Customs 1941 Chevy Coupe Build Thread
Discussion in 'The Hokey Ass Message Board' started by Project41, Aug 4, 2014.
  1. choptop40
    choptop40
    hey hey , this is my favorite build lately.....old school and cool.....gonna ride beautifully.....lots of aftermarket stuff for the frame......
  2. Project41
    Project41
    Wes, here is a drawing of the frame I found on the internet off of a G-body forum. The drawing indicates the structural bracing that is recommended to harden the G-body frame. I added the grey lines in the center to indicate the approx spots I am building perches to attach the body to this frame. Once situated I will X brace it with a drive line loop.
  3. Project41
    Project41
    I didn't want to blow the bank account up with air bags, so I opted to go with some drop spindles to bring the car down. I went with RideTech's 2" drop spindles from Summit Racing for the 5th gen frame, part# 11399300.
  4. Project41
    Project41
    Started on some sheet metal work; removed the poor fill/weld job on the gas filler hole found after dipping the car. Going to relocate it to the trunk area, somewhere...
  5. Project41
    Project41
    New right side tail light patch panel installed.
  6. Project41
    Project41
    Gutted the entire trunk floor all the way to the back seats, was hacked in poorly and not properly tied in; just kind of floating in space without reinforcements. I will custom make the floor to fit the frame I am using.
  7. shagginwes
    shagginwes
    Thanks for sharing you project with us. I actually stsrted with shortening the frame one inch and moved engine five inches to the rear. The rear horns I cut off and cut a vee into the lower section to keep the horns lower so the rear of trunk will sit on frame. Not rea sure hiw to make mounts so I bought square stock an welded plates onto he top then drilled hole to match body mount points. Where the stock was welded to frame it axctually stiffened the flimsy rails. I will try to send pics asap.
  8. Project41
    Project41
    Yes, please post some pictures, I would like to see how your build is going.
  9. Project41
    Project41
    Project updates: Found second left tail light patch panel to finish off the terrible tail light crater holes that were there before. Starting to look normal again!
  10. Project41
    Project41
    Decided this deep into it to replace the firewall, here it is installed.
  11. Project41
    Project41
    Ditched the floor, there was too much rot to repair. Here is the body just sitting on the frame before the rail ends are cut off.
  12. choptop40
    choptop40
    Looks awesome......keep us posted.....
  13. buick bill
    buick bill
    from yreka;ca
    how did the 41 turn out .? im looking for some inspiration to start mine ! anyone think a 73 nova clip will be to wide in a 41 coupe ??
  14. Deuce Daddy Don
    Deuce Daddy Don
