the drivers firewall the windshield and frame weren't affected but the rocker and front door hinges were smashed it pretty good that I need to cut out this section and weld in new piece from a donor car.
    Can I use a firewall and floor section from another model? Would this be the same as a 1953?
    Are the fenders unique to the Cresline cars or are others the same?
  2. You should be able to use a firewall section from any 52-54 Ford. The fender will have to be a '54, but off any model.
  3. HOTRODPRIMER
    HOTRODPRIMER
    I thought the 52-54 body's were pretty much the same in A pillar section forward and I found this photo of a 53 and it confirmed my suspicions. HRP
    My '54 Firewall
  4. VonMoldy
    VonMoldy
    from UTARRGH!
    20150817_172803.jpg thanks for the info guys.
    here is the car and the repair I have a pretty good idea on how to do it but would like some tips in case I missed something. it may be repaired using the stock metal but I dont think so I think it might be easier just use a piece from a donor car.
  5. JeffB2
    JeffB2
    from Phoenix,AZ
    VonMoldy likes this.
  6. VonMoldy
    VonMoldy
    from UTARRGH!
  7. oldolds
    oldolds
    Hmmm. Merc and Lincoln might even be the same 52-54
  8. I'll bet that steering wheel is worth a buck or two
  9. JeffB2
    JeffB2
    from Phoenix,AZ
  10. VonMoldy
    VonMoldy
    from UTARRGH!
  11. VonMoldy
    VonMoldy
    from UTARRGH!
    What do you guys think about using this replacement panel and fabricating the missing parts? The damage doesnt go very far in towards the center of the car. the brake master cylinder area is fine its mostly the extreme drivers side and up to the windshield. The windshield didnt get damaged and I measured the frame of the windshield and it is nice and even.
  12. JeffB2
    JeffB2
    from Phoenix,AZ
  13. shivasdad
    shivasdad
    from Texas
    @VonMoldy, those toe boards are really nice stampings. I'm replacing floors and rockers in a 1953 right now and the metal is thick and welds nice. They make nice floorboards as well. Building the firewall and cowl side and the support pieces under there would be difficult, but not impossible. I would think a donor would be easier, but those cars all rust at the rockers and outer supports. Good luck.
  14. VonMoldy
    VonMoldy
    from UTARRGH!
    Thanks for the input. The trouble I am running into if finding a decent priced car that I wont feel bad cutting up that is pretty close.
    I was really impressed that they have nice stampings and 18g steel and made in USA. The drivers toe board extends up pretty high and I have a shear and a brake so I figured maybe it would be easier. I also have a ford shop manual and it didn't look too difficult but I might be naive.
  15. VonMoldy
    VonMoldy
    from UTARRGH!
