Faux 1932 Ford roadster pickupproject
Discussion in 'Parts For Sale' started by earlyv8, Jul 18, 2015.
  1. earlyv8
    earlyv8
    from oklahoma
    City: Edmond
    State: Oklahoma (Boomer!)
    Price: $9,500.
    Price reduction $8,750.00 USD
    Greetings, due to declining health, I am offering the 1932 Ford roadster pickup project that mimics the 1932 roadster pickup as built from scratch in articles of American Rodder in Jan, Feb, and July 1999 issues.
    PICTURES ATTACHED for many of the parts.
    Many of these parts have been collected over the 48 years I've owned the 32 5 window pictured as my avatar.
    You won't be disappointed.
    Due to the number of parts, shipping should be considered impractible.
    Price in USD collected funds.
    Parts list:
    Frame: New and unboxed JW 32 frame rails and an old original 32 crossmember that could be used to add to after market front crossmember for correct radiator placement and riveted in frame , JW front cross member, excellent 32 K member, 35-40 rear cross member,
    Suspension: 32 Ford MorDrop (yes MorDrop) heavy front axle, nice 32 unsplit wishbone, 32/34 uncut perch bolts, or choice of after market, Posies reversed eye front spring, 35/40 rear spring, 40 Ford rear end with 33/34 drive shaft and torque tube,and also have open pickup banjo rear, 4 X Armstrong shocks also have some Ford Houdaille shocks, 4 X 46 Mercury 15" wheels with new Ford hubcaps and beauty rings,
    Steering: 1937 Hudson steering modified by HAMB's Neal Jennings to fit 32, with Limeworks 40 style steering wheel with small crack, includes original 32 column drop with key and switch, 32 Ford spindles or choice of round back or square back spindles,
    Engine: rebuilt 59AB with adjustable lifters as found in old Ford dealership, recommend taking apart and reassembly, D & S dual carburetor intake with 3 X 97 Stromberg carburetors with some linkage parts, new Brice Thomas aluminum 32 V8 radiator with stay rods, 39 style toploader 78 case and late style shifter, and correct type rear mount,
    Sheet metal: 32 Ford original filled grille shell, repaired original grille, 4 piece hood with after market sides with louvers, 2 X closed car cowls with cowl vent parts, pair of repro steel roadster door skins with one pair of hinges, pair of 32 4 door b pillars for rear door jams, nice original 32 Ford firewall (no extra holes) or modifications, repro roadster steel dash, 32 Ford gas tank, and pickup bed made by a friend (I intended to use it),
    Brakes: pair of F2 backing plates 12" Bendix, 40 rear brakes, 4 X 45 fin Buick drums, 32 brake and clutch pedal (no pedal box) corvette type master cylinder (recommend kit),
    Misc: steel battery box for type 24 battry, 32 (used) hood hold downs, 32 B model head light bar, 2 X 903J headlights with brass tags (prewar) GM head light / ign switchs, battery cut off switch, 1 X 37 Ford tail light and pair of 32 Ford spare tire rack ends, I intended as tail light stands, set of new Autometer gauges with electric speedometer, Bendix 12 volt fuel pump (has been used).
    Thank you
    Jack
    405-812-4932
  2. earlyv8
    earlyv8
    from oklahoma
  3. earlyv8
    earlyv8
    from oklahoma
  4. earlyv8
    earlyv8
    from oklahoma
  5. earlyv8
    earlyv8
    from oklahoma
    BTTT
    Virtually a complete kit with exception of rear panel.
  6. earlyv8
    earlyv8
    from oklahoma
    BTTT
    You would look for a long time to find parts this quality and quantity.
  7. earlyv8
    earlyv8
    from oklahoma
  8. earlyv8
    earlyv8
    from oklahoma
    BTTT
    Lower price $8,750.00.
    This is not a museum, this project is for sale.
  9. earlyv8
    earlyv8
    from oklahoma
    BTTT
    Will make a very traditional RPU.
  10. earlyv8
    earlyv8
    from oklahoma
  11. earlyv8
    earlyv8
    from oklahoma
  12. earlyv8
    earlyv8
    from oklahoma
