Technical Need new chopped radiator for my channeled truck (advice)
Discussion in 'Traditional Hot Rods' started by corndog, Aug 28, 2015.
  1. corndog
    corndog
    from Indiana
    I built this channeled hot rod truck over ten years ago from a falling apart '29 Plymouth sedan. I sold it to a guy who never did one thing with it. Supposedly someone stole the Whippet grill shell and hood while he had it. I bought it back a few months ago and have found another hood and grill but I dont like the funky radiator I had in it. So am looking for a reliable vendor for a new aluminum chopped radiator. Everything I see on the net is chopped 3" and that will not be short enough as my truck is channeled 5". Anyone had any similar issues and can offer some help?
  2. What size do you need?
    Channeled 5" doesn't say how big the radiator needs to be.
  3. 32 hudson
    32 hudson
    Suggest making a template of the size you need to start with and look for an oem replacement
    in the Chester's book how to build a t bucket/ hot rod for under $300 there is a section that gives different radiator sizes /dimensions.
  4. wbrw32
    wbrw32
    I would suggest anything BUT ALUMINUM....
  5. falcongeorge
    falcongeorge
    from BC
    You know, that's a pretty neat little truck...bet it leaves a lot of guys scratching their heads...
  6. Mr48chev
    I'd go along with finding an oem replacement radiator that will fit behind the grill unless you are up to shelling out the coin for a custom radiator.
    I did see an "we will build it to your measurements with no plastic anywhere" radiator outfit advertising on the net when I was hunting for one for the 48 one night but don't remember more than that.
  7. 340HilbornDuster
    340HilbornDuster
  8. 383deuce
    383deuce
    Check with RCP they will build you any size you want and they are all welded alum construction and cheap.
  9. Rex Schimmer
    Rex Schimmer
    from Fulton, CA
    Find a radiator that is the right height and then cut it to your required width. You can narrow it with a wood cutting ban saw and then block of the tank and add a cover for the core on the side you cut. You will need to be able to TIG weld or have some one that can but it really turns out pretty simple. I built the radiator for my modified from a core that I bought but making one from an existing radiator is much easier.
    Rex
      519.8 KB
