Technical Trying to indentify Chevy Differential
Discussion in 'The Hokey Ass Message Board' started by brevennaugh, Aug 29, 2015.
  1. brevennaugh
    brevennaugh
    Anyone have an idea the year range of the attached Chevy diff? Is there a website i could go to to check it out? I'd like to know final ratio, and how to remove drive shaft.
  2. manyolcars
    manyolcars
    Is that a torque tube? 1954 was the last year
    volvobrynk likes this.
  3. brevennaugh
    brevennaugh
    Yes, has torque tube. Is this a pre-54 Chevy? What year did Chevy start using this rear?
  4. squirrel
    I replied with some information in your other thread asking this question. Maybe you should see if you can find it? and only post a question one time?
    yeah, this forum is busy, and it's hard to keep track of your post...but if you don't, you won't see the replies. Welcome to the hamb!
    Go to your member page, and click on the "postings" tab, and you should find all 3 of your posts. then you can find the other thread you started.
    brevennaugh and volvobrynk like this.
  5. stimpy
    stimpy
    or when you post click on the watch the thread option under the message box ( it will send you messages when people reply ) . took me a while to learn how to use this place and I been here since 08'
    volvobrynk and squirrel like this.
  6. bct
    bct
    I just bumped your first thread
  7. volvobrynk
    volvobrynk
    from Denmark
    I think there something about old chevy rears has a cast in number on the p***enger side of the banjo with info on year and ratio? Or is only the newer ones.
    And FYI @squirrel is the ID master of all things chevy, never let me down or disappointed me!!!!
  8. squirrel
    yup, there might be a casting date. Like D 13 1 which translates to April 13, 1931 (or whichever decade is appropriate for that particular casting number)
